Temp
    43
Everything posted by Temp
  1. I don't think it can be that as he says the flow indicator suggests there is flow.
  2. Clever marketing I'm afraid. The "channels" are just wires inside the wiring centre. They go from clock inputs to the connectors for the room stats. No timer inside. Some people will have one time clock connected to the wiring centre so they would connect all stats to the ?1 pin. Others want upstairs and downstairs to be controlled by different clocks so the upstairs stats might be connected to the ?1 pin and downstairs to the ?2 pin. If you have fully programmable room stats with built in timers (like me) or a HA system you just ignore those clock terminals and connect the stats/Fibaro to L&N.
  3. It looks virtually identical to my Heatmiser wiring centre and isn't complicated. Nothing in it to program or override. For example the timer stuff mentioned in the manual needs a separate time clock that does all that stuff. If you don't have that timer the wiring Centre itself is basically just a big OR gate to control the pump.
  4. I can only think of two reasons.. 1) Its got a bad insulation problem (no insulation under the UFH) 2) the water flowing in those loops isn't going to the room you think it is. If you don't mind being cold for awhile I'd try an experiment. Before you go to bed turn down all the stats so all rooms are off. Let house get cold over night. First thing turn up the stat for just that room. Check flow and pipe temperatures on that loop warm up (and that no others do). Wait 1-2 hours. Then see if you can detect any change in floor temperature in that room. If not go looking to see if the floors in any other rooms are showing evidence of warming up. Thats what makes me think the loops dont go to the rooms you think.
  5. Ok if the room temperature will be monitored by a separate HA wireless device I don't see the problem its as you said..
  6. Occurs to me that for the above to be possible you may need more wires to the room stat than planned. L & N to power the stat then wires 2) and 3) above. That's a 4 core and earth rather than a three core and earth.
  7. Ok so I've had a look at the Fibaro manual here.. https://manuals.fibaro.com/content/manuals/en/FGS-2x4/FGS-2x4-T-EN-1.0.pdf It has two relay outputs (Q1 and Q2) but the other relay terminals inputs appear to be connected together internally to the IN terminal. That makes it slightly more difficult to use both channels but not impossible. I think it would be necessary to use Room Thermostats that have volt free relay contacts (eg not the stat shown on the Heatmiser wiring diagram you posted as that only has a switched live output). Firstly I would power both the Fibaro and the room stat from the wiring centre L & N. The control signal path I would wire up as follows. The basic logic pathway would be... Live > Fibaro > Room Stat > Wiring Centre > Actuator Wiring would be.. 1) L on Wiring Centre ------> Fibaro IN (Can be a jumper/link at the Fibrao) 2) Fibaro Q1 output -------> Stat 1 Relay Input 3) Stat 1 Relay Output ------> Switched Live 1 on WC Then for the other channel just need 4) Fibaro Q2 output -------> Stat 2 Relay Input 5) Stat 2 Relay Output ------> Switched Live 2 on WC In operation this would mean that the UFH Loop actuator would only be enabled when both the Fibaro AND the room stat call for heat. I assume you would never want the Fibaro to over rule the room stat and call for heat when room stat was already satisfied. The opposite is possible (eg Fibaro turn off heat when stat isn't satisfied).
  8. Deleted my reply as I'm gong to have to read the figaro manual.
  9. Grant say the return temperature should be less than 55C (and over 40C). https://www.grantuk.com/media/1294/vortex-outdoor-modules-installation-and-servicing-manual-doc52-rev00-october-2004.pdf
  10. Also noticed this.. https://www.gov.uk/guidance/vat-and-overseas-goods-sold-directly-to-customers-in-great-britain-from-1-january-2021 Quote: "Low value consignment relief (LVCR), which is an import VAT exemption for goods valued at £15 or less, has been removed.." Paying a bit of VAT isn't a big deal as long as the post office don't charge a £9.99 fee to process it. Edit: Sorry its £8.. https://personal.help.royalmail.com/app/answers/detail/a_id/7208/~/help-with-paying-customs-fees So that 10p washer ordered from ebay and sent from China could end up being £8.12p.
  11. Here you go.. https://www.gov.uk/guidance/vat-and-overseas-goods-sold-directly-to-customers-in-great-britain-from-1-january-2021 The break point is £135.
