Laser Level - Recommendations?
richo106
Hi all
My very old laser level has finally gave up the ghost and I need a new one for when I start on the internal fit out. I’ll be needing one for socket heights, spotlight layout, fitting kitchen units, installing stud walls etc…
Can any one recommend one at all?
One them keeps cropping up is a budget one called a Huepar.
https://uk.huepar.com/products/huepar-3x360-3d-laser-level-green-cross-line-laser-self-leveling-147ft-45m-large-power-903cg
Happy to consider any recommendations though
Many Thanks
I got one of these for indoor use.
https://www.amazon.co.uk/gp/product/B092HXDGS3/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Works for me but I've got nothing to compare with.
Frequently you want the laser to draw a line through an existing mark. Say a vertical line. It can be fiddly to do that because small movements of the laser level translate to large movements of the line on the wall. A tripod with a knob you turn to rotate the level might solve that. Also needs a way to raise and lower the unit to adjust the height of horizontal lines smoothly. Otherwise you need a lot of different thickness blocks of wood etc.
I have the DeWalt as well. Had a couple cheaper Chinese 5hings from Amazon that had loads of features but the robustness of a dry leaf. Killed two before getting the DeWalt.
I then got the laser receiver and mated it to a 25 x 50mm batten and now I've got a levelling kit.
Screenshot_2023-01-28-15-35-58-903_com_ebay.mobile.thumb.jpg.5ffe085b38db44c0a5c352b060e3a296.jpg
I have one of these, built my garage with it.
Twice it's come to save the day when a DeWalt level and then an expensive rental model went bust.
Its about 4 years old, never got any special treatment and is still going strong.
8 hours ago, Thorfun said:
I have a Huepar. It’s a great little unit. A few others on here also have one. Do a search and you’ll find some threads about them.
Yup, I have a couple of Huepar, but the 603CG with the receiver unit and an extendable pole, so works great for landscaping too. Couldn't be happier with it. It's robust, dropped off scaffolding and out of my hands at height a couple of times. The other day I accidently kicked it out of a loft hatch and it landed on one of the ladder rungs in an unfortunate way that broke the protection cage and glass over one of the lazers, but it's still working fine with no harm to the lazer itself. The first one I bought developed a fault with the horizontal lazer. One email and a video and I received a warranty replacement within 24 hours, so the customer support is there too.
Hi All
I have decided to go with the Huepar 603CG. I think this is exactly what I am looking for, for the price and functionality I think its worth a try!
With the options to buy the extras also appealing
Thanks for all the comments/advice very much appreciated
  • 1 year later...
My lastest one is a Kaiweets KT360. Looks like a Chinese knock-off DeWalt, but works well. That battery lasts for ages, but still worth getting a spare.
Thanks all. I just returned the Dewalt DCLE34031N and the matching receiver for the Huepar S04CG-5RG. Half the price for much better features and similar performance (less range so need to check on-site that it’s enough). The Huepar seems sturdy enough compared to the Dewalt.
Green dewalt with the receiver. I tried using the receiver with a cheapo green laser from Amazon, it didn’t work, I got the matching dewalt laser. Goes through batteries but really pleased
Used my Heupar S04CG-5RG to do a basic (very) survey of my site. It worked very well once I got the hang of using the receiver. Seems to have a reliable range in sunlight of at least 30m.
Edited by zzPaulzz
12 hours ago, zzPaulzz said:
reliable range
I don't know what you will be using it for.
Just to say that the seemingly accurate range can wander off if used too casually. The way you use it too.
Are there instructions about, for example, equal backsight and foresight?
Maybe I value accuracy more than most. Houses are very approximate usually, and mostly it isn't a big deal.
Drains not running is important though.
Fair points. I haven’t evaluated its accuracy so will not bet the house on it. Even then I don’t trust my skills here so I will leave the real surveying to the ground works contractor as there’s a main sewer to move as well as prepping for the foundation pad.
That is my unspoken concern.
Using lasers , people seem to think everything will be fine. I've had huge errors by letting them get on with it. Lots of block cutting, as usually the concrete is too high.
I'm maybe old fashioned but I like working levels to be pre-marked.   eg battens up to footing level, or nails banged into trench sides. (or proper motorway stuff of profiles.) Then they are just pouring concrete, not juggling a staff as well.
Or you watch their skill level and do the odd check after hours.
The equipment benefits too as it isn't covered in concrete or knocked or driven over.
More advice upon request after you've searched the interweb for advice.
