Ferdinand
    41
  1. PS I would be thinking about things like spreading Junipers that will be 20ft wide and up to about 5 ft high, in 12-15 years, and a huge bank of different-coloured Pyracantha in front of the garage (heaven for birds). This is Landscape Design not gardening - go to town on it. F
  2. Lovely job. I just happened to glance in the mirror; I have gone slightly green. The language ... esp. the heavy eaves, and window / door proportions and placing eg heavy chimneys, mullions and windows continued to the roofline: for me that look is Lutyens or Arts/Crafts inspired .. looking at places like Deanery Garden or Fig Tree Court. The marker is heavyset vertical proportions but still an emphasis on the horizontal as the frame. I am sure that someone can identify parallel comparators in Scotland sure that. William Kerr and The Gean? I would be interested to hear a bit more about your inspirations. What is your landscaping scheme? To me a key element is how you are going to handle those large pieces of blank wall next to the front door, and on the face of the garage. Not having features on the wall there, to me it needs a concept or something to root them into the plot. I would look to something quite architectural as the core, to provide a counterpoint to the smooth texture of the walls. Good job. F
  3. I normally leave those hidden as far too easy to delete by mistake otherwise. Do Microsoft still have Delete next to Rename in the Right-Click menu?
  4. Having been of slight help to a member of the community, I am cashing in my right to make a horrible pun. ? Twas in a restaurant they met Romeo and Juliet Having no cash to pay the debt Romeo'd what Juliet. Ref Chivers Jelly Bumper Book of Fun, in my possession when I was about 7. I hope to remain about 7, except for the uh-hum. F
  5. ENough so that when all the clutter and the gubbins and the sticky-out bits are in place, you can with reasonable ease put scaffolding in place to maintain it in 20 years time. And get anything through the gap that you may need at the other end. If I can do it I like space for a decent digger, which means about 1.1-1.2m. Not always possible and you may have another route. F
  6. If it is a door in window mode, then surely you need a safety something across the opening on the outside anyway to stop you falling out and landing on your bonce? That IS a Juliet balcony. If for some reason you do not have one, then a Juliet balcony as in a grill to stop you falling out would normally be permitted development as long as it had no floor. I think the other test is that it must be within 150mm of the face of the wall. You would not even normally need PP for a new window unless there was potential overlooking ie on the side. This point may be nullified by your being in a National Park Iirc (?), but in principle you could perhaps just add it afterwards in most situations. I think that is all right, but I am open to challenge. @Prodave the advantage of a Juliet balcony has always seemed to me to be that the balcony space is inside your house so you get to have the floor space all year, rather than on the Perhaps 7% of days where the weather is OK. But that argument does not hold against a cantilevered balcony, just vs one of those that is recessed into the building. F
  7. Ferdinand
    "What hole?"
    Learning point for most places: always have a cheap phone in your pocket to call help when working alone. Do we all do this?
  8. You could probably put small circles of theatre light colouring on those if needed, or use the paint-on stuff; they run cool. F
  9. I think you perhaps cannot use other people's land to fulfil your turning requirement anyway. Though I wonder what *he* will do for Fire Engines when he builds his new house? Or can you get an extra bit of land beyond just for the Fire Engine (is it a field?). Suspect this will go back to sprinklers...
  10. In that you presumably supply the meters?
  11. Hmmm. It does say "or Hammerhead" in the text. Any use?
  12. Good. Personally I would be wondering about growing watercress...
  13. Looking at @Russdl‘s detail I would do one or two things differently. I would not have OSB sitting underneath the gutter. At the least I would use waterproof ply, but ideally something even better that is entirely unaffected by water. I would probably want a fall towards the outside wall in the sheet beneath the gutter for belt and braces. I would ideally want to run the below tiles membrane straight down into the gutter for simplicity and continuous coverage. I am not sure how I would detail that. Ferdinand
  14. Yes. But needs care and appropriate lintels. Creating two was the first DIY construction job I ever did. F
  15. @deuce22 From a different angle, do you have to bury this? Can you make it a defining garden feature with waterfalls, maybe fountains, and a "babbling brook", and perhaps a cistern with a pump for feeding your hose pipe and outdoor shower? Some magnificent gardens have been designed around springs on hillsides. Or could your "dam" be a reflecting pool and a fountain? In a flight of fancy could you build a natural swimming pond? Could be far more economical than digging holes and building walls and dams and culverts, and no one could dispute the accessibility. Ferdinand (carefully avoids mentioning cherub based on @pocster's avatar).
  16. @laurenco Clarify for us - you are talking across the bottom of the roof, not drainage down the verge? And do you want all the water from the roof to find its way into *this* gutter (which implies some sort of slot all the way along the bottom of the roof above your gutter-cover)? If it is the former, I made a neighbour do something like this along a 20m roof when his gutter was going to overhang my garden - though it was not quite *fully* concealed. My dad designed a detail for them. Essentially you sit the gutter on top of the wall, and flash underneath it and up the back and sufficiently down the face of the wall. And then you need a robust detail that will protect your wall and inside of the house, keep your gutter clear (anti-bird and insect grilles at the ends etc), and let the water get into it in a maximum water-flow event. It needs to be maintainable for when it *does* get blocked :-). You also need the face and appearance of your wall to be robust to the runoff water that lands on the gutter-cover, and overflow if the slot has insufficient capacity or gets blocked. I think my neighbour used lead flashing, but it could be one for glass fibre or EDPM. Will try and get some piccies. Ferdinand
  17. The limit of 25W says to me that it isn't not there yet except for specialised and niche stuff. Imagine trying to wire 16 down lights from it. Ferdinand