  12. I last looked at this some time ago so I might be wrong now or out of date.. As I recall the process and VAT treatment is different depending on the order value. For small orders I believe they are meant to register with HMRC, charge UK VAT and remit this to HMRC. For larger orders I think they they are meant to ship it VAT free (no EU or UK VAT) as you will be charged UK VAT on arrival at a port of entry. Someone will call telling you how much VAT to pay and what their handling fee is. In other cases the post man put a note in your post box with a demand for the VAT. This is meant to happen already for orders from ourside the EU (China for example). I can't remember where the break point is but think its in the £50 to £150 range. My guess is some small companies may not bother to make changes for the UK market. They may just continue to quote "inc EU VAT" prices to everyone that visits their web site. If you pay that beware you might have to pay UK VAT as well.
  13. I was just thinking on similar lines... Those two don't quite match. You have the membrane above the counter batten. One reason for the counter batten can be to form a gap between membrane and batten so that any water that does get past the tiles can run down to the gutter and not pool above the battens. Its important on a roof with wooden battens because without it the membrane can be pressed against the batten. Pollen and other sources of dirt can collect above the batten and form a gunk/slime that seals any tiny gap that might exist. Eventually the timber batten can rot. Not an issue with metal battens? The way the tiles are lapped they depend on the interlock between adjacent tiles to be water tight. I also wonder if on one or two tiles the interlock broke without apparent damage to the tile.
  14. I assume you replaced the tile with broken corner in second photo?
  15. Yeah its mostly dangerous stuff but its the only list I can find. So far sausages are the only thing I've seen we can't export to the EU. I recon it in retaliation for.. https://youtu.be/OzeDZtx3wUw?t=90
  16. Have seen mention that the deal doesn't cover all goods. Apparently there are some things we can no longer sell to the EU. No idea if there are things that they can't sell us. Edit: Found a list here.. https://www.gov.uk/guidance/list-of-goods-imported-into-great-britain-from-the-eu-that-are-controlled One thing that might be relevant is this section.. Presumably that's mostly raw materials not things like aluminium windows.
  17. I think the recommended depth is 600mm with 450mm minimum. That's about how deep our swa cables are. Can be shallower if protected. Should be a marker tape above it but don't think ours has. No gravel either.
  18. £ is down a bit over the past year..
  19. I would also go with SWA direct in the ground. You can leave a loop where you think you need a light. Then use either a potted junction in the ground or post mounted box. If you use duct I wouldn't use T joints. I'd just bring the ends of the duct up like this.. UUUU
  20. We have a Clearview Solution 400. Can't say I've noticed any noise as the burning wood makes quite a racket while its warming up. What I love about the Clearview is the way you can slow it down to produce nice lazy flames. Not having to clean the glass so frequently is also nice. Our other stove is a pain as the glass get obscured in a day.
  21. The Brexit deal means there won't be tariffs on imports from the EU but the VAT rules are still changing. This will effect you if you buy direct from an EU based company rather than through a UK based agent. Currently you can reclaim VAT paid in an EU country but I doubt that will continue. You should/will probably pay UK VAT on arrival at a UK port and reclaim that. I doubt this will affect many people though. Some buying from German suppliers on ebay might get caught out and have to pay UK VAT.
  22. If feeling rich.. Both Swadling and Perrin & Rowe make premium price and quality mixer valves. Massive lumps of machined brass.
  23. I've spent about 3 hours trying to work out how to replace a belt on my mower. It appears to be topologically impossible. There are rods for the accelerator and brake that go through the belt and neither rod can easily be disconnected at either end. So in effect you have two interlocked rings. I'm sure Tommy Cooper could get them apart and back together but its defeated me. Today I cut the rods and will sleeve and weld them back together after fitting a new belt.
  24. Welcome to the forum. The self build reclaim scheme is intended only for people building a house to live in so selling the 4th house could be problematic for the vat reclaim. Try and find a relative to build it for? There is no minimum period they must live there (apart from the CIL exemption requirement of three years but I'm guessing there is no CIL in your area), however HMRC may look for evidence of their "intention" if they decide to check.. If you can't do that you may have to subtract 25% from your reclaim for the 4th house. There is also an issue that prevents developers reclaiming VAT if the first use is a long let. Pretty sure self builders are precluded from using the self build reclaim scheme for a build to let. I believe its possible to use the scheme to reclaim VAT on a house built for a relative but I don't think I've seen it written down anywhere. You would need to explain why the invoices are in four different names. As you are new to the forum I should check you know that the reclaim only applies to vat paid on materials. Services/labor must be zero rated to you, meaning there is no vat to reclaim on services.
  25. https://amp.theguardian.com/politics/2020/dec/24/from-tariffs-to-visas-heres-whats-in-the-brexit-deal Very confusing because some "UK flagged vessels" are european owned and landed fish in Holland.
