Nickfromwales
    330
  1. Yup, the 10mm works surprisingly well.
  2. It could go above I think. Does that pipework head upwards to the manifold?
  3. Every sizeable dwelling gets this discipline installed as standard. I never leave specifications to a client tbh. I make them aware ( at the quote stage usually ) of what will be installed and why. I don’t get into that degree of being micro-managed as people are asking for my professional opinion vs them wanting to go to a cheaper option due to bean counting. Clients could demand that I do it a certain way and I can then either cover myself with signed caveats, or refuse to do the job, particularly if I felt that was going to be more laborious for me ( what bean counters often decide to selectively overlook ) or to the detriment of the finished system and its reliable ( and robust ) operation. Hepworth manifolds have a good waterway and allow flow through with relative silence, but cheaper ball valves / other isolators can be both restrictive and noisy by comparison. For @Russell griffiths job I’d be feeding both ends of the manifold with water, so a bit like a ring. Costs aren’t a million miles away from ‘normal’ plumbing when you discount all the joints, costs of additional fittings, increased liabilities and the number of times you’ll have to drain down and refill during the course of an entire build. Ive had such good results with the manifold system why do anything else? “Tried and tested”. Members here with the traditional arrangement have given poor feedback on the amount of time it takes to get hot water out of the taps with the primary distribution having been in 22mm everywhere, or even worse, starting in 28mm ?. Not for me sir, no thanks.
  4. https://www.ebay.co.uk/itm/STAINLESS-STEEL-LOW-LOSS-HEADER-HYDRAULIC-BALANCER-25kW-1-INSULATED/293485375133?hash=item4455176e9d:g:5WAAAOSwmfhX4qyi Something like this.
  5. Have you checked that the radiator valves are fully opened?
  6. 3 mins down the road from me lol. Sounds deffo like a small buffer would sort it, just down to having some ( more ) room to fit it. You may be able to get away with just a low loss header if the lowest base loads aren’t a million miles away from the lowest burner setting for heating. I’ll ask my mate ( who loves everything WB ) if that can be dialled down on that boiler. Maybe a call to WB tech support would get an answer quicker.
  7. Don’t be scared about having a big one Will suit your build timelines perfectly with you being able to connect and test over time / as you go. ?
  8. If the OP has 16 x cold feeds ( assuming 3 x WC’s / 2 x cold mains appliances ) that’s 11 outlets requiring cold supplies ( so also assuming 11 hot supplies ) then the cold supply would need to get to at least the first two bathrooms in a minimum poor size of 22mm. Same for the hot, but the hot more like starting off in 28mm, then picking up the first bathroom, and then 22mm from there forward, and then reducing to 15mm as seen fit. Really if a bathroom is the last item then you can’t drop to 15mm until you’ve picked up the shower & bath. So, a minimum of 26 x T connections if you don’t adopt a radial manifold setup and fingers crossed after you’ve tested initially and boarded up. Another benefit is that for a new / self builder, you can just bring on items as work progresses, so no need to keep draining down / connecting / re-pressurising each time you add a new item. And, the party piece is hot return and flow rates. With a large single bore series setup you’ll be waiting for a very long time to get hot water out of basin sinks in particular as they are low flow / high frequency use and by the time hot had got there you’d have got fed up waiting. Pressure and flow rates are as uniform as you can get too, so question has to be.....why wouldn’t you do it? Not having isolations on the end of every run / at each outlet is a no-brainer, as most modern bathrooms won’t have somewhere for such valves to be easily / practically accessed, particularly for baths and showers etc. Regular ( series ) 0 Manifold ( radial ) 1 ( well 4 actually ).
  9. Not going to happen. My pissed tiling is better than your sober ones ✌️??
  10. You know that if you hadn’t done that, one of us would have come there and done it for you. See, a night off, and now some clarity. Buy some new tiles and make peace with your inner grouting line self. And breathe.......
  11. 25mm2 4-core and loop it back on itself as a ring @ProDave? Equivalent of 50mm2 then so 16a would be achievable reliably ( given a consideration is likely here for diversity ).
  12. If you're keeping the bed, for a new life elsewhere down the line, just cut the skirting. Skirting is pennies, but just keep the bits you chop out and caulk them back in when the time comes. Screw them to the underside of the bed for safe keeping.
  13. OK, I've had a loom and all seems good to go. There should be a double-check NRV immediately after the stopcock, and then a drain off cock. Make sure the outside taps have NRV's in them. Do you need the second hard manifold? Ideally you'd make the 1st hard manifold bigger and run the 3x bathroom hard feeds back to that. No issue with your setup as is, if that is easier. "Carry on!"
  14. What is the cold mains pressure / flow like? I've done plenty of UVC installs where there is only a 15mm cold feed to tap into, and they worked fine. You just need to understand that if you have multiple cold devices running when you want a shower, it'll be a less-than-amazing shower. That's all
  15. All work and no play go watch a film
  16. Not much you can say about those, other than put up and shut up or yank them off and change direction ( tile )? It would drive me nuts, but once it’s on you’ll just adjust and move on with your life. I have stuff in my bathroom that I did a less-than-perfect way, but I did do it over Xmas, and I was pissed most of the time I was tiling.
  17. I’ll put a man on it shortly. ??
  18. Oops.
  19. I’m allergic to apples.......
  20. Texas grout line massacre? ?
  21. Other option could be to use Wedi insulated panels, which you can build up in layers of differing thicknesses, to achieve the same result. DPM will remain intact as the Wedi system is watertight. Just foam around edges then, instead of pouring SLC as the SLC would bridge damp.
  22. That’s going NOWHERE, EVER
  23. The most recent one I did was the following; Cut out DPM, cut out insulation, foam insulation to block and beam, weigh down until cured. Then apply foam to top of upper insulation and spread DPM back on top until all in contact and keep doing so whilst foam cures so the DPM is bonded to the insulation. You could make a plywood baffle and weigh down if easier. ( Note, obvious waste connections done in parallel to these processes ). Then reinstate DPM and tape it up to death and back. Tray then simply laid onto plywood pattresses which were foam bonded to the DPM and then flexible tile adhesive onto those pattresses and tray onto that ( cleaning and preparation of the underside of the tray carried out as required ). Tray set into place and tile adhesive left for an hour or two to cure. Cardboard funnel then made and self levelling compound flooded into the remaining void under the tray ( nearly 2 bags in this instance ) to a) fully fill the void and leave the tray ‘locked in’ at all 4 corners and all 4 sides, and b) to mechanically support the trap ( which is best practice imho ).
  24. They’re all much of a muchness. You may have to remove that one to see what you’re up against. Then ask manufacturers for the schematic of the new one to see if there will be any conflict. If so....voddy up, hammer out ?
