Shock Horror! we've just been watching one of those building programmes and when it came to plastering they didn't! They used the taper edge boards and just filled along the edges and the screw hole. I'm thinking if I took this approach It would save a wet trade, loads of time and mess.
To plaster or not to plaster - Thoughts?
It wouldn’t save time
or mess Lots of dust
Many of the new house builders lead by wimpy moved over to a taped finish
Some still do
Edited by nod
39 minutes ago, Christine Walker said:
Oh no you need to plaster, even when you Ames tape you see it forever!
Im afraid I disagree, I think it depends on the quality of your tapers and their finish
you can get a level 3 finish which is fairly standard or a level five finish that will make your skimmed wall look positively rough
i have had perfect skimmed walls that still require lots of fine surface filler and sanding.
I’ve done both on a daily basis for the past thirty five years
Skiming is a far better job
Skimed walls should need no filling
  • Like 3
I also disagree, taped and filled PB is office style on a good day.
You try sanding back on a PB wall and you hit paper. You knock a PB wall and you hit paper.
You BREATHE next to a PB wall and.....
With skim you get a layer which is infinitely harder wearing, can be filled and sanding without instantly lifting fibres, and can absorb all the undulations that boarding, taping and filling simply cannot ever do.
Ive been around both long enough to give an informative perspective.
Plaster if you want a home, tape if it's an office. When the sun hits a taped wall you can even spot where the studs are.
  • Like 3
  • Thanks 2
Amen, brother Nod.
The last time I had a spread do a single set over PVA I had them come back and sand it back. Looked shit.
Two sets over PVA or get back in your van.
I use a spread with arms like a lobster. You can hear the sound off the blade when the final 'rub' is being done. Nothing better.
Sheet 'o glass.
  • Like 2
The problem we have with taping is any crest or bump on the wall will show
With skim you can feather off inperfections
A point I’ve made before was prefill all joints casings and beads Two tight coats Three passes with a STEEL float No wet angles
its a myth that you need to fill after mist coating. You certainly shouldn’t see lines of easy-fill
Just now, nod said:
its a myth that you need to fill after mist coating You certainly shouldn’t see lines of easy-fill
:ph34r:
  • Haha 2
7 minutes ago, ultramods said:
eek, we have just budgeted for Ames taping. What is a typical cost PSM for skimming a new build?
Cost for labour is the same
If the taping is done correctly
And painted with a gyprock slurry
two coats Material cost is more
2 minutes ago, Onoff said:
:ph34r:
Apologies OnOff I’m sure your first attempt looks better than some of the so called pros work
Last house was tape and fill, almost the normal up here. Screw heads pop, and some taped joints the tape started lifting after a few years, needed some rework. Also some boards were not perfect with ripples visible on the untaped bits in some light conditions.
So this time we have had it skimmed, now we have found a good plasterer who is as rare as rocking horse ...... up here.
At this time of year, a plaster skim is dry in 2 days and painted in 4.
The lads that work for me I pay them £3.25 per sq mtr labour only
Which equates to about £200 a day
2 minutes ago, willbish said:
You could consider a clay plaster to save on the decorating... I just had a quote from Clay Works, 226m2 material only £9063 ?
I do marble plastering
very exspensive But looks beautiful
Real grand designs
Though my wife didn’t want it on our build
Have you had a go at Tadelakt? I like that Moroccan look for bathrooms but wonder how water repellent it really is. Again too expensive I reckon
No not come across that one
If it's your house skim it.
Or tape it and when the sun comes up pull all the blinds down till the sun sets again as you will see every join.
Yes @Triassic you should skim.......tape is for low end spec builds. We did tape joints not skim in the garage and thats ok for there but I would never have it in the house.
You will spend many years looking at those walls, you dont want daily reminders of a bad decision. Save the pennies elsewhere and get a good plasterer in.
Generally, yes, IMO.
Unless there is a specific different finish you want eg ply or bricks or concrete.
Or if you are using a different wallboard to pb. Isn’t there one @PeterW always talks about that takes heavier loads but which has its own finishing product? I think it is Fermacell, which I keep turning into batteries or angel hair pasta in my head.
Ferdinand
Yes Skim for definite, which does seem to become less common- any trades that have been on site have expressed shock and awe that my place is skimmed and not taped.
funnily enough I was in a rather plush hotel in Edinburgh a few weeks ago and noticed, whilst lieing in bed that my room had been taped when decorated. looked crap.
Fermacell is not for the faint hearted as it’s a very different product to plasterboard.
The green PB in @Onoff photos is moisture resistant PB, bit more expensive than normal PB but great for kitchens and bathrooms. Still needs a skim though.
