Nickfromwales
    346
  1. @Ed Davies Ed, if you wish to 'mention' another member simply type the @ symbol and then the first couple of letters of their ID and then select from the drop down list that will appear. Like I have done above. To quote a segment of others posts just select the section of text and 'quote selection' will appear. Click that and it'll open the editor with that person notified that you have quoted them. Anything else you need to know just ask
  2. You'd have a deep void between joists for lights ! Keep the ceiling high IMO.
  3. For the joists to stop / start over the flitch you'd need a 8x3" joist above the flitch ( running in line with it ) and the timber ends would need to be mechanically fixed to the extra joist. You'd then have to noggin between the ceiling joists near to the beam to keep things true.
  4. A manufactured flitch would look nice cleaned up and stained eg left on display. .
  5. Hi and welcome. If not EPS then what was the suggested alternative?
  6. They're nice little units. The L-shape stuff looks more expensive than it is so a good option. The cisterns do have the access through those panels, so the tops only ever need to come back off if there is a major failure.
  7. Ah, yes. 2 heads better than one. Maybe better with a trio of 9x2's, joints staggered, and make a flitch beam. Best of both worlds ( timber faced already ) and then sit the firing pieces on top going perpendicular to the steel plates in the flitch to reduce the cold bridge. All depends if pillars are preferable or not, but pillars and a regular steel with the joists / firing pieces atop is probably the cheapest and quickest route. I'm pre-programmed to eliminate pillars and boxed in beams as I massively dislike both. OCD sorry.
  8. If you go for an ASHP, then I'd go for 3 runs of pipe to a void for the areas in spreader plates, that will give you more volume so less temp required to get the equivalent w/m2, and in the screed id go for 150mm centres. You want to get the volume of water & cross-sectional area up, and the flow temp down 3 pipe plate No reason why the LG and GF cant be on the same manifold as that'll be the highest point and will vent itself without issue. Manifolds are available as big as 12 ports so no bother from that PoV but will save you cost / complexity / extra 22mm primary HP pipe runs to the 3rd manifold / no 3rd wiring centre and less physical size / impact for the overall installation. I'd be very surprised if you cant do that off one manifold tbh, ( + the second manifold for FF of course ). Ask the question with your chosen supplier
  9. Avoid the B&Q stuff, it really is dog shit. Im fitting vanity sinks and WC's in my current job purchased from there and the quality and finish is just disgraceful. How they allow stuff through quality control is beyond me. Utter shite for what they're charging for it. Looks great in those pics, just wait until you see what actually turns up.
  10. You won't get that cistern flush plate into the short panel of the vanity unit linked. TBH ive just done one identical to the first link and I just fitted the regular hide-away cistern and then simply bonded the sit-on sink top with 4 dots of white silicone, between the underside of the top and the top of the carcass. Then I applied a bead of white all round to prevent water ingress. If it ever needs an overhaul you simply peel off the silicone, run a long blade type craft knife through the 4 dots ( 4 five pence sized dots is ample to hold things in place ) and lift the whole thing off. Worth the effort as imo these really do look nice when fitted.
  11. That would have to be a plate with a welded flange, pre drilled to accept the wall fixings and the steel ends. Do-able, but more cost / complexity. Id rather plate the steel with timber and butt the joists up to that so the timber sits flush with the steel, that way there is no boxed-in beam showing underneath the ceiling level.
  12. Change of £19 for the 300mm one. Fitting two of these exact ones in my current job. Will show a pic tomorrow. Looks the dogs bollocks for the money.
  13. Yes, saw that but it can only be both, eg inbuilt would be sitting on the last course of block. As its a flat roof, you may be able to detail some cold bridge mitigation in but it would be negligible / useless. "Attached" is the other option where the steel is mechanically fixed to the block. EWI may help, and allow you to go cheaper on the block.
  14. What will support the steel and stop the cold bridge with that being end-exposed? Plate it and 'gallows bracket' it? Will need to be an UC then and not an UB?
  15. Agree its a wasted space otherwise, but what will keep 10 tonne there? Will the weight simply be spread over a long distance and things beefed up as required? Bespoke tanks ? Its an interesting idea so im keen to better understand it. Thanks.
  16. Another good reason to ditch it. With the thinner liquid screed I think you'll be over the safe threshold for the floor temps.
  17. Just trying to work out how to kill off the cold bridge where the steel meets both ends of the building. For the front, drop back to regular thickness blocks to get a 100mm deep pad stone, prob 600mm wide sat on the under-laying full depth blocks and then the outer edge will be the thinner course of thermalite ( eg so the steel stops 100mm into the 215mm deep wall ).
  18. Just realised I'm fitting the same valves in this job. For the money, the flow rate is excellent.
  19. How about a piece of PB like I said? By now I'd have had 3 walls 4 courses up !!!!!!
  20. Hi and welcome to our new hideout . Im intrigued as to where this 10 tonnes of water will sit? Ill definitely be looking at the links later, some evening reading. Always pricks my ears up when I hear "off - grid".
  21. I'd go for the deeper thermalite and 75mm insulated stud work with 30mm insulated plasterboard over the studs. Warm as toast.
  22. I was just going to say steel spine and normal joists but @PeterW beat me to it. Steel will be better and quicker IMO with no need for extra detailing with the pozi joists required. Just drop them in as your building the walls up. Cheap enough and logistically simpler.
  23. You need one manifold and one pump and blending set per floor minimum. Im not so sure you can't do both floors with 2 sets. Why are they mentioning 3 pumps? 3 pumps would mean 3 manifold locations, so are you doing towel rads off a 3rd ?
