Nickfromwales
    330
  1. Are you considering solar PV instead of solar thermal? I've been in the heating and hot water industry for over 3 decades, and if I was given a solar thermal system for free, and could fit it myself, I'd sell it to someone and use the money to buy solar PV. Your hot water use is low, but you're electricity costs are going north, so I would, personally, go with PV here and save yourself a lot of money long-term. Excess solar PV in summer will give you free hot water via the immersion, so your gas consumption in winter will be off-set by how "energy rich" the solar PV makes you in the 'sunny times' of the year. If you go with PV, I would go with the bigger cylinder, but if you're sticking with gas then 180L should be the biggest you need.
  2. The upper edge of a standard UK basin rim is 820-830mm from FFL. A kitchen worktop surface is around 900-915mm off FFL. A counter-top for a 150mm deep sit-on basin "bowl" should be no more than 700mm from FFL afaic?
  3. A google search of images of these seems to show the spout outlet at around 150mm off the top of the bowl, so if you're referring to the height of the centre of the spout before the spout turns downwards, then I'd say you're about right.
  4. You can go for a dual string inverter and put E in one input and W in the other, without optimising, as long as there’s zero shading.
  5. I'm going E/W split for the majority of mine, with prob 30-40% of the array(s) getting true S sunshine ( irradiance ). Should give me a long steady solar day. I've decided on an E/W 25 degree apex for the pergola / shed at the top of my garden, with 10x400w E and 10x 400w W, plus then around 12 panels S-ish on my gazebo roof. Should see up to 4kW from E, then up to 4kW S then up to 6kW late afternoon to evening. Btteries are going in from the get-go, and just about to order them, plus a chunky hybrid inverter. Eventually I'll put another 10 on the E roof and another 10 on the W roof, and aim to provide a lot of space heating from A2A during the winter. 🤞 A machine plus driver will get the job done very quickly without damage. It also needs some thought as to spoil and residual useable manoeuvring spaces which is gained by experience only. Liability resides with them then also. You may have to get separate insurance for the machine also. Check it all out properly first
  6. Can you get this to 15 or 20? Would make a huge difference and also then the panels would be deemed "self-cleaning". Below 12 and you typically have to mechanically clean these periodically, then they're not 'maintenance free'.
  7. Run the 10mm W/C hot from the 22mm pipe All good otherwise.
  8. You got that bit right. There's a reason they don't engage with the public any more Some people buy a dog so it can do the barking, and sometimes, people who don't want to enter the ring anymore, buy one to do the fighting..
  9. The correct procedure is to use the existing manufacture fittings to convert to copper tails, and then push Hep2o onto the copper. The copper divorces the different manufacturers.
  10. It never went public, therefore you made an assumption
  11. NOPE! Off the 'net; The new Thermino range contains a new and improved Plentigrade P58 phase change material (PCM) They did a PCM34 and then a PCM43 ( I was part of an 11 strong group to spearhead the design and implementation of this unit ) but they must not have pursued this as above. The lower temp units would have been way more reliable tbh, as the failure of the rest of these ( 58's ) has all been attributed to the immersion overheating ( and destroying ) the PCM. To 'melt' the PCM58 you actually need to heat the SA with much hotter water or it takes an inordinately long time to phase-change. I routinely set wet heat to go into these at 65oC which seemed to work quite well. The units with immersions were ( are? ) still prone to issues with spewing the overheated PCM out through the PRV. I've got a dedicated photo album of these gone 'pop', some where it was so violent that the nuts sheared off the lids as they bent upwards. By comparison, I have been to 2 failed UVC's in my 30 years on the tools, and both were either installer error or where the client had neglected to service / maintain the installation, so basically a near zero fail-rate for UVC's. I'm not a fan of the Mixergy tanks, sorry, just way too much faff / external components / flow switches / pumps and the associated heat losses from all the stuff mounted externally. A simple UVC wins the day, just get a low-slung secondary immersion installed and then you can use 100% of the low / sporadic / proportional energy from PV diversion control.
