CalvinHobbes Posted March 25 Share Posted March 25 So thinking we need to order the 2 staircases. What is the most price effective wood that is decent? We would love walnut but presumably that is eye watering in terms of cost Also at what stage do they go in? Is it when you are watertight? Baskill will have our windows and doors installed 2nd week April. Link to comment Share on other sites More sharing options...
Simon R Posted March 25 Share Posted March 25 I'd put it in as late in the project as you can manage. Our went in after we had painted! Yes, it was a pain having to use ladders internally but it was also good having the open voids to get material in. Installing as late as possible also reduces the risk of damage which you want to avoid as much as possible. Fontanot do a very nice modular stair case with a good rage of different wood treadles which won't break the bank. It's a very minimalist staircase so not to everyone's taste . Link to comment Share on other sites More sharing options...
nod Posted March 25 Share Posted March 25 On our previous build we used oak with pine spindles and fitted them about a fortnight before we moved in 1 Link to comment Share on other sites More sharing options...
Conor Posted March 25 Share Posted March 25 We put oak in but regret not putting in a standard timber staircase and carpeting it. I'd say well end up putting a carpet runner on it this year. FYI with a local company for basic hardwood staircase you are looking at £5k upwards. 1 Link to comment Share on other sites More sharing options...
MikeSharp01 Posted March 25 Share Posted March 25 15 minutes ago, Simon R said: Yes, it was a pain having to use ladders internally We are not at the stage for the final stairs but to avoid the ladders we put in a cheap stair from Howdens to make it more comfortable getting around the building. 1 Link to comment Share on other sites More sharing options...
Kelvin Posted March 25 Share Posted March 25 8 minutes ago, Conor said: We put oak in but regret not putting in a standard timber staircase and carpeting it. I'd say well end up putting a carpet runner on it this year. FYI with a local company for basic hardwood staircase you are looking at £5k upwards. Why do you regret putting in an oak staircase? Link to comment Share on other sites More sharing options...
Kelvin Posted March 25 Share Posted March 25 Ours is solid oak. We also had a debate about when to put it in. To some extent it depends a bit on the layout of your staircase and ease of access. Ours is tight and hidden behind the kitchen wall so felt it was better to put it in a bit earlier rather than leaving it until the end. I ‘clad’ it in hardboard to protect it. Link to comment Share on other sites More sharing options...
Iceverge Posted March 25 Share Posted March 25 Pit ours in before spray painting. Bit of a PITA masking it. Pine and painted and carpeted. Oak handrails and popular spindles. Pleased with the carpet. Would do the same again. Oak is fine. Maybe a lighter wood would be nicer. 1 Link to comment Share on other sites More sharing options...
Bramco Posted March 25 Share Posted March 25 1 hour ago, Kelvin said: Ours is solid oak. We also had a debate about when to put it in. To some extent it depends a bit on the layout of your staircase and ease of access. Ours is tight and hidden behind the kitchen wall so felt it was better to put it in a bit earlier rather than leaving it until the end. I ‘clad’ it in hardboard to protect it. Ours went in pretty late and like @Kelvin it's oak and it was protected by cladding with hardboard and plastic sheeting. We used a light (whiteish) Osmo oil on ours - no carpets - everyone to their own.. Simon 1 Link to comment Share on other sites More sharing options...
Pocster Posted March 25 Share Posted March 25 Late as possible . Ours recently went in after 11 yrs ☺️ 6 Link to comment Share on other sites More sharing options...
dpmiller Posted March 25 Share Posted March 25 Throw up temporary, or buy a cheap set from the merchants, until the very last moment. Ours is a value-engineered lashup of oak, mdf, and something else solid-woody, but it really finished the hall off, very pleased with it. 1 Link to comment Share on other sites More sharing options...
Kelvin Posted March 25 Share Posted March 25 1 hour ago, Bramco said: Ours went in pretty late and like @Kelvin it's oak and it was protected by cladding with hardboard and plastic sheeting. We used a light (whiteish) Osmo oil on ours - no carpets - everyone to their own.. Simon Can you share a picture ig your whiteish osmo coating. I have both that and clear and can’t make my mind up what to use. The floor upstairs is oak and whiteish so either had to match or be very different. 1 Link to comment Share on other sites More sharing options...
Bramco Posted March 25 Share Posted March 25 13 minutes ago, Kelvin said: Can you share a picture ig your whiteish osmo coating. Hi Kelvin, take a look on our architects web site, lots of photos -> https://lhc.net/projects/ashcroft-creating-a-low-energy-family-home/. If you need a close up I can sort one out. Our 1st floor is also light oak (Brooks - Balmoral Rustic Oak). So the stairs and the 1st floor flooring were both treated with the Osmo oil. The Osmo oil label just says '3040 White'. We're not keen on oak when it goes orange, hence the use of Osmo white oil. We bought some samples from Osmo and tested them out on a sample of the wood that would be used for the stairs before deciding which one to use. Simon 1 Link to comment Share on other sites More sharing options...
CalvinHobbes Posted March 25 Author Share Posted March 25 Thanks, right so we have some time then! Thanks for the advice. Unfortunately we need non standard height Set 1 is Ground Floor - First Floor: 15 No. Risers at 199.4mm 14 No. Goings at 220mm Total Rise = 2991mm Pitch = 42 degrees Set 2 is Staircase to comply with Technical Booklet H (2012). Stair to have clear width of 800mm and be fitted with handrail at a height of 900mm above pitch line above stair. See General Notes. Ground Floor - First Floor: 15 No. Risers at 199.4mm 14 No. Goings at 250mm Total Rise = 2991mm Pitch = 39 degrees I know its a bit odd but frankly it gives our grown up kids a separate area and access Link to comment Share on other sites More sharing options...
