What type of windows? Are they original? How old is the house? Alu frames are relatively recent, and in this country mainly post war. Looking forward to the detail. I think in the US they go back to about 1930 .. around the time of the Empire State Building. There is a company Called the Heritage Window Company who may advise .. but that is not a recommendation, just a note. Or a body called the Historic Houses Association, but if they are Alu and original I do not think it is likely to their territory, as the house will be relatively recent. F
WHatw as the actual situation on that roof. Was it actually built too high, or did the street view give a misleading impression. IF the latter, calling it "an illustrative street view" may have saved you. Ferdinand
2.5m wide garage door, a decent default size?
Ferdinand replied to epsilonGreedy's topic in Garages & Workshops
Why not use the method the first used for setting torpedoes? They put a long prodder on the front of their boats and submarines :-) A bit like Sir LanceLot. Ferdinand -
No, but it is actually planted slightly above ground level in an old asparagus bed. We are starting to get one or two escapees now .. 4-5 years later. At ground level I would put pavers vertically down to 18” and probably use a membrane to line them. F
Yes .. I would offset it. Not least because that would then satisfy (perhaps) cycle storage requirements, as providing 1.1m useable width above a generous parking space. I bet @epsilonGreedy has considered that however. F -
Good that you have considered it. Can you exploit the Ooops I Built It Slightly Too Long error margin factor to get 5.1m? F -
A current transit van including mirrors is 2.474m, and Tonka Tanks such as an Audi Q7 are up to about 2.25m including mirrors. So that might argue for 2.8-3m. What about the length? However, the length is notably short at 5.0m. A perfectly normal senior salesman special BMW 5 Series Estate is 4.942m, which will give you exactly one inch at either end. I would say you want it to be at least 5.5 and preferable 6m long. That imo is an issue at least as significant. My grandad used to have a tyre on his garage back wall to prevent him nudging it in his sectional garage. Fortunately bike tyres come down to 20mm or less, so one of those would just fit ? in those circumstances. But closing the garage door would be a game of Russian Roulette with your rear bumper. Ferdinand -
Not convinced that we have a full answer to this yet. We have the Building Regs saying lag all main distribution pipes. i would say that inside the heated envelope you should lag hot pipes when you don’t want them to cool, and cold pipes where you o not want them to become lukewarm in warm environments. If your bath hot water is losing a couple for degrees, then the temperature at the boiler or whatever end will need to be higher. I would lag cold pipes if they are eg in your heated slab. A drink of cold water would be cold and not require extra water to be run out of the pipe. My predecessor did not lag cold in te slab, and it is annoying. One more question .. has anyone calculated any impact on heating system controllability of having uninsulated hot pipes? There is a lot more pipe in a ufh system, but if that is running at say 30C, then a smaller volume of pipe running at 55C for a time may be material in boosting the temperature. F
Ahem. DependEnt. (/pedent) . Since he has balls of steel, @Onoff will need three of those things. Let's hope he never has an accident with all those electromagnets in his shed.