  18. Usually you can 2 shower rooms in the space for a Jack and Jill.
  19. Recognising that a lot is cast in stone as you have a Planning App in, but commenting a little more widely as I am wondering if your overhangs will be seen as taking the p slightly on a footprint restriction and they may say to think again in some respects. I like that you have not told the planners *too* much stuff they do not need to know. 1 - I like the placement, orientation and layout on the plot, but wonder if you need something for winter / wet weather playing for kids that is not the main lawn; area by the South end of the house? Being cater-cornered always make it seem more upmarket and bigger, like laying tiles diagonally in a room. 2 - I like the curved wall - if stud should be OK to build (insulation inside it) if planned carefully by good people. Not sure a pantry that deep and narrow will work at the back - lay it out in full plan size and experiment physically? I might make the last 1.2-1.8m into a cupboard or shelf unit in the hall. 3 - To me the overall look and feel is a bit retro, and does not match recent ideas of open voids and "wow" spaces inside, and in the use of windows. May not be a issue for you. That may be partly the furry sketch style of drawing, which always feels more busy on the page. Has it been run through a furry-iser program ?, or is it a real by-hand sketch plan (gold star if so)? 4 - I half agree on the "4 beds to one bath" comment. I would consider a compact ensuite (perhaps shower / whb / no loo) in Bed 5 - either where the desk is shown, or at the house corner and move the Master Ensuite (does it need a bidet? Would a shattaf be OK instead?) down slightly where there is room and the M.E. window round the corner (in two minds on this as that would make the road-facing elevation asymmetrical). I would make Bed 5 a potential alternative or second study wrt to sockets and lights etc. Make sure all the showers are large, and not like telephone kiosks. 5 - I think the lounge-dining works OK but if that is a woodburner it may be a pink elephant in a Code 6 house. Consider a flame effect gas fire or even electric, or spend the money on a lighting designer for your lounge diner to create an intimate feel? 6 - I think your biggest issue is that the hall / loo / utility / stairs area is not resolved enough, and could be a lot better. It feels a bit maze-y to me. There is a lot lost to circulation space in the hall and that dogleg walkway in the utility. I would: a - Put the hall-utility door by the kitchen, so that the utility walkway takes up less space and you only have doors in one corner. b - Straighten the wall between the utility and cloakroom, for me towards the utility so a shower can go in the cloakroom for disabled or frail guests etc. c - Put that inner-hall space into the Cloakroom, and use that as a coats and "things" (pushchairs, wheelchairs, golf clubs etc) area - could have a large closet, with a further door to the downstairs loo, into which I would put a shower as (b). As it is that circulation space is wasted. d -I would take away the wall between the stairs and the front door, so you get a more fluid space and the impact of the void above the stairs is your "wow" perceived on entry. e - I would consider moving the front door to the West or Centre within your 3 section door design and consider either making the staircase wider (ie open well between the two halves), or making it a 90 degree not a 180 stair to lead the eye into the void. That would increase your impact for minimum changes, but may need a bit of juggling with your door design. I think it would be grander and suitable for a large house such as this. f - I would make sure the stairs are at a more relaxed than typical angle - go for 34-38 degrees if you can, not 42. It makes a huge difference to the "feel". IMO insist on this. This should be a building regs not a planning matter. g - I would be more generous with my staircase windows, perhaps double or treble the width. That may affect your Code 6, however. 7 - I think you could reconsider your other windows at the front - at present there are too many different sizes, and I am not sure about the "tall and thin" subdivisions. To me that is not a suitable entrance face for this house. This would unfortunately involve returning to the planners. 8 - What is your provision for house-wide disabled / elderly access in future? This will become important. 9 - Do you need a snug? HTH - it may be more than you wanted but even for validating your decisions different suggestions can help; there is also a lot you could do within your PP if this is approved. Ferdinand
  20. Thanks for the suggestion for a 3kW option. £150 is also a price point for the non-elecronic version of the Siebel, and smaller versions of the Electronic will be in-between. It's a tricky call. Current use of the facility is relatively limited to peak periods (8-11, 4-9, occasional at w/e) with a some 6-8 early morning, but our membership could easily double this year - so more potential demand. Currently there are quiet periods, but we are working to increase usage, and filling in the gaps etc. I need to look at our constraints, I think, and do a short project-memo to lay out the options. Ferdinand
  21. Build a hinterland, and also read all the blogs from end to end. F
  22. Yanking this thread back from the Elysian Fields... Is this range still a good option to heat a tap on a washbowl in a cloakroom? The application is for a gym changing room where we currently have hot showers but no hot water tap for hand washing. I have a whisper in my head that it may be a regulatory requirement somewhere. Our supply to this is not preheated, and the most need I can see for expansion would be one further bowl ie 2 taps. If I could use something more like 3kW than the 10kW discussed here to avoid any need for running new electrics it would be an advantage, I think. If I can save £100 or £300 that would be another extra little improvement project I can do more quickly. And I have a list of dozens of small improvement projects I would like to carry out which are gradually being done one by one. Having run a few numbers I think that I probably want 2-3kW per sink, and that I cannot rely on averaging to reduce my demand since they may all be in use at once. So it may be do something inexpensive now and accept that new wiring might be needed should we add another sink. I'll first have a detailed look at the electrics just to check that there is not a heavier supply close by. Ferdinand
  23. SO that is ganja too, then. Has Levi Root self-built yet? His twitter handle is @levismokehouse.
  24. THat is interesting. How large an installation is that? F
