Everything posted by MJNewton
We’ve got a Persimmon house and I’ve actually been really quite impressed with how well it was built, and I’ve seen it from virtually every angle and perspective having modified and extended it over the years. It was the show home though, so presumably first-built and perhaps the one that was subject to inspection with all the others just assumed to be built the same!
Are there any clues reported in /var/log/syslog, /var/log/messages or /var/log/kern.log?
Does the control group filter also apply to the balanced cold feed (which has been confirmed as having no issues)?
Yes, I’d expect it to last longer. Ours is 15 years old and never had an issue (touch wood!). Has it been properly diagnosed as to what the problem actually is? With such an expensive item I wouldn’t give up without knowing exactly what’s wrong (and that it’s terminal).
Probably just needs an extension kit fitting to divert the exhaust gases further away.
Ah okay. I wonder what it could be? You mentioned other reported cases - what was the cause in those?
To add: Is it just the hot flow that has reduced to a trickle or outlets connected to the balanced cold too?
Is she in a hard water area? If so, might it be limescale blocking the inlet? These type of cylinder are designed to minimise turbulence when being filled (from the cold mains) which invariably relies on some form of diffuser which can be prone to blocking. If you can get some descaler inside with, say, a 1/3 tank fill of water that might suffice. The immersion heater hole would be the best form of access I expect. It’d need a good flush afterwards. If you did decide to get rid of it I might be interested in buying some of the external components as spares for mine.
From what we've seen I imagine it might just be a case of flexing/persuading the two parts to be in better alignment. Perhaps some colour-coded silicone to fill any gap that might persist?
Who is the manufacturer? Would be worth asking them about it. It might well be that the maximum extruded length they can supply is 6m.
Working on different zones of an S-Plan
MJNewton replied to CotswoldDoItUpper's topic in General Plumbing
Yeah I've done the same when my only other option was turning off the whole road! It's funny (looking back at least!) how much harder a job is with water going everywhere. Very different kettle of fish to an depressurised heating system though. -
Was that water release whilst pressured? Once released the flow should reduce massively, although 22mm will always pose more of a problem than 15mm due to the difficulty maintaining a vacuum in a larger pipe. I can appreciate 'once bitten twice shy' and all that though! -
From what you've described I'd just do that 'live'. Cat litter tray and some towels work wonders. As does having everything you'll need to hand! Once the pressure has been released then water can only come out if air can get in. It therefore doesn't take much to reduce water loss to a minimum. Pipe freezing is for mains pressure situations, and even then its not essential if you're brave and bold enough! -
What job are you actually doing? Closing of valves is sufficient for radiator removal/refit, and pushfit stop ends can usually suffice for more intrusive work to temporarily cap the system off. Soldering of wet pipes is an issue, but it all depends what task you're doing as to what options you've got. -
Plumbing pipes - copper v plastic, different sized pipes
MJNewton replied to Porthole's topic in General Plumbing
7. Always use inserts! -
Is my house suitable?
MJNewton replied to jayc89's topic in Mechanical Ventilation with Heat Recovery (MVHR)
.. But noting that some can operate in unison ie one sucks whilst the other blows (stop that sniggering at the back please!) so as to get through flow of air between rooms. -
Grout colour sample lie and grout "shield" or stain pen
MJNewton replied to Adsibob's topic in Floor Tiles & Tiling
Be careful with that assumption! Whilst they might contain the same pigment the body of the paint is usually very different and can thus lead to a different end result (not dissimilar to Temp's reference to plastics/metals). -
Death of MHRV unit
MJNewton replied to DaveAndAnnaUK's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Do you know what he meant by that? What's are the branches of the T-junction connected to/from? Are they suspecting water (condensation) build up to be the cause of the unit failing to run (PCB/motor damage presumably)? -
Rigid vs semi rigid ducting?
MJNewton replied to SBMS's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Semi rigid, not least given that kine was a retrofit and rigid would've been impossible. I'm not sure of the benefits of rigid though - semi rigid seems to tick so many boxes in terms of ease of use, absence of joins etc. -
It must just be an unfortunate coincidence. I do indeed fit kitchens from time to time! Are you sure you want to go with TKC? I haven't heard good things about them, but I don't have any personal experience. Have you had a look at DIY Kitchens? They are generally very highly rated (Trustpilot can be handy to get a feel for a company, particularly once thousands of reviews have been left as the bias of extreme views tends to reduce leave a good overall picture - which in their case is particularly good). I think they came out second in a recent whole-of-market Which? review (I think it might have been Ikea in the top spot!). I don't know where TKC came - not sure they were even in the lineup.
Yeah, apprecuate that, I'm more just comparing it with my little white boiler hidden in a kitchen cupboard with a flue terminal popping out of the wall. I've never felt all that fond or protective of it until recently when thoughts have turned to the possible pressure to fit a heat pump at some point in the future.
All that automation and you have to press a button? I was expecting a rim mounted break-beam detector or something... ?
I hope the author 'Andy M' isn't 'Andy Marshall' (Sales Director for TKC Kitchens)... ?
I certainly wouldn't want one in my garden. It's (they're) a monstrosity.
