Everything posted by ProDave
Were you planning to set it up and commission it yourself? If not you will need a gas safe engineer and he will be capable of changing the jet and setting it up.
@Tennentslager Are you saying your cheap Machine mart stove is just a "tin box" with no fire bricks to line the fire box? I am thinking SWMBO is thinking of a WBS for our static 'van, but I don't like the idea of one with no fire bricks as surely the sides and back will get much hotter?
- 20 replies
- anthracite
- heat output
The sparrow's share should be the input less efficiency so say 80% efficient, the sparrows get 20% Or have I got that wrong?
- 20 replies
- anthracite
- heat output
I would suggest you go for a pretty standard timber frame design which is what we mostly "do" up here. That will be the standard stock house design so should be easy to sell. If you do what we did on our last house, that is pay a builder to build the shell then do the rest yourself you still have plenty of scope for doing work yourself. 12 years time is a long time so I won't even try and predict what the market will be doing then, but if someone had asked me 12 years ago when we had just completed our present house, I would never have believed 12 years on it would be almost impossible to sell.
300mm of MOT1 and 50mm of base layer tarmac. I expected this to get trashed by all the delivery lorries, concrete lorries etc, but it hardly touched it and eventually I will just put the top layer of tarmac onto it.
I would be interested in how you find the insulating collar. Particularly with a roof with counter battens then battens, almost all of the thiickness of the roof window will be outside the insulated makeup of a warm roof, so I feel it needs something. However if that skinny black thing in the picture is the "collar" it looks a rather pathetic attempt and I feel it should be possible to DIY something better. On the one I have done so far (cheap 3g window I would not recommend) I made a surround out of 20mm wood fibre board that was left over from cladding the back of my garage. Certainly better than nothing. I found you have to pay a lot to get much under 0.9 U value for a roof window. Have a look at the eye watering price of the 4g Facro offering.
Interesting Design Features ... Or Not
ProDave replied to Ferdinand's topic in New House & Self Build Design
Looking at the floorplan, the facing dormers are bathrooms. As I thought, the living room is at the back, which if the plan is "north up" faces East, so your average working familly will get home of an evening to a living room and rear garden in shade. Still, the two bedrooms at the front will be overheated by the afternoon sun to ensure an uncomfortable nights sleep. I wonder what the floor plan of the other 3 is like? they at least have a south facing garden.- 11 replies
- new projects
- design
But the houses are mirror images, so at best one will be optimised for the sun and the other not. More likely is the orientation of the sun never entered the designers thought process so both probably get a north facing living room and south facing utility room.....- 11 replies
- new projects
- design
So £6400 for a 14KWh storage system. Lets be generous and say I can use all 14KWh of stored energy from it every day, saving about 15p per KWh compared to the grid, so saving £2.10 every day. That's a maximum saving of £766 every year, so will take 9.66 years to pay for itself. How far will the batteries then be from end of life and needing replacement? Numbers still not stacking up for me I am afraid.
Assessing the quality of a laid tile floor
ProDave replied to Fallingditch's topic in Floor Tiles & Tiling
Actually I think you can. I know a good tiler, and if the floor is not level, he will tell you, and tell you what needs to be done to make it level before he starts tiling. -
Not sure if this has been mentioned before, but here is a house, 3D printed in 24 hours
ProDave replied to Onoff's topic in Bathrooms, Ensuites & Wetrooms
The rubber washer is the seal, so it should not need anything else, and should not need to be especially tight. -
I have always found it easier to start at the destination (entry to treatment plant for example) which will usually have a fixed depth, and then work that backwards towards the house, and see what sort of sensible fall you can achieve without the pipe getting too close to the surface.
Help me with my little penetrations, please.
ProDave replied to ToughButterCup's topic in General Structural Issues
Here was my list: Two foul drains into the house. Water in Water out to outside tap Electricity in Electricity out to shed and treatment plant Telephone Data cable (spare phone cable) Hockey stick duct for gas pipe to kitchen island Hockey stick duct for tv aerial cables etc to under stairs "A/V hub" cupboard The only ones that had to be super accurate where the drains.- 13 replies
- services
- marking out
Help me deal with a neighbour!
ProDave replied to hmpmarketing's topic in General Self Build & DIY Discussion
So get the lines removed and see where he parks? My guess is he only parks there because he knows if he doesn't someone else will. If it ceases to be a parking space, he might just use his own drive. I had a friend who used to park on the road which as it happened was closer to his front door than his own driveway, simply because if he didn't park there, someone else would. -
The access in that photo is not as bad as it looks from the plan. As long as nobody is parking to block the access to No 16, then even with his van in the parking space, it looks like you can get into your plot okay. It's probably only large lorries that might be an issue, and if it's in the daytime when his van is not there.... I can see why the space is where it is, to put it where I proposed earlier would block access to his own drive. I also guess even if the space was deleted, in the absence of double yellows, he would carry on parking there. On ballance I would probably just have a word about being prepared to move or not park there when you are expecting large vehicles. -
Well if the plot used to belong to No 14, then I would have no sympathy with him whatsoever. He could have divided the plot a bit more logically to have given himself parking alongside his house, but presumably chose not to. He has created his problem, me must deal with it. Unless of course No 14 has changed hands since the plot was divided off? -
British Geological Survey for ground source heat pumps
ProDave replied to vivienz's topic in Research Resources
I discounted a GSHP when I found the cost of the pipe you have to bury, and the cost of the antifreeze to put in it (which is supposed to be replaced every 10 years, where are you going to dispose of it?) Even having my own digger so the install cost would have been minimal.- 2 replies
- ground source heat pumps
- ground survey
Unvented Cylinder D2 discharge pipe calculations
ProDave replied to ProDave's topic in General Plumbing
The blockwork is not rendered, but yes it did burst the face of the block so I will repaint it first. Not sure I want to camouflage the pipe though, I want that to be visible. -
You definitely can't discharge to a dry ditch here. It's like pulling teeth just to get a permit to discharge to a flowing watercourse. One of the things they take into consideration is the minimum flow rate in a dry summer. I even made a temporary V notch weir to measure the summer flow rate.
- 26 replies
- sewage treatment
- cost of sewage treatment
Neighbour "disputes" and access can be a real problem. when I lived with my parents, the front drive where I parked openned onto a service road with double yellow lines opposite my drive. It ws a very common occurrence to get up in the morning and find a car parked, on the double yellows, blocking my drive. Phone calls the the police were a regular thing, but usually all they did was employ some grunt to push the car along a bit and left. They hardly ever put a parking ticket on it, and even once when I pointed out the tax disc was out of date, they took no action. I got so fet up I printed a slightly rude note I used to leave under people's windscreens telling not to park there (not quite the exact phrase I used ) until one day the police knocked on my door and cautioned me for "distributing obscene material" He could be bloody minded and carry on parking there even without a marked space, then it gets messy. -
Yes sorry, holes or gaps for wiring in the battens that create the service void, sorry for the confusion.
Rather than delete it, could the space be turned 45 degrees and slid sideways so it is to the north east (assuming north up) of the space outside No 16 Is there any scope for creating an off road parking space for No 14 in the course of the work you are doing? It's ther sort of thing where I might sacrifice a couple of feet of the plot if it enabled No 14 to have his own off road parking next to his house. Can you get the Highways to come in one day when he's out and "delete" or move the space or would that be a red rag to a bull? -
He's screwing through the battens, through the insulation and into the stud of the timber frame. So if he's got his measurements wring and the screw does not go into the stud, leave it in place and try again.
