Merry crimbo folks 🍻🎅🏻🏴👍
If DIY then a lot here have used Midsummer iirc, but ‘we’ install Solarwatt mostly. Turnkey only, so no “supply only” I’m afraid.
Clients get told to do their OWN research, and to instruct us to crack on, or not. 👑 👆👎👌
Heat demand too low for Vaillant Heat pump?
Nickfromwales replied to Ewan's topic in Air Source Heat Pumps (ASHP)
Variable resistance created by an automatic bypass ( sprung ), installed immediately prior to the manifold rails across, flow and return, which closes as the resistance downstream becomes lesser, and vice versa. General health and safety foremost, and yes, flooring manufacturers stipulate max temps before certain types of flooring get damaged / adhesives begin to reconstitute etc. -
I’m not a fan of an install without local pumps and blenders ( thermostatic mixing valves ) at the manifolds tbh, as without them you have to accurately control the flow temps and guarantee that they’ll never exceed 27°C, plus that type of setup also attracts expensive digital ( electromechanical ) mixers and PWM pump sets / CPU etc etc. Overly complex imho. Driving directly into the manifold rails also doesn’t allow for dynamic bypass, so you can’t really do this without PWM pump control tbh. That’s the exact same LLH I fitted for a recent client and it does the job perfectly. Primary pump in the HP circulates back on itself unhindered, and the UFH manifold pump ( immediately adjacent ) sucks whatever heat it needs as loads vary. -
If the heat load is as low as stated, bloody good for a retrofit ( EnerPHit? ) his sounds like a candidate for a low loss header or very small wall mounted 2-pipe buffer with a constantly open bypass at the manifold. The manifold pump will happily ‘suck’ whatever heat it needs as and when so you’ll probably be fine with the LLH. If you go LLH then you’ll likely need a pump between it and the manifold, but if you go 2 port buffer you can just pump straight through it to the manifold from the pump in the HP. Doubt you need to complicated this much at all, just needs the water from the HP to be free running back on itself to smooth out demand vs relying solely on the value / temp of the return from the loop(s). -
Put them on, see if anyone cares. Unless your neighbours hate you or it is obvious from the roadside then I’d say you’ll be fine.
Well, ‘we’ve’ got a few in without complaint or interest, and they are bigger than 9m2. Lucky for me I’m in Wales, and not many people care about much more than the price of beer down here. I shall proceed as planned ( or not planned lol ). “Death before dishonour”.
Nope. Not considered ground mount unless it is literally, on the deck. 👌👍 Fill your boots basically.
Array was 6m x 3.7m. Panels were 990x1780 ish, 360w iirc. Slept a few times since knocking that up in one of my ( very kind ) clients living room lol.
I made just this type of structure for my colleague as a mobile demonstrator. Joins up the thinking, between outbuildings / structures satellite to the main residence and grabbing a cheeky extra few m2 of solar revenue. It has a sniff over 4.3kWp on the roof. Loads of interest when we put this up at Bicester, and a few strange looks when I simply stated that wood has been around for a “few centuries” and solar panels a few decades……….just screwed one to t’other lol. Some random woman asked “what time is the car being raffled off?” Doubt that the BMW garage who loaned us the car would have been too chuffed with that lol. I’m ( before I die hopefully ) putting 18 panels at the top of my garden ( East facing ) and another 12 on my ( re-roofed to comply ) gazebo for West. Both elevations get smothered morning and afternoon so fingers crossed, and I should get good returns from both.
Indeed, and close to my thoughts tbh. With those numbers I'd happily throw the money at it, not just to have self-sustainability but to also shove 2 fat fingers up, directly into the face of the grid. I'm thinking longer term of complementing this type of capacity ( 48kWh of battery for the get-go ) with a water-cooled self-start genny which I can bury underground, running on LPG. The waste heat from running the genny ( inevitable in winter vs pulling from grid ) would be directed to a big TS and then used as a pre-heat to space heating. I'd retain the gas combi, but convert to LPG for the times where I need high grade heat. No matter who turns what off, or when, I will be warm and well lit. After a couple of years of measuring reliance, I would then look to yanking the meters and going fully off-grid.
Is everyone factoring in the ( replacement ) cost over useful lifespan of the battery system?
