Yes. Shingle goes under / around / atop, and then the sand blinding goes in. Groundworkers will just shoot through this, but if there's any major backfill over the shingle then they may well use a bit more type 1, then the sand (usually dependant on how far they have to walk to either pile of 'stuff' ).
360 degree laser level recommendations
Nickfromwales replied to flanagaj's topic in Tools & Equipment
Don’t bother with tripods indoors, they’re too susceptible to foot traffic. -
I used the red line Bosch 3 80, sub £400 iirc, for years and years and then (when I got fed up of batteries being consumed) I went and got the Milwaukee Green 3 line with 4ah rechargeable batteries. Miles better and sub £600 iirc. -
Worcester 24i Junior - PRV?
Nickfromwales replied to Mulberry View's topic in Boilers & Hot Water Tanks
@Mulberry View Have you checked the pre charge pressure in the expansion vessel? -
I’m one for caution but it’s just push fit with a retaining clip. Worst thing that can happen here is you get wet tbf. Drain down, get a towel, isolate the electrics to the boiler, and get it swapped out. You'll need a lint free cloth to clean out the receptacle and some silicone grease to lube the o ring on the new item. Slight twisting motion when you offer it back in. Same retaining clip will be fine. -
New build waste drainage, durgos and the regs.
Nickfromwales replied to jimseng's topic in Waste & Sewerage
Yup. 👍. SVP’s vent the accumulated gasses in the network sewerage system, and as you’re on an STP you don’t need to do that. As above, you can put it on an external facade out of sight or just route a branch off the STP and do a short stub stack / riser in the garden or landscaping, defo away from where you’re BBQ’ing lol, although these things don’t seem to stink as much as a sewer would. -
What do you think?
Nickfromwales replied to Alwayslearning22's topic in Bathrooms, Ensuites & Wetrooms
Rail for me, EVERY damn time . -
Good that you stopped that one from doing anything more on site tbf. That wall is (was) just shockingly bad. Onwards indeed
On the current MBC project I'm consulting on, we have soil pipes in the 150mm MOT1 layer directly under the 50mm sand blinding, and some others like comms and landscape power are lower to avoid these. I designed all this ahead of MBC's arrival, making sure there were the least number of services crossing over/under each other. As you're under a raft, there is no minimum depth THB, but for power and water you do need to drop down towards the periphery to comply with the 750-900mm that these authorities will mandate.
Kitchen Grid/Isolation switches
Nickfromwales replied to Spinny's topic in Electrics - Kitchen & Bathroom
Just DO NOT let them fit them down low, as you'll bash the crap out of them taking things in /out of the cupboard. Get then as high up as you can, plus then you pretty much cant see them. This. Install a piece of 15mm MDF or PLY behind, screwing it into place where the sockets etc will hide the screws. -
You don’t need the SVP then! Just vent in the garden on a stub stack. -
You can ask the BCO for a 1:5 or 1:10 exclusion, if you’ve got immediately neighbouring properties where you can show they all have a SVP (Soil and Vent Pipe). Then they should be agreeable to you cutting the pipe back inside the attic and fitting an AAV (Air Admittance Valve), aka Durgo, and close the roof back off. -
Whats going on here?
Nickfromwales replied to CalvinHobbes's topic in General Self Build & DIY Discussion
If they lose the stupid name and make the colours more neutral, that may help.- 1 reply
Easy folks! There is the old saying, "if you've nothing good (or helpful / productive) to say, then saying nothing is best". If we can't offer support then let's keep schtum, please. On the flip-side, if anyone feels like they've been singled out or spoken to in a manner that's offended, then please use the REPORT function and the mods will review this and respond accordingly.
Changes to the grid proposed
Nickfromwales replied to Temp's topic in General Self Build & DIY Discussion
Oh deer….. -
Tell us more about this Moose Count. -
So...I'm about to do Rainwater Harvesting
Nickfromwales replied to mike2016's topic in Rainwater, Guttering & SuDS
Pressure vessel, aka accumulator, is an essential bit of kit. For RWH, anything less than 10,000L is a waste of time and money. This is one sector where sales people are waaaaaaaaaaaaaaaaaaaaaaaaay better than the thing they're selling. -
Sticking insulated plasterboards
Nickfromwales replied to Arnold9801's topic in General Self Build & DIY Discussion
Topic moved. -
Over site prep after foundation masonry. Why?
Nickfromwales replied to flanagaj's topic in General Flooring
By the looks of the block-work they may just fall out with a swift left boot. -
That block-work is shockingly poor. Zero GAF, and there’s no way whatsoever that person should be doing anything for face work. If you don’t care about stuff that’s not on show, to that extent, as the horizontal line looks like a waveform, then there won’t be much more care for the remainder. Shite.
No need to I’m on these projects full time so the last time I had to do this was less than 2 years ago. AKA “hands on”. On walls it’ll stay put, give or take a few handfuls, but if it’s overhead then it’s going to drop out like confetti. Removal is simple with an AVCL, as you just make a 2” incision into the membrane and poke Henry’s pipe in there and keep sucking and swinging the hoover pipe about until you’ve got the worst of it and then open up a section. From there you can go to a dustpan and some bin liners.
Make a ramp, and get the micro digger in there. Or just get a wet saw and remove a 1200mm section of brickwork and accept that as collateral damage aka “it is what it is”. Digging it out by hand is unnecessary, there’s always a solution. A good machine operator will tell you how he’s going to get a machine in there. My guy walked up a vertical 900mm brick wall without so much as a scratch. -
Goes in bone dry. Comes out with more enthusiasm than you’d ever want. A Henry would remove it in seconds. I’ve had to chop into a few MBC homes retrospectively and it’s a pig of a job, especially ceilings, as the second you cut the AVCL you’re wearing two bin bags worth of it. Not so bad with walls where it’ll stay put, if you’re very careful.