ASHP- struggling to warm house in the cold weather
Ferdinand replied to Jude1234's topic in Air Source Heat Pumps (ASHP)
I think we have done that before. In this weather one way is to heat it up and take a lot of thermal images. The outgoing air drafts may well show. -
I think this illustrates that trying to be TOO precise can be a waste of effort. If we look at Celotex, to go from 0.16 to 0.11 is 50mm extra. The current Wickes retail price is £37 for 2.88sq or £12.5 per sqm. But Self-builders get the VAT back ,(£10.50 per sqm) and anyone sensible can get 20% off at Wickes across the board. £~8.45 per sqm) And then they do 5 for 4 sometimes. £~7 per sqm. Or you can just buy from insulation Superstore for £7.50 per sqm anyway. Or buy-and-store from a seconds place for perhaps £6 per sqm if you watch it carefully. The stack I have in my shed cost about £14 per sheet, delivered, or £4.50 per sqm, and that includes VAT. About 2 years ago from Seconds & Co. I think @PeterW did even better. Currently you can buy 110mm 8x4 from Seconds and Co for £32 per sheet, which gives you a 0.9 u-value for <£25 per sqm for the materials - obv foam, alu tape etc needs to be added. Or you could use a 65mm insulated plasterboard on top of one layer for 0.11 to save labour. Ferdinand -
This is a giant clumping bamboo that was put in in iirc Spring 2014 or 2015. It is planted in a former asparagus bed, and cost about £50 at the time. The plan is to block those windows, and it has thickened massively and will reach about 10-12ft this summer. IN theory it reaches 5m or more. Ferdinand
A friend who supervised the construction of one of the offshore wind fields hinted that his company would not be doing any more .. I think. But it may have been the last one they were doing in current licensing rounds. Does anyone know if more offshore wind will be built around the UK? Ferdinand
AH the planning system :-) The average U.K. House price in 1980 was 24k. It is easy to spend that much now on Planning and Ologists for a single self-build. F
Is there anything which can help mitigate the downsides of an overlay system by providing a measure of buffering and persistence in the heat? eg spreader plates on the top, say under the underlay which then has laminate on top? Possibilities might be metal sheet, or even slate or cheap tiles or similar. Creative sourcing would be required. There is no point in having something thicker than a screed, but something may be possible. Quirky, mind .. so probably strictly for self-builders. Ferdinand
Welcome @Sam Barn. looks like a good project. I grew up in a restored small Manor House with walls that thick, though rubble fill. Our renovation took more than 20 years ?. My initial comments: 1 - I would avoid the rockwool for 2 reasons. In a narrow property it is a little bulky, but if they get in it will be loved by vermin. What is your strategy for Roland and his friends ? That required gap under the old foundations in the detail is a slight alarm bell for me wrt to tunnelling under the slab, but it is not an area where I am very knowledgeable. I suspect they would access your inside/outside wall gap from the top, though. In ours we used to get rats scrambling about inside the walls. How will you protect that gap behind your inner wall? 2 - Is that insulation enough? It is close to Building Regs minimum, and I question that for such a long, and quite narrow, building. Perhaps some thermal modelling to determine the value in adding more insulation to your walls? PErhaps PIR both ways, with the inner side of the outer layer taped for more airtightness? 3 - How are you ventilating? Ferdinand
Small dreams - looking for house layout advice.
Ferdinand replied to simplepimple's topic in New House & Self Build Design
Good. Remember my opinion is just an opinion not advice. (/slopeyshoulders) I wouldn't turn it round ... I would actually treat it as double aspect with the rooms located for sun when you will be in them i.e. Kitchen mainly morning, living all day, bedrooms evening. One nice thing about the plot is that you have obstructions to the light away beyond the road on the sunny sides throughout the day and evening. F -
How to build - so many options
Ferdinand commented on Sue B's blog entry in 5 (2 adults, 3 dogs) go building in Dorset
Blimey. That sounds like an STD. -
OK @simplepimple, in response to your last 3 posts. (I have actually sketch laid out this morning what I think is a better scheme, but I will leave that for a day or so as we have hit you with a lot of stuff). It is probably to your advantage to have a minimal scheme designed for the PP. If they suddenly came up with something better, they would perhaps want more for the plot. Given what you have posted, I would be reasonably happy that I could develop *something* that meets your needs on that plot, and I would be willing to go toe to toe to get something better through, as I can see no showstoppers. BUt that is my opinion and I have done planning battles. I think the parking is easily fixable .. I would replace it with a side by side parking and a double width driveway, with your privacy fence on the far side of where your tandem parking area is currently indicated. In terms of the sale, I think you need a binding including on successors guarantee that they allow you to put scaffolding on their land as will be necessary to construct a dwelling which has received PP on the plot. NOrmally it could cost a couple of thousand to have it there if you are being charged rent, and if they sell up that might happen or they could just say no. THere may be a time limit say three or five years. I also think you want that silly dog leg in your land where their back gate is in the middle straightened out, but that is perhaps minor. Are you sure they do not plan to sell? IT seems strange to keep it once it is that much smaller, but plan to sell the bigger version including the plot. THe smaller one will be more inadequate. have you considering offering for their whole house, so y get the uplift on the plot .. or is that out of the question? F -