  12. Yup. I'm just tired now from writing their name and the word fcuked in the same sentence tbh. Apparently, the boneyard at their HQ is "considerable". The architect is a buffoon. Still a buffoon. Because :- How the feck can you vent stone cold air into the room that you are 100% reliant for to glean input heat from??? FFS?!? The guy is one brain cell up from a turnip. He's just invented "perpetual electric bill". Je-sus.
  13. Yup. Go flush yourself!
  14. A heat battery supplier I am familiar with is suffering multiples of failures of their, now eye-wateringly expensive, units. I've received pictures from two clients since xmas who have had failures with their units and damage done to their property. One is "not on his first replacement unit"... A Telford / other unvented cylinder is cheap, simple and very reliable, and all of these will "work with Octopus" Contact Trevor at cylinders2go and mention my username and the forum and he will look after you on a price for a cylinder. If you wish to charge this with cheap energy in a short window, you can ask Trevor to fit multiple immersion heaters into this so you can heat it very quickly ( to match half-hour pockets of cheap rate electricity etc ) so can all be done with one unit, very simply, and very reliably. Reliability is the key here, as the heat batteries are, unfortunately, dropping like flies ( from the feedback that I'm receiving.anyways! ).
  15. Outstanding mate. Restores faith in humanity, when people jump in and help someone in need.
  16. Yup, +1. How old are they, and are they convectors?
  17. Is there any mention of a crane, or just heavy vehicular traffic?
  18. Simple option is to go for an insulated raft, with 300mm of EPS 100 under it and a 120mm reinforced slab with tied A142 mesh. If the ground is that hard, a raft is a no brainer. It'll make for a much nicer working space ( slab won't be ice-cold ) and you could ( I never said this, right ) install UFH i it, zoned for the working space, and for the "office" area accordingly. You will, never again, mention the word "office", or document anywhere this repurpose of that internal space, it if it coms to fruition, so we bear no guilt in telling you to strap a manifold and ASHP to the slab and heat the "office" and "workshop" as you then please. I know I would, without a second glance. Or, just be happy that the "office" has an insulated floor, and retro-fit A2A AC ( for heat & cool ). If you want to work on tractors in the depths of winter, you'll thank me for the above.
  19. The weight will be a huge problem. Most floating shelves are hollow, with strategic timber ( usually ply or pine ) inserts to accept the fixings. The reason for the thickness is that the brackets usually feature a dowel of 16-18mm, or thicker dependant on projection, so need a depth of thickness / cavity to allow these to be integrated. Move away from MDF, as it's not the right product for this instance Where are these to be located? What purpose? How heavy the loads?
  20. Gentlemen, you are reading above and below the lines. One of my neighbours ( immediate as were semi-detached ) are the nicest people that I dare you to attempt to ever find replacements for. The "new" wife of my also outstanding next door neighbour, of 16+ years, is a complete and utter, acidic, erosive and outright minge. A walking and talking bitch of an order of magnitude that I've yet to witness, anywhere, at any level. I have had to make 'more than one' police ( attendance level ) complaints against. She is now bound over for 2 years, eg to keep the peace, and the fcuk away from me and mine. If she were male, the police would have been coming for me instead. So; ...this, I do. My only respite is that she drinks excessively, from lunchtime until "floor-o'clock", and has 20 years on me. So, ( in theory ) I can look onwards with hope that I will live long enough to go piss on her grave. Some people do not embrace, or deserve, the gift of life, vs those who sadly lose theirs in untimely circumstances. Can we talk about something else now? This is getting to me.
  21. All I hear of is neighbours being assholes, happens lots of times, sadly. Green-eyed monsters or just utterly miserable bastards each one of them. For some, death is a convenient end, but, ultimately, the only end that would ever be arrived at for peace to be restored. These think that perpetuating misery as a pastime is acceptable. What’s wrong with just getting along?
  22. Correct. In the summer your heating will all be in the summer / off position, so I don’t get why your system would come on, to heat anything? Summer sees the ASHP > UVC directly, and the buffer remains isolated and dedicated to the heating primary circuit only.
