ragg987
Everything posted by ragg987
Nope - MVHR. Every modern low energy build should have one. Though if you are very sensitive to noise you may wish to add an inline noise attenuator in the ducting. Whatever takes your fancy Movement sensor activated lighting in circulation areas and bathrooms, together with low-level dim lights will take care of these and improve your safety. We used fire doors on all internal doors. Just be aware you will require a gap under the door for MVHR so some noise leakage is inevitable, in our house the only obtrusive noise is the shower. Cistern is in-wall and quiet, bath fills down the bath wall so no splashing noise. If you woke early and wanted a shower you could always use another one? I guess I am suggesting that an ensuite is a bonus, especially if you are moving away from the traditional 3-bed-semi approach. Modern buyers tend to expect this, so it may have an impact when you come to sell. I have seen this mentioned somewhere before, and I guess if you are tight on space or money and need to make choices then reducing number of bathrooms is one way to increase space in bedrooms or cut the build cost. But if you have the space and money then why not - don't get it.
Ensuite does not equate to bathroom noises steam and smells. Keeping the door shut and having a MVHR extract in the bathroom will take care of both aspects. Having a humidity sensor in the bathroom to boost the fan speed helps too. Other factors for ensuite are probably more important, e.g. number of bedrooms, occupants and number of bathrooms and toilets they will have access to.
This is the case for us. Our open plan south and West facing kitchen lounge diner suffers a lot, 2 small North facing rooms are fine. Does not have to be active cooling, an option would be to take advantage of cooler air at night by leaving windows open then shutting them in the day and let the MVHR do is thing. But when external temps gets to upper 20s we resort to floor cooling.
Where would you put one sqm of extra space?
ragg987 replied to Ferdinand's topic in New House & Self Build Design
Kitchen storage. I thought I had catered for enough, but now bursting at the seams. -
I have a split system. The indoor unit is not noisy, essentially it is the noise of a circulation pump. Agree his comment re antifreeze, this is required as your water flow goes outside. And the refrigerant of a split system does require a qualified fitter, but in my case this was cheaper than antifreeze.
Using their manifolds and pipe, 3 years in all is fine. I hve no experience with other brands. I also use a heatmiser stat, but only to control the upstairs direct electric MVHR heater. Works OK, not intuitive and require a lot of button pressing to do anything. What is your context for heating? If ASHP then I suggest you use the same brand controllers as likely you can control aspects like heating / cooling and proportional control through that rather than a more crude on and off type of control using an external stat.
Arrrgh can't make my mind up!
ragg987 replied to gc100's topic in General Self Build & DIY Discussion
I would check on where the margins are going to lie. E.g. if company A is your contracting company and they want 20% margin, they sub to company B who also want 20% then you are paying a big premium. -
Oh and one other aspect is what sort of relationship you think you might have with either. You need to be able to trust and be in for the haul, e.g. when the inevitable snags appear will they still be interested or available? -
I went the bill&Bob route with my build, except it was a one man band with a bunch of subbies. If I were to do it again this would remain a good option, however I needed (and wanted) to be quite involved to the extent that I brought in other specialist trades outsider my builders network. This seems like a classic 3 cornered triangle of cost, speed, quality. If this is your long term home and you are prepared to be pretty involved I would suggest bill&Bob is going to give you the best outcome. Some considerations from my experience: 1. Specialist Vs generalist. The specialist trades will complete the job faster, better and to better quality. If you can contract these in as needed that might be a useful supplement to the team. E.g. plumbers, plasterer, tiler, timber frame. 2. Whilst builders might be able to get better prices for materials, don't assume they will pass on the benefit to you. A bit of googling and ringing around will usually get you a better price. 3. While you are factoring rent, don't forget cost of any finance. A longer build time will increase the interest period. -
Advice on Choosing Material - AluClad / Timber / uPVC?
ragg987 replied to soapstar's topic in Windows & Glazing
Do make sure you see samples of this. I have no personal experience, but have seen many replacement windows in houses and the fake timber can be spotted easily from the street, looks nasty IMO. -
It looks like you are overflowing at the end of the run - where the downpipe is. Suggests either that the gutter slope is too high so water is rushing down it, or perhaps the hole in the gutter connecting to downpipe is too small or obstructed. You gutter supplier should have some documentation on slope as well as number of downpipes for the area of roof. If the single downpipe is not adequate then you might have to use a larger diameter pipe - slowing / diverting water on roof or deeper gutters will not solve it, only delay it.
