ProDave
    427
Everything posted by ProDave
  1. I have said this before, but there is nothing "new" in what this thermostat is doing. All it is doing is mimicking how a mechanical thermostat with an accelerator heater behaves. People shun them now as "old" and "inaccurate" but I am finding our new mechanical thermostat is working very well indeed. To overcome the inherent hysteresis with a mechanical thermostat, they have a small very low power accelerator heater that warms the local environment very slightly when the heating is on with the effect of cancelling out the hysteresis. A by product of this, whether by accident or design, is the modulate. As you approach the set temperature the thermostat turns off, then a short while later back on. As it gets closer to the set point the on duration reduces and the off duration increases. I think what I am saying is unless you actually want a programable capability (different temperatures at different times of day) then it is hard to beat the simple humble mechanical thermostat. At least everyone knows how to work one of those!!!!
  2. You don't see people working outside in shorts and a tee shirt at this time of the year up here.
  3. ^^ For that reason, you should not put Propane cylinders next to a drain, and why gas bottle storage is such an issue on boats (where any gas leak will end up in the bilge)
  4. So the message to anyone reading and about to do their plumbing is DO NOT put the ABV right in between two 90 degree bends. All seems to be working fine and silently now, both HW and heating working as they should. So I will leave it as it is.
  5. What is of more concern to me is we used a total of 47KWh on heating and HW in the week, but the total used in the week was 130KWh so 83KWh on "stuff" so I am looking to find how we can reduce that.
  6. I would love to know the back story. Is this a new house or was it fitted to an older house? Who paid for it and why was it ripped out in preference for a gas boiler just 4 months later?
  7. You could be right. That is the flow and return both coming up out of the floor and 3/4 of the way up the cylinder to where the coil connections are. The ABV is connected between these just above the floor. Above that and to the right is the 2 port motorised valve for hot water The flow rate is relatively high at 15l/min so water is indeed more likely to go straight on, rather than make a 90 degree turn to pass through the (now nobbled) ABV. My guess is the noise was an unfortunate resonance thing, with the workings of the ABV oscillating at the resonant frequency of the coil and making it vibrate. No ill effects so I will see how it goes.
  8. So I have finally got around to trying to investigate this. The one thing I wanted to eliminate before I contact the cylinder manufacturer, is the automatic bypass valve. This is situated in the airing cupboard between the flow and return pipes, immediately before the 2 port motorised valve for the cyilinder, this puts it as far from the heat pump as possible. Adjusting the ABV does not stop the cylinder noise, but it goes through a transition as you close the ABV down you momentarily get silence before the noise starts up again a few seconds later. It is impossible to find a setting where it remains silent. To replace the ABV is not easy, will need a bit of pipework stripped down (didn't think that through enough) so I pondered what I could do to eliminate it. Well what I have done, is remove the top of the ABV, remove it's spring and plunger and put it back together. So now it won't be operating as an ABV but as a permanent bypass and probably way too much bypass. The result. Totally silent hot water heating. Hot water still seems to heat up okay in spite of almost certainly too much bypass. I assume convection ensures enough flows through the heat input coil rather than all bypassing? No detrimental affect noticed on space heating. Even with too much bypass, the manifold pumps seem to ensure enough circulates through the UFH and it maintains it's temperature. What now? Leave it like that? Replace with a new (different make) ABV? replace with a gate valve to give manually adjusted fixed bypass?
  9. If it's monoblock, then what is the "inside unit" looks like a split system to me. Why was it only used 4 months?
  10. You seem to be missing a bit of the model number. It should end in ,A04 (3Kw) .A07 (5.6KW) .A10 (7.7Kw) or ,B10 (7.5Kw) https://translate.google.com/translate?hl=en&sl=de&u=https://www.energieheld.de/heizung/hersteller/viessmann/vitocal-222-s242-s&prev=search
  11. It's a split system so will probably need re gassing.
  12. 12.5mm here. I never see anything else used except where 15mm fireline is specified (garages for instance) and then it's 2 layers of the stuff. Regarding strength though, I have noticed a difference recently. When I did the upstairs, it was "normal" plasterboard, as I had always known it. Easy to score and snap to cut to size. But all the stuff I have been getting for the downstairs (just ordered as normal PB) when you score and snap it, it is much tougher, and looking at the raw snapped edge, you can see hundreds of fine strands of fibre. I have never seen mention of this "reinforced" PB anywhere?
