Everything posted by ProDave
Recommendations for breathable roofing membrane?
ProDave replied to Crofter's topic in Roofing, Tiling & Slating
So you are proposing putting the plastic strip on top of the membrane. So any water running down the membrane would run UNDER the plastic strip, and drip off in an uncontrolled fashion and may or may not drip into the gutter, it may just run onto the cut edge of the OSB? By putting rhe plastic under the memnbrane, any water running down the membrane passes through the slot vents over the formed edge of the plastic into the gutter, keeopnf the fascia (and any exposed cut edges of sarking) nice and dry. The edge of the membrane is sandwiched in between the plastic strip and the plastic slot vents, and secured by the nails holding the slot vents that go through all 3 into the top of the fascia board. I have detailed a similar thing for my box profile roofing which I will take a picture of and post it here later. -
I'n sure you will read the post title and say NOOOOOO you can't do that. But it's not quite that simple. My posi joists run sideways across the whole width of the house, a total span of 12 metres, with two supporting walls. At the very front and very back of the house, an "extra" posi joist makes the same "span" but it's not really being used as a joist, it's helping to support the walls of the upper floor. Here is a picture: So hidden behind the Intello membrane are the front walls of the house. The posi joist is set roughly 2/3 above the wall and 1/3 overhanging in front of the wall. The upstairs wall rests on it in exactly the same way. (the intello membrane is the "tony tray") So the joist is not supporting any weight in the conventional way a joist would, instead throughout it's length it is in compression from the weight of the wall above. Now the problem I have is that it overhangs the wall by about 60mm. I want to create a 50mm service void for pipes and cables. I have fitted one such batten to illustrate the problem, that the posi joist completely closes off the top of the service void so I can't get any pipes or cables through. On the basis this is not really a "joist" the way this one is used, I cannot see an issue with drilling where required up through the bottom chord of this "joist" to allow cables and pipes through. What do others say?
Interesting thread. If I were DIYing a heat recovery system, I would not get bothered about the regs. All you have in essence is a cold water supply pipe running next to a waste pipe, nothing against that in the regs. the fact you [cough] solder the cold water pipe [/cough] to the waste pipe makes it no more likely that waste water will contaminate the cold flow. My thoughts, It would surely work much better in a long horizontal run at a shallow fall, feed the cold water in at the outlet end and take the warmed water out of the end nearest the shower trap. On the basis the water will flow along the bottom of the pipe, just a couple of heat collector pipes in a straight line following say the bottom 1/3 of the pipe rather than wrapped around it. Now I can see this working for a shower, to pre heat the "cold" feed a little bit. and having an individual heat recovery unit for each shower, feeding the cold feed to that shower. But what about a bath? A bath uses a lot more water. It lets it all go qickly when you pull the plug, and even if you had a heat recovery system where is the warmed water going to feed? So it seems only a viable idea for a shower then? for a bath you need somewhere to store the heat and a heat pump to extract the heat from it. I know, why not just leave the water in the bath after you have finished until it has gone cold (wared the room) before pulling the plug?
Do you mean this?: What we have is the fascia board set at a height so that allowing for the ventilator strip, it is at the right height for the bottom tile to rest onto. So that usually means the top of the fascia board is higher than the sarking board would be if it carried on down. Some roofers will cut the sarking board just below the bottom batten and have the bottom section of sarking angled onto the top of the fascia. What I did was bought plastic eaves boards (not the proper name but I don't know what the proper name is).They are as cheap as chips from TP something like £3 per 1.5 metre length. So the plastic eaves board fixes to the top of the fascia, and the plastic extends up the roof by 8" or so giving the "kick up". the membrane lays down over the top of this. Then the vent strip goes on and the edge of the membrane then gets trimmed off with a sharp knife leaving the edge of the membrane securely fixed and the plastic eaves board directs any water out into the gutter. -
Welcome back. Glad you found us in our new home. I agree with Nick, it would be good to hear how the boundary dispute got resolved, and we look forward to seeing the build progress.
Is the wall strong enough to withstand the water presure? I am not doubting your bricklaying, it looks very good, but fill that with water and you have an outward pressure on the wall, and cement is not very good in tension. For that reason alone I would be loking at a fibreglass pond liner cast in place, if nothing else to add to the strength of the wall.
What's your reason for 3 port valves? Yes I agree they are quite clever the way they work, they also give a lot of trouble and in a multiple valve system designing the controls for them can be interesting. I prefer individual 2 port valves for each individual circuit, a lot more reliable and less complicated. You can also get normally open (energise to close) 2 port valves if that helps.
Ventilated cold roof - can it ever be airtight?
ProDave replied to Stones's topic in General Construction Issues
It was a common problem in older houses that the roof space was not ventilated well enough, so as soon as you introduced more loft insulation, condensation became a problem in the roof space. A lot of old cottages up here are built this way, then with walls lined with plasterboard, open to the roof space. If you remove a switch or a socket you are greeted with a howling gale of cold air coming through. For a low energy house today I would not consider a cold roof. Warm roof all the way for me. There would be far too many details to try and make air tight, not least any light fittings and even the loft hatch. -
Green Homes Expo, Inverness, 18th June
ProDave posted a topic in General Self Build & DIY Discussion
Just had this by email http://energysavingtrustscotland.org.uk/2PT0-8TCD-5CHS60SC9/cr.aspx Not sure if it's worth going or not. But at least it's "up here" Might be interesting to some of the other Scottish builders? -
Yipee, you were lost but now you are found
ProDave replied to lakelandfolk's topic in Introduce Yourself
Welcome back, glad you found us in our new home. -
My garage roof has been exposed with nothing more than the VP400 for 8 months now. Not a drop of a leak even over winter. Once I get the cladding and render finished I will be tiling that. The roof of our sun room will be left exposed even longer so that one I have also sheeted over with some left over DPM to give another layer of protection to the VP400
No, mine has 100mm thick wood fibre board as the "sarking" and extra insulation. Then 9mm osb goes on the inside (to hold the insulation in) before the service void and plasterboard. Which membrane are you using? if it's the VP400 that I have, it's as tough as old boots and you won't tear thart.