Slimline units for loft
ragg987 replied to Wagas's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Not used, but some of the commercial units are quite slim and are designed to fit in a ceiling void. https://www.bpcventilation.com/heat-recovery/commercial-heat-recovery -
Fan Coil Units for use with a (cooling) ASHP
ragg987 replied to ProDave's topic in Air Source Heat Pumps (ASHP)
That example is 2.65kW not kWh. Google translate calls it "thermal power". Mighty have to think about retro fitting one of those for bedroom supply if these hot days keep happening. Should be a simple take off our buffer tank which is supplied by the ASHP. -
So somewhere between 1 and 5kW of cooling available depending on incoming air temperature and flow. Seems usable? -
Anyone tried one of these? I doubt they will deliver enough cold air to make a huge impact, but should drop the temperature to something more comfortable. https://www.bpcventilation.com/cold-water-duct-cooler-range -
Small ASHPs / Units primarily for DHW
ragg987 replied to Conor's topic in Air Source Heat Pumps (ASHP)
Yes, but not abnormally so for a PH standard build, and you still need to provide heat input else your room temperature will drop. As long as you have allowed for that you should be fine. Ufh in bathrooms will not redistribute the heat to the rest of the house in any meaningful way. 2.7kW X 24hrs is over 60kWh, costing £9 per day of direct electric heating. Yes this is on a cold day and will be less on average during the heating periods, but are you also heating water with electric direct? You have 2 options, direct electric heating or gas boiler / ASHP. Low capital + high running costs vs. high capital + low running costs. If direct electric you can save money by omitting the ufh and fitting electric emitters or heating element in mvhr. You have to do the maths, I'm afraid, and decide based on your priority. -
I have a separate electric meter on the incoming supply to the heating system, and the ASHP reports output energy (which seems to be a calculation inside the firmware based on water flow and temperature delta, according to my read of the manual). Some observations: in reality this is not COP, more a energy-out vs energy-in energy-in measures whole system - circulators, thermostats, valves as well as ASHP I noticed that the ASHP consumes about 50W even when everything is off it cannot measure instantaneous COP - only average over a period
We get 4 on average, mixed DHW (to 50C) and space heating (auto-adapts between 23C and 30C using built-in weather compensation).
We heat our DHW to 50C using ASHP. Our average COP (DHW and space heating) is around 4. I don't bother with electrical heating to 60C, the immersun will divert solar PV to provide a boost. Admittedly it means we hit over 60C in spring, summer, autumn but may not in winter. -
I may be misunderstanding this - are you saying that the rest of the floorspace (apart from your wetrooms) will have no UFH? How are you going to heat the house? Your PHPP shows you still need the ability to input 2.7kW of heat (11W/m2 x 242m2). And do check your assumptions about primary demand being DHW. That may well be the case in warmer months, but in winter your primary demand may be space heating. The problem with average values is you miss the reality. I would keep it simple and get an ASHP for both DHW and space heating (with UFH - helps with floor cooling too). Minimise your capital spend as your fuel costs are going to be relatively small, so a small saving on a relatively small cost is easily swallowed up by excessive capital (read complex) installation. -
If we take a summer night temperature to be 10 to 15C (about 5kWh) and summer daytime to be 25C, then this represents a 25% saving. Not insignificant. Depends on your objective. E7 may well be cheaper but you are burning more fuel, and potentially emitting more CO2.
Why bother, to much time on your hands?
I suspect that the capital costs of your second option will be lower, both materials and services. Running costs are likely to be similar, but one advantage of Combi is no heat loss at the dhw tank. If you are happy with the limitations of a Combi, that is probably the way forward today. But in 10 years? With the government intervening on new build I think it is only a matter off time before gas costs escalate faster than electric. My view is that ASHP and PV are a great combination as surplus electricity can provide hot water, but the financial equation with no FiT is weaker.
I should mention, the is another option where they lend in advance of the stage rather than in arrears. Not sure how that works in terms of collateral against the risk. I believe interest is higher.
