Nickfromwales
    346
  1. A mist system takes up no more water that it takes to fill a bath, and only requires a piddly flow from a 15mm inlet. Can’t see why planning would be an issue? Just fit the system and ask questions later. Applying retrospectively would be par for the course if I was interested in going for this dwelling.
  2. Automatic fire suppression would permit the dwelling to be habitable and compliant.
  3. Do you have room for an accumulator? 300l would be the minimum to install if you want a decent uplift. If not, then it’s a pump set. Accumulator is silent and near zero maintenance, so I’d at least consider that first. It can be in an outbuilding/ garage / other. Go to screwfix and get a pressure tester for a couple of tenners, and connect it to the outside tap or was home machine valve. Report your reading here.
  4. I think it would be wise to get this power-flushed once and for all. That should sort this out long-term and leave you with a healthy refreshed installation. At that time, if it turns out you do not have a magnetic filter ( Link to a robust example here ), you might want to get one installed, and also instruct that person to treat the system with inhibitor ( and watch them do it ). Once this is done, you should have trouble-free motoring from that point onwards. Is your home UFH only, or do you have radiators there too? Trying to work out where this corrosion ( and subsequent build up of goop ) is coming from? Have you had the automatic vents fitted? Pics?
  5. The likelihood is, because of the distance, you will have to de-rate to an 80a fuse at the point of origin. Based on that, a 25mm SWA will more than suffice. I wouldn't get too hung up on having a 100a supply, as an 80a supply will give you more than enough 'juice' for a typical residential dwelling.
  6. That also sounds like an elegant solution....................
  7. Thanks for the heads up....Neil Scotland ?
  8. Look for a fused spur inside the house maybe on the outside wall near / next to a socket. That’s a popular way to glean power for out buildings.
  9. Ok, one issue at a time First off, you cannot connect the lights directly to the 2.5mm cable if that is fed by a breaker bigger than 6a ( or 10a ) which a 2.5mm cable normally is fed by. So, the supply cable needs to be identified, as does the size of the circuit breaker servicing it before any comprehensive advice can be given here. If it turns out to be from a 6a circuit breaker then great, carry on as advised, but if not then you'll have to install a DP switched fused spur and fit that with a 3a or a 5a fuse accordingly to de-rate the incoming supply. Can you add that info first, please ?
  10. You need to know what the room requires in terms of heat input ( to maintain 20oC internal at 0oC outside temp ) before deciding on UFH, especially retro-fit options. There are a few online room heat calculators out there, so I'd say use 2 or 3 different models to get an average, and then work out total useful floor area / w/m2 and you'll have your answer. LVT is a good option because it makes the floor feel naturally comfortable under bear feet / in socks vs tiles, but it is a very poor diffuser / emitter and will allow the floor to have 'hot-spots', eg areas where you will actually be able to tell where the pipes are laying due to the elevated flow temperatures that you will require vs tiles. Are you dead set on LVT? That will work but tiles would help out quite a bit here and be far better at diffusing and emitting the heat evenly and allow for a slightly lower flow temp.
  11. I’ve not seen much great about Nu-heat and have had to sort a few ( too many ) of their poor designs out. I’d look at Wunda Overlay as an alternative. Not great heat transfer characteristics with vinyl flooring either. With the Nu-heat system, do the panels get over boarded before laying LVT? Make sure you cost in for the spray adhesive that is required to bond the boards to the substrate, and the required prep work for the substrate too.
  12. Aye, Dennis is a top guy. Just tell him I said to lay off the custard donuts and watch him go!!
  13. Depends if the substrates are nice and flat? Whichever you lay the notched bed onto, the opposing face should be buttered, eg to have a thin wet skim of adhesive applied immediately prior to affixing the tile. Powder adhesive in a shower area is a no brainer, and most tub adhesive is shite on a good day, especially with zero-porosity porcelain. Get the standard or extended set adhesive and NOT rapid set. That way you'll have at least an hour open time with a bucket of goop before having to clean down and do a fresh mix.
  14. Words are like weapons...they wound some times.
  15. Facebook marketplace and Gumtree, under "grab what you want, it's free" and hope for the best. Usually causes delays, costs and inconvenience. Put the staircase on market place here on BH and see if anyone is building near you and could do with a temporary 'site' set
  16. So, can I have 50% off my first order of N'evian?
  17. And what can reassure you is, the FACT that I have done many like this, and its all good. Same with anything, the job will be as good as the execution and attention to detail. If that slides, so will the things you put on the floor. Very much relies on the builder having more brain cells than a house plant.
  18. "Peckham spring" ? LOL.
  19. Crazy. You don't need more than 32mm with a cuffing sprinkler system !! The last time I specified 50mm was where there were 3x 400L cold mains accumulators and a pump in a garage, and we needed to feed the house, and I needed a bigger pipe to retain the stored energy potential from the accumulators without hinderance. That's 'hooj'.....
  20. An academic approach is fine, but my approach is of being on sites over the last 25 years and seeing these in, working, still working today, and all the ones that failed, and why. That comment of your suspicions is loosely scaremongering and without evidence also, ( IMPO ). PIR does not crush with a raft of screed over the top, as there is virtually zero distinguishable point loading. Order of events is usually; whack and blind ( with sharp stone ) the sub floor until compacted and level fit a secondary DPM atop the blinding layer install 25mm EPS as a sacrificial layer, employed to absorb any remaining points / adverse undulations / cheeky bit of hardcore that sneaked through when you were having tea and biscuits fit the primary DPM atop the 25mm of EPS, ergo it is safe from being penetrated from said foreign items in the subfloor carry on building the EPS layer up to 100mm or whatever in thin layers so it conforms fit final PIR layer(s) as required fit perimeter expansion skirting / insulation install screed / concrete / other to suit The weight of the screed going down will hold all the insulation layers against each other, and is essentially the worst case for compression in the lifespan of the floor. It will sit there quite happily...........................unless someone buys a grand piano, sticks it in the corner of the room, and then invites the Tomi-Tukamoto Sumo-wrestling team, and their family, from both sides, to sit on it.
  21. Looks like the type of junction boxes associated with a burglar alarm. Maybe where PIR's have been removed because previous occupants had pets etc. Is there an alarm there now?
  22. Probably the same price as a clip rail system to hold the UFH pipes, so that box ticked plus a lot of insurance. As prescribed. Also, from my limited knowledge of slabs and concrete, IIRC you need a minimum of 40mm cementitious coverage over bright steel to stop atmospheric moisture from penetrating the screed / slab and allowing the steel to start corroding. Maybe galv or stainless is employed in those circumstances, but i'm not 100% sure. Got a load of floors made up this way that have been in for north of a decade, and I've had the same phone number for longer Not a dicky bird
  23. Experience you mean?
  24. Doesn't matter, as it will make an excellent raft to sit the rest of the floor on. It's been in long enough to have settled, and will be fine to take the non point-load of a new upper deck. What's it like when you walk slowly over it? Any movement in the corners?