I think the black vessel is the expansion for the DHW ( domestic hot water ) coil inside the thermal store. If all taps are closed and you heat that from cold, the water held within the DHW coil needs to expand somewhere, and that is where it goes. Very difficult to comment without seeing where every pipe goes to / from in detail of course. I think the same. The static head ( gravity pressure ) is displayed on the gauges and then that value rises when the pumps force water into the manifold rails. As there are differing values of resistance, with x number of actuators open / closed, those values will be variable but will reflect the pump creating pressure between itself and the available runoff into the loops of UFH. Rolling back down to zero / near zero says this is indeed likely to be a gravity based heating system vs sealed and pressurised. I assume you have not had to top up via a filling loop and have a gauge and ( typically ) red heating expansion vessel ( as Dave asks )? A sealed and pressurised system kit would look like this ( LINK ) so if this is not present you are on gravity, also if you've been venting a lot you would have run out of stored pressure by now and would have had to 'top-up' via the flexible silver hose ( as seen in the image ) so this further reinforces the gravity assumption here. The big blue rocket is a cold mains accumulator ( a 1/2" thick rubber balloon inside a pressurised can which the borehole pump 'inflates' each time it runs. This prevents erratic unmanageable water delivery to the taps etc and smooths things out. It also prevents the pump kicking in frequently for small take-offs of water, thus extending the longevity of the borehole pump. Air in the system is a killer of UFH as the flow rates around the loops are sub 5l/p/m, so they are just not flowing fast enough to 'blow' the air out by the force of circulation. I would recommend getting these all purged properly, and having the automatic air vents replaced without hesitation. The items circled in yellow here; These automatic air vents simply unscrew from a 1/2" BSP thread and can be bought from most local plumbers merchants, albeit they will likely come in brass then and not chrome. The ones you have may well have a black rubber o-ring for hand tight installation so you may want to order the same again, or the brass ones will work with a few turns of PTFE tape on them. Here's a link to suitable replacements if you want to order online ( LINK ) vs the "buy local and PTFE them" option This fix will allow the air to be expelled without you constantly monitoring / babysitting them, and work automatically to release the air whenever it presents itself. Without these functioning properly it is likely you are missing air which then gets sent back around the loops, infinitely. The purging I refer to above is carried out thus; ( this is based on the manifold being on the 1st floor and the ground floor loops being 'below' it? If this is on the ground floor and there are loops above it, you will need to tackle this differently ). Turn off the red and blue manifold isolation valves after the pumps to isolate the manifolds and loops of pipe. Remove the old ( knackered ) air vents, catching a couple of litres of water with some old towels. With the air vents all removed, using the empty port for access, you use a 1/2" connector to link a hose running to a drain to the lower manifold rail. You connect another hose from the outside tap to the other manifold rail ( or if cold mains water is available locally within the plumbing tap into that ) likewise. You then remove one actuator and open the outside tap. Cold mains water will then blast through the one loop, and out to the drain, taking any air / crud with it. Once satisfied this is running freely without spluts of air, you refit the actuator and move to the next actuator, and repeat the purge cycle for each loop, one at a time. Keep going until all loops are purged on both manifolds, then remove the hoses / connectors and fit the new air vents in their place. Open the blue vales slowly to allow air in the manifolds ( not loops ) to rise to the air vent at the higher manifold rail and then reopen the red valve. Remember that the thumb cap on top of the new vents stays OPEN, and do NOT shut them after installing them. These are designed to be left open for life, so venting air in your absence. Maybe get a plumber out and offer to assist with this process if you are not confident with this. Start there, and I think you'll be back running smoothly in no time, or we will soon know the next fault! Enjoy.
Anyone got a FLIR camera....
Nickfromwales replied to NSS's topic in General Self Build & DIY Discussion
I'm doing around £7-£8 a day in a leaky granite cave in Wales. That cost vs result is disgraceful, but not at all a shock to hear. These mass-building cocks are the worst of the worst as a lot of their victims are first time buyers who know no different. I'm looking to purchase a FLIR camera ( decent one ) if anyone's got one for sale. PM if so please. -
It would be fine, but a little OTT IMHO. Do you mean moisture-resistant not water-resistant? If so, then green PB would more than suffice; which I use in wet room showers with a layer of tanking solution on top of to create water-resistant shower cubicles ( on 1st floors as well as ground floors ) without issue.
I quite like this tbh, but indeed it's "bespoke" to the extreme. I would have said a bigger UVC would have been advantageous, but you state no issues ( running out of DHW I assume? ) to date, so if the shoe fits....it seems to be a beautiful mistake in fairness!!
Ventilation in insulated outdoor office / shed
Nickfromwales replied to pstunt's topic in Ventilation
Just use a fan heater then, also, for instant heat when needed. No wait time, just got air there and then. 👍 -
They over-ventilate in such a small single space. https://www.preservationshop.co.uk/product/vent-axia-piv-lo-carbon-pozidry-compact-pro-with-heater-479188/?gclid=Cj0KCQiA14WdBhD8ARIsANao07iFhNCXUdn03SlialqG7Ml6wfv2Ngh9XKrFsq4b2ImAj5cqrhzg9n4aAtVrEALw_wcB -
Yup, flux residue ( likely they used PowerFlux or Laco ) from acidic "self-cleaning" fluxes. The others are leaks which look to have sealed themselves as @Kelvin said. Clean all these joints up so you can be sure they've cured, but this is typically what you see under a combi boiler where it's leaked a little but then sealed itself up, eg very minor weeping joints.
Connecting soil stack to the existing sewer
Nickfromwales replied to pilgrim's topic in Waste & Sewerage
Happy days. -
Nope. As per the man above, a rising 110mm for every item, but you can connect to the foul at the WC for the basin as you’re allowed a change of direction if it’s not foul / solids. Prob easier to connect to one incoming underground pipe vs bringing 2 in to the same IC. It’s just a basin so very little duty and clear running water.