  13. Well it has been exactly a week since the meter was installed so time to take a reading and analyse what has been used. Firstly Hot Water. My meter tells me I have used 23KWh in the week heating hot water. If I take a guestimate that it might be running at a COP of about 2.5 that equates to 57.5KWh of heat, or 8.2KWh of heat per day. Some of that will be loss from the HW cylinder (that will at this time of year add to space heating) Now space heating. My meter says we have used 24KWh heating the house. Again taking a guestimate at a COP of 3.5 that gives 84KWh of heat, or 12KWh of heat per day, or just taken as an average over the whole period equates to a constant heat input to the house of 500W At this point some of you (in the south still basking in summer temperatures) will be questioning why we need heating yet. Well it's been a long time since we had anything like "warm" up here, and for 2 or 3 weeks it has been averaging about 10 degrees, and the house had gradually cooled down to 18 degrees, so apart from anyhing I wanted to make sure the heating worked and was actually capable of heating the house. That heating usage seemed to be mostly in the first dew days as it was gently warming the house up again from 18 to 20 degrees. Now it is up to temperature, the heating does not come on often, so next weeks figures should be interesting and probably more relevant.
  14. Wiring a plug is a "life skill" not taught any more.
  15. I "fixed" a "boiler stuck on" fault the other day. It was the HW motorised valve seized. Removing the actuator and the controls worked and the boiler shut off correctly. Initially the valve was stuck solid but a pair of mole grips got it turning and after several full revolutions it was turning freely. Put the actuator back and it all worked fine. I did warn him if it seizes again he will need a plumber to replace the valve body. I wonder if it was just gummed up with carp and rotating it several times further than the actuator turned it cleared all the debris. for now.
  16. B&B or guest house. I remember when building our last house and not long after we had moved up here, I met one of the community councilors. When he realised who I was, he said "Ah yours is the house with 5 toilets......"
  17. So, devils advocate here, you are having an "all electric" well insulated house. How will you heat the house and hot water? What thought have you put into it so far?
  18. My only comment is £10K for the mvhr. A casual viewer would discount that when desigining a house as an expensive luxury. Mine cost well under £2K Interesting the "solution" to a low VOC sofa, was buy an old one, so some previous owner has "suffered" it's ill effects.
  19. Oh that's sneaky. Hadn't noticed that. but I am sure I have seen others at least including the inverter for £2K. Mine will be ground mounted probably on a home made mount (which will form a shed roof) so minimal cost there. Re payback times, a 4Kw[ system will generate something like 3100KWh per year. Even if you only use half that, it will reduce your electricity bill by 1550 units per year, which at 14p per KWh is a £217 saving. If you can get close to 100% usage, the saving will be getting close to £400 per year.
  20. The ones I was looking at on ebay include the inveter panels and on roof mounting kit e.g this one https://www.ebay.co.uk/itm/173540599051?ViewItem=&item=173540599051
  21. This has been discussed before. First thing, if you are not getting the FIT, then do NOT get them installed by an MCS contactor. You will pay over the odds. You can buy a 4Kwp system for about £2000 at the moment, just get an electrician to connect it all. The key to making it worthwhile is near 100% self usage. Simple things like use large appliances washing machine, dishwasher, tumble dryer) one at a time in the daytime. Easier if you are retired or work from home but can be achieved with timers. Second thing is have a hot water system with a tank (or a sun amp) i.e NOT a combi boiler. This will enable you to divert excess PV not being used to water heating. And later on (I am not convinced the economics are there yet) is battery storage. Also think about panel orientation. All facing due south is not necesarilly best. A mix of E, S and W would give more generation over a longer part of the day so more likely to be self used, than all S that will give a big mid day peak that you might not so easily be able to self use. If you can even save a modest £200 per year off your electricity bill the payback would be 10 years.
  22. There was mention on here once (or ebuild) of someone getting a Spanish slate sample, and submitting it to the planner as a sample of the local slate, and they approved it.
  23. Hi and welcome. I thought building on what is currently "garden ground" was almost guaranteed. Perhaps the bit you are looking at is not considered as part of the "garden" but rather a separate paddock?
  24. Look on ebay. Several people selling refurbished Kwikstage. e.g this one 24M by 5M high for £2660. Would 4 sets of that do you for a little over £10K most of which you would get back when you sell it? https://www.ebay.co.uk/itm/Used-Kwikstage-System-Scaffold-24m-x-5m-inc-NEW-8-Timber-Battens-2216-67-Vat/150993037936?hash=item2327e2ea70:g:kCwAAOxy1klRZVO0 I bought mine for a lot less from a private seller, but had to provide the transport myself.
  25. My 5KW LG Therma V is 15L per min. Astonishingly, this vital information is not given in the installation manual. I had to seek it from their technical support (when it would not operate due to low flow) Installing a flow meter I would say is absolutely essential. Some heat pumps provide a flow meter but not all.