Originaltwist Posted March 25 Share Posted March 25 I did a write up on a modern floating design along with some details on the geometry - might be useful. https://wordpress.com/post/originaltwist.com/1927 2 Link to comment Share on other sites More sharing options...
Kelvin Posted March 25 Share Posted March 25 2 hours ago, Bramco said: Hi Kelvin, take a look on our architects web site, lots of photos -> https://lhc.net/projects/ashcroft-creating-a-low-energy-family-home/. If you need a close up I can sort one out. Our 1st floor is also light oak (Brooks - Balmoral Rustic Oak). So the stairs and the 1st floor flooring were both treated with the Osmo oil. The Osmo oil label just says '3040 White'. We're not keen on oak when it goes orange, hence the use of Osmo white oil. We bought some samples from Osmo and tested them out on a sample of the wood that would be used for the stairs before deciding which one to use. Simon That’s a lovely house. i’m not keen on the orange either. I’ve done a trial to match the floor. It’s close. Top left is painted using the Osmo white. Bottom left is the floor. Top right is Osmo clear and bottom right is untreated. Link to comment Share on other sites More sharing options...
Bramco Posted March 25 Share Posted March 25 1 minute ago, Kelvin said: That’s a lovely house Thanks - the architect is our son - we think he's done us proud! 2 minutes ago, Kelvin said: Top left is painted using the Osmo white. That's about what ours looks like - I think there were 3 coats on the stairs, not sure about the floor though. Simon Link to comment Share on other sites More sharing options...
shuff27 Posted March 26 Share Posted March 26 My chippies made a sturdy temp staircase out of scrap timber (mainly left over from the timber frame package) for £200 & installed it shortly after the plasterers had finished the final skim coat. The design more or less mirrored what I wanted for my permanent staircase, albeit with narrower treads. They came back about a week before we moved in to remove the temp 2 flights of stairs & install the permanent ones. I kept the same half landing as it was already in the correct position (laid vinyl click flooring on the board, same as on the GF) & they attached a hardwood fascia to the pine. Where the temp stringers were removed there were just a few small areas of bare plaster to paint. My staircase is made from ash by a local joinery, with glass balustrades - I didn't want oak (too common!) so I visited their workshop to look at various hardwood samples. I've left the ash untreated as I prefer that look & don't have young kids or pets to worry about. Link to comment Share on other sites More sharing options...
Kelvin Posted March 26 Share Posted March 26 Ash is lovely. We had a table made from ash. 1 Link to comment Share on other sites More sharing options...
Thorfun Posted March 26 Share Posted March 26 On 25/03/2024 at 06:27, MikeSharp01 said: We are not at the stage for the final stairs but to avoid the ladders we put in a cheap stair from Howdens to make it more comfortable getting around the building. we used Stairbox for that cheap temp staircases. sadly funds are so scarce now we're near the end that i think the temp staircase will be painted and kept for a while until we can afford the final one. Link to comment Share on other sites More sharing options...
Blooda Posted March 26 Share Posted March 26 We put a temporary starcase in. [got it free as the supplier of the final staircase was ripping one out the next day, after he came round to measure up. Our final one is Oak [oak veneered MDF in places], but we have a runner up the centre. We fitted almost at the end [it sat in the lounge wrapped up for over a year.], tiled most of the floor, then fitted the stairs [the bottom stair is delivered loose], finished tiling and then fitted the bottom step. Ours is still one the website. See below. I think they now do installation, which I would recommend as our joiner, me and the mrs lugging the oak stair case about was not a pretty site . Link to comment Share on other sites More sharing options...
CalvinHobbes Posted March 31 Author Share Posted March 31 (edited) I called into an engineering workshop re the balcony and whilst looking at the plans said he could build our main staircase (it has a turn in it) for 2k plus. It's tempting, it would never creak. We had one years ago and it was carpeted. Great job. I asked would it satisfy building control, he said yes. Tempted. Also I guess could put it in as soon as floor was down? Like it wouldn't mind a knock. Edited March 31 by CalvinHobbes Link to comment Share on other sites More sharing options...
Declan52 Posted March 31 Share Posted March 31 I used softwood for the main timber and painted it white and used oak treads to make it a bit more fancy. 10 years in and both are holding up well. It kept the cost down a fair bit as well. I used a temp staircase until the last few days to stop the nice one getting wrecked. Just made it out of 6*2. Wrapped the oak treads in carpet to protect them until the day we moved in. Link to comment Share on other sites More sharing options...
Shoestring Posted 15 hours ago Share Posted 15 hours ago So late to the party here, you probably already have your stairs! Just in case it's helpful; we went oak handrail and treads and softwood painted risers and spindles. We used Pear Stairs and they were really good, love the quality, our carpenter is a god too, so that helps! We had a non standard height too & needed the staircase in in order to start upstairs so we wrapped all the handrails in bubblewrap (from all our various packages) covered that with cardboard and put strips of vinyl flooring cut and stuck together with duck tap for each tread. My only regret is I would like to have painted the spindles and newells before they were fitted as it's mighty fiddly and time-consuming. The stairs were preserved really well under all the protection (from adhesive, plaster, paint & tea) and I have used Fiddes hardwax oil in clear for the handrails and treads. Link to comment Share on other sites More sharing options...
Dave Jones Posted 14 hours ago Share Posted 14 hours ago stairbox top quality oak 2500 Link to comment Share on other sites More sharing options...
