Nickfromwales
    345
  1. I hope you’ve got the drawbridge working? 🤔😆.
  2. Who is principal contractor? It’s their role to do due diligence and help you reach out for costs, with tenders.
  3. It should enter into a junction box, fixed to the back of the cabinet. From there it can be either trunking or conduit, trunking prob easiest here. Basically you shouldn’t be able to see the brown or blue cables at all as they’re not PVC/PVC.
  4. Having single PVC’s ‘on display’ is a no no. How the feck are they getting away with this if it’s the finished article!?!
  5. I was wondering why the test certificate had pictures of the Mr. Men on it. lol.
  6. It's to de-rate the outgoing supply, so L > SP MCB > final destination. The cable feeding the MCB should be able to take the current of the supply so it's not looking up to par.
  7. We're both going to hell. lol.
  8. What have I told you about drinking during the day?
  9. I've zero idea of what I'm looking at. Is the cable regular twin and earth (T&E), as it appears to me to be so. If it is, then it's a dangerous install. This needs to be in "containment", so as @Mr Punter suggests it needs conduit or trunking. Even if this is temporary it is dogshit on toast, and the bread was out of date.
  10. This catches so many people out. Needs taking off and replacing regularly. I feel for you, but maybe you could reach out to the courts and ask for some scrotes on community service to be sent round. They won’t break the law ever again after that.
  11. Unsuccessful Somalian pirates most probably
  12. VHT (Very High Temperature) paint is used on exhausts and the such, so start there.
  13. Two entirely different things! The weather sealing is fundamental, so absolutely should have been done. They (or you) can now use a clear UV stable mastic to do this, or employ a "mastic man" who will not come with fat thumbs and make a mess of this in anger. If the work is offered up as snagging, state before work commences that you don't want the sealant looking like Ray Charles did it.
  14. I'll get my coat.......
  15. People will just be plugging these in with near zero GAF though, I expect.
  16. Quite interesting! Thanks for that.
  17. Ah! How does it then not electrocute the poor sole holding the pins of the plug?
  18. Erm....expense? A few £10's at most. It's a totally different foam, which will be void of honeycombing etc, so buy cheaper foam if you wish, but "seriously!?".
  19. He'll be dead from worry before the concrete has set! An extra 200mm of concrete will have zero impact here. Mountain vs molehill. I dread to think what'll happen when you have to choose paint
  20. Drill a dozen 6mm holes and pump it full of "PIR in a can", eg Illbruck foam <20 mins per window, job done