No dwangs in my roof and none specified on the drawings. P.S a question out of curiosity, why choose 42 degree pitch? 45 degrees is SO much easier for marking out and cutting.
Has anyone mentioned diggers are great for putting in fence posts. Position the post, get it level, a couple of taps with a sledge hammer so it's in a little bit and won't fall over, then push down with the digger bucket and one post securely in the ground. And back to the size question. Are you expecting to find any rocks in the ground? I pulled this little pebble out of the ground when digging my foundations, I am not sure a smaller machine would have lifted it
Click on your user name top right and select "profile" The profile picture is at the left of the header bar. Just to the bottom left of the picture is a box to click on to give you the options to upload a picture from a file on your computer or from a URL
Okay I am going to ask a VERY daft question. Can the ecologist not go INTO the loft space and have a look for any bats BEFORE you strip off any tiles? Remove any bats present or declare than none are present, then let the roofer strip the roof on his own. Why make things complicated?
A bigger machine will dig the same hole quicker, it can lift more soil per shovelfull. Having the longer reach means you have to move the digger less when digging a trench. I found for moving soil (without a dumper) the dozer blade was the answer. Pile up a good 10 bucket loads in front of the blade and push. the larger machines have a bigger dozer so can move more, but the really big machines tend not to have a dozer at all. When you start pushing, some comes out the side, but you soon end up with a tramway like this and then you lose very little on the way, and it's easy to go back and clear up when you are finished. My site insurance covers the digger. The bit to be aware of is all those neighbours who say "I see you have a digger....." I declined to do any work for others because then there would be no insurance cover off my own site.
Another caution about "12V" stuff is a battery on charge can easily be close to 14V. One example of this was Sky once made a mini sky box that ran from 12V but they would have a habit of blowing up if connected to a battery on charge at close to 14V. Motorhomes were the big problem and anyone using one in a motorhome was advised to unplug it when driving the vehicle which was when the charging voltage would be highest.
Just man up. I carried all my roof tiles to the roof up a ladder.
Isn't at least one of the Ford Transit variants rated to tow 3.5 ton? It's regularly mentioned on the boating forums for that reason. If you are driving a vehicle over 3.5t for private use the tachograph laws don't apply. Or at least that's what I was told on the two occasions i have hired 7.5t vehicles for private use. You are also exempt from the goods vehicle operators licence if it's for private use, e.g you see a lot of 7.5t horse boxes. but I guess that doesn't help you if it's business use.
And pre 1960 has the advantage of no MOT either. (I would have a series 1 Landrover if I could find one at a sensible price)
It is possible to get a fork lift attachment for a digger to lift stuff, but it would not be very good on an old machine like mine that tends to be a bit jerky in its movements. They are good for picking things up with slings or ropes, I used the digger to lift the treatment plant into its hole I wouldn't have wanted anything smaller than my 3 ton machine. On the other hand the builders I used brought their 13 ton machine to pour the concrete (for its greater bucket capacity and much longer reach) but it was very tight moving that around our site so that size would have been too big for general use on our site.
I will post my off the peg unusual take on vehicles. We are being driven (excuse the pun) to smaller and smaller less powerful and less poluting vehicles. That's fine for personal passenger transport, but a big problem when you want to shift stuff or tow something. I do a lot of both and my Subaru Forrester does the job well, but it's very old now and won't last much longer. As we head towards retirement I can foresee a time when we don't really need a car each, so the one shared car will probably be something small and low emission. That is part of the reason I bought my old Landrover a few years ago, Made in 1972 it is a "historic vehicle" so the road tax is £0. Comprehensive classic car insurance is £80 per year. It's rebuilt on a new galvanised chassis so that should outlast me. So it's just a case of fix things when they break which is all basic engineering, no electronic gizmo's to spell a premature end to the vehicle due to silly costs. It's rated to tow 2 tons. So I can foresee a time when we have one nice modern small car, and the Landrover for the towing and when we both want to go to different places at the same time. Of course the Landrover is anything but low emission, and it drinks petrol like it is going out of fashion, but the point is, in all other ways it is cheap, and it won't be doing much mileage. And I know for a fact it is already worth more than I paid for it, another advantage of being old, it won't depreciate in value. It's my way of sticking two fingers up at the "establishment" that is trying to force us to drive tiny under powered cars that can't tow anything or carry a decent load.
I've just done some sums. So you paid £4K for the lease of the plot, £9k to build it, and £90 per month ground rent for 20 years which is another £21600 So a grand total of £34,600 for 20 years, or an average over the period of £144 per month It's probably like owning a boat, you should NEVER add up all the costs of ownership and never ever write it down.
