Everything posted by Marvin
Recommendations for a CO2 detector please.
Marvin replied to saveasteading's topic in Barn Conversions
Yes but even the mains connected ones don't last for ever. ours lasted about 5 years! Its the same with smoke detectors/heat sensors.... -
Hi @Barnboy I've had this problem with cheap water based mist coat. The paint came off with a damp cloth. Also had challenges before when I think the plaster had got dusty before being painted...
Depends of amount of pipe available. Not easy if pipes go into screed but often easy when timber joisted floor.
What causes the water to go through the Bypass radiator? temperature or pressure or ? Where is the bypass radiator? in the bathroom or ?
Where in the building is the buffer tank? In the loft?
Don't hang about. Carefully put suitable wooden chocks either end of the radiator between the bottom of the radiator and the floor. Don't force them in, just use enough thickness to be firm. If your really worried squeeze silicone in where the fittings are off the wall as a temporary measure as well this will help to stop it wobbling. M
MVHR into a cold roof ?
Marvin replied to Post and beam's topic in Mechanical Ventilation with Heat Recovery (MVHR)
The MVHR units can be quite big. Ours fits through the loft hatch. We rolled 400mm of loft insulation over it and around it. -
Loft conversion - rotten timber?
Marvin replied to Firsttimereno's topic in Lofts, Dormers & Loft Conversions
How deep are the joists. How deep is the hole. -
TRVs not responding to room temperature
Marvin replied to Little Clanger's topic in Central Heating (Radiators)
It suggests the head may not screwed down to the body correctly. You have to rotate the head into the groves of the body before screwing the collar. (the groves stop the head rotating before the collar is screwed up It may be that the head has not warmed up yet. The head has an expansion vessel in it which pushes down on the top of the pin which closes the valve. the expansion vessel takes time to respond. The rad valve may be colder than 15C and need to warm up. The product is faulty. Many other reasons that clever people will come up with. Good luck M -
Are we targeting ASHP's at the wrong market?
Marvin replied to ProDave's topic in Air Source Heat Pumps (ASHP)
https://www.coolingpost.com/uk-news/roof-mounted-heat-pumps-on-trial/ -
Sounds like the set temp for the defrost to kick in is high
Hi @Beelbeebub Yes it works, but by 'reasonable', what is required are radiators with a larger surface area than for boiler heating so the lower temperature is dissipating over a larger surface area thereby giving off the same amount of heat. Luckily I didn't believe that our renovated home would be as thermally efficient as it is and had installed larger radiators than calculated when fitting the boiler before converting to the ASHP. Where we did have any cool spots i replaced a single panel radiator with a double. there are many upgrades you can do: P1 also known as Type 10, is a type of radiator with 1 radiator panel and no convection fins. K1 also known as Type 11, is a type of radiator with 1 radiator panel and 1 set of convection fins. P+ also known as Type 21, is a type of radiator with 2 radiator panels and 1 set of convection fins. K2 also known as Type 22, is a type of radiator with 2 radiator panels and 2 sets of convection fins. K3 also known as Type 33, is a type of radiator with 3 radiator panels and 3 sets of convection fins. As @ProDave says above be careful about cost efficiencies. Ours were achieved by the fact we were using expensive bottled gas to run the old boiler and we have PV that supplements the electricity used so the savings for us are good. Good luck M
New Garage Floor - Lower than my driveway 500mm
Marvin replied to iSelfBuild's topic in Garage & Cellar Conversions
could that cause any issues to the retaining wall??? Yes. But it might not. The devil is in the detail. -
And my advice is that it can technically be built but it may depend on planning rules, building regulations, ownership of the retaining wall, property deeds, and everything else I'm ignorant of. As my brother used to say 'It's not if, but how much.' Good luck M -
Hi @iSelfBuild Items you may wish to consider.. Soil mechanics! Load baring capacity of the Soil Slip plane Heave Full design details of existing retaining wall (survey may be required) Existing services. Old and new drainage. Localised flooding Leylandii hedge is known for its shallow but wide root system, depending on the soil and the variety of leylandii. Permitted development rules. https://www.gov.uk/government/publications/permitted-development-rights-for-householders-technical-guidance Who owns the retaining wall Conversation with the neighbours Undermining the stability of the existing retaining wall whilst your gym vibrates as you pump iron🤣 Yes this is the problem. Without a drawing with accurate dimensions (not a scaled drawing)written on it, with both horizontal and vertical distances, ideas given could be excellent or Ballox and pictures of the walls really help. (is the retaining wall vertical or leaning towards your drive at the top?) In my opinion a raft foundation is more likely to cause heave or lateral pressure on the retaining wall. Good luck Marvin -
Does plasterboard have to be plastered once installed?
Marvin replied to Post and beam's topic in Plastering & Rendering
You can do either and I have done both but skimming with Thistle Multi Finish Plaster will give you a better end result in my opinion. -
Removing sealed units from old UPVC windows
Marvin replied to Lincolnshire Ian's topic in Windows & Glazing
A photo or 2 would help. I'm surprised that it takes so long. -
We have challenges with over heating when the outside temperature is above 11C. Thank god my wife insisted on openable windows. With two of us in a 104m2 bungalow, when were cooking or washing or my behaviour is being discussed the building usually over heats without putting the MVHR on boost and or the windows being opened.. M
Hi @Bramco. No. I actually installed with the same company this way when there was another government scheme going on in 2021. I carefully checked the MCS regulations about positioning and read up lots of things here, completed the installation and they came all the way to the Isle of Wight to inspect and commission.
This is what I did! They were very helpful.
Goodness me! I have estimated our running energy use (no, not all metered, but a lot of history over the last 5 years and testing on items like the MVHR fridge and freezers, internet, ASHP, TV fire detectors, water softener, telephones, clocks, items on standby and so on) Heating 1,674 28.74% Hot water 1,460 25.07% Running 2,190 37.60% Car 500 8.59% Total 5,824 100% I'm going to have to do something about this.......
Hi @SteamyTea wonderful stuff. I have also looked at this but from a different angle. I realised pretty quickly that there are about 5 main areas associated with going off grid electrically. Decisions on how your going to live (candles or going to bed when it gets dark. How your going to cook, wash and so on.) Total energy used per year. Peak power requirement Production source Energy Storage. We only have electricity. no gas or oil or wood burner. We have PV, ASHP and MVHR and Electric car. We produce about 6000kWh per year We use about 4500kWh per year We buy in about 3000kWh per year Just over November we purchased 500kWh If we could go off grid by storing all our PV energy whilst producing the peak power requirement and not have to generate any extra over the winter and do that for about £20k and keeping our existing life style I think we would. Problems we face are Size and cost of energy storage Supporting peak power demand Storing long term, the energy produced in the summer, for the winter. Saying all this things would dramatically change if the building would hold it temperature over the winter and we stopped using high power equipment in the kitchen M
Hi @Triassic Re Solar. Fixed on site or mobile? What you want it to serve? (lights? computor, kettle??) What amount of storage do you expect to need (storage?)