@newhome The normal rule is something like 2 spaces for 2/3 bed, and 3 spaces for 4-bed. @simplepimple Another material inaccuracy on the plan afaics ... next door are misrepresenting their amenity space. It says 120sqm, whilst putting a measure on it says something like 60sqm if that grid thing on the back is a conservatory, and about 75sqm if it is a patio. It may be that some of these misrepresented aspects have got through outline, but tmay be questioned at detailed planning stage .. so take your time to be sure. Visually, just compare the fifty sqm footprint of your bungalow to their back garden and it sticks out like a sore thumb. I would suggest taking great care on measurements etc. Do not let them peg out the plot for you, or you could get scalped. BE particularly suspicious of the width of their parking area, the position of that gate, that you are getting all the width of your plot, and where the edge of the pavement is taken as being. If you have not signed on the dotted line, I would get a check that your 110sqm is accurate. I think you are actually getting slightly under 80 sqm, which is a quarter less than you are being told if accurate. Potential negotiating point imo rather than a withdrawal point imo, it is still a very nice plot. Amenity space is private, and it does not I think I nclude sheds, storage, parking outside your privacy fence, or narrow areas which cannot be sued practically or access paths. F -
(I welcome contradiction here, esp. from @ProDave or @newhome, as these are rapid insights and I am raising doubts. I could be wrong and I do not want to scare @simplepimple off.) How big are those car parking spaces? The plan as shown makes them - together - the same length as the width of the bungalow ie about 8.5m. It's a bit of a diddle, as that is not legal. If you ignore the space for the gate to open, and go right to the wall of the shed, you have the legal minimum *just* ie 10m. To go inside the spaces as drawn - and assuming a gap between the cars of 6 inches, and to be 6 inches back from the kerb, and 6 inches from the shed wall, you can *just* get 2 Minis on there. And you will then need the gate opening the other way, and to move the Minis to get to the shed. Ferdinand -
(I hope @simplepimple does not mind us debating the plot like an exhibit in an experiment ?, but that is where new perspectives and insights emerge from at least for me !). Looking at the plot, it is really on a curved 90 degree corner - so there are probably TWO building lines, even though the Planning Permission shown only really reflects the one on the South side. Assuming that fence on the West is 2m, I agree with you wrt to a West facing garden. The insights needed here imo are from tight plots in built-up areas. If the bungalow is moved up to join the parking spaces, then a private sunny courtyard garden the same size as the existing shaded North side garden can be created within the current indicated S-side building line as well as the private garden on the West side, And it may be that that could extend further South too. Classic "house placement on tight plot" practice says put it as far to the non-sunny corner as possible, and leave the sunny or non-shaded sides as your garden that can be seen from the house - in this case the latter are the West and South sides, which face the road. Privacy on the South Side right up to the pavement can be achieved with a fence / wall (subject to PP) or with a hedge (perhaps with a hedge outside a fence). But a wall / fence can surely be built along the building line, which gives a private sunny garden as large as the current shaded Northern garden. That must be a better layout. The other obvious layout thing may be to put the parking on the South Side to do something useful with the non-prrivate area S of the Building Line, which lets the bungalow or house to be put where the parking is currently - and that gives space for a larger building footprint or even better private and sunny garden. Personally I think a roughly L-shaped or similar layout, or an enfilade layout, would work well right in the East Side or North East of the plot, which gives sun through the largest proportion of the day. Remember the discussion we hadback in 2016 (and before that in 2014 on E-Build) about my studio bungalow, which is on a plot with two sides against public roads or paths. The thread is here The design is below. Imagine this at the RHS of the plot in this thread, with minor adhustments. Ferdinand -
Welcome.
i would look at something more like turning the parking space into a covered car port, with the house as far north on the plot as possible, directly entered from the north, and you walk through from that side to a private south facing generous courtyard garden. In its way it is quite a spacious plot .. if used efficiently. But I have not worked it through yet, and it may depend on things like where the council will allow two metre walls or fences. To me the existing design is what I expect.by renovating a small 1950s bungalow when I remove one wall and add in one set of patio doors; mine was exactly like that before it was renovated. A new build should imo have fewer compromises. F
