ProDave
    427
Everything posted by ProDave
  1. £1500 is way too much unless you have a lot of bedrooms. Leave doors open to allow heat to flow upstairs by convection. Our house is perhaps a bit like yours. Whenever the bedrooms get down to 17 degrees we give the wood burning stove a blast with all the doors open to help get some heat upstairs.
  2. Did you find a solution? If not how about this that just popped up in CPC's offers comic https://cpc.farnell.com/pro-elec/pel00550/13a-socket-remote-controlled-1/dp/PL1502507?ost=pl1502507&krypto=VmhK8VsP%2FAlNYDqoJUdgcNtLcm%2Bg9AE83IgIEN86EAZkAAEf0JJfc%2F7h5%2FunKIMXZ2Ztyb7jVhta1wquNKnsk5ZpNOgRpz%2FJMSbxdONiKWK8IhjGUgguocHlODWtw6sI9FfdG%2F96Yez0FgVljoVKhsOgc1D2a19I5I%2Bvxp%2BEbx9Tmier7F%2F%2FSTxZNdSn8xKv5%2FSG0xUgNq0C5CO4m6Z7fP8ZAdnLOYjo3EtKqxbjfYgRqOrInf7O8%2F9XbXDS4PzE4bi8E9R0kbdVb4R%2BxOD1dgRYQTVhR%2FHGn9zTLLddO0FARi1CPYjhAPXfsrBjbu24STsCVMs2lsnjfgjvQK1rs%2FMpcRLm%2BZE%2Fsu3vXvaRctLRWgUmJ%2Fvxucz%2B8n2JBmeisn62oldTg3qp9n8HExZTg4n2f%2FH75yAzWKeoiyN8x68MsWuxMkt3eJf0itDlz9134%2FcbkTFidy8JIOHdCrdSaw%3D%3D&ddkey=https%3Aen-CPC%2FCPC_United_Kingdom%2Fsearch Butcher the remote control so that a relay operated by your light switch operates the On and Off button contacts
  3. Yes, but each gets used less so do not need cleaning as often.
  4. Alternatively detach the hose from the washer and just get one the same but longer.
  5. rather than a trestle, use a section of Kwikstage, Then you can have a handrail.
  6. An E7 or E10 supply has a single dual rate meter so you should be able to switch to any supplier that offers E7 or E10 But the rate they are charging you you might just as well have a single rate ordinary tariff? Does your boiler connect to a buffer or thermal store? The ones that work best with E10 are storage boilers.
  7. small 2 step ladder is good for hopping up onto trestles.
  8. Wait until you get the supply (arrange it's connection sooner rather than later) then you will know.
  9. I am guessing you must be on Total Control tariff to get a 24/7 "cheap" rate for heating? That is a long discontinued tariff and I thought it came with a high standing charge. E10 may well be a better bet if you align the boiler times to the off peak times which come as a morning, afternoon, and late evening burst. The only problem time with E10 is early evening where if you need a boost then it's peak rate. I did predict a while back that this cap would spell the end of a lot of the cheap deals, a case of "be careful what you wish for" I would also be having a stern word with your supplier, explain a "cap" means that is a price that you cannot exceed (and your tariff was not exceeding it) It is NOT a price you have to raise all tariffs to reach.
  10. Dehumidifier and mvhr on if you have it. We were painting 2 days after the plasterer left it dried so quick.
  11. But does that not assume it is always delivering the rated 9KW? I would have thought the actual output would vary somewhat so you can't really measure the COP unless you also measure the output (which you could do knowing the flow rate and flow and return temperature)
  12. Why open? so inefficient. How about an enclosed wood burning stove and twin wall flue system?
  13. Are you on your own or near other houses? £12K even with a new transformer sounds very steep. A local near here paid £10K which included undergrounding about 200 metres of 11KV overhead line, provision of a new transformer and the supply. If there is an existing transformer can you avoid the need for upgrading it by accepting a lower KVA supply rating? I accepted their offer of a 12KVA supply as I am sure if I had asked for more there would have been a cost for upgrading the local transformer.
  14. How can you calculate COP only knowing the input power?
  15. With the new chain saw?
  16. Congratulations, Enjoy the new house and that long planned holiday. I get the feeling your old house is probably not the best rental prospect in terms of yield but that is not your concern.
  17. An en-suite does not increase the amount of cleaning. We use the en-suite instead of the family bathroom, so that needs cleaning less often. It's like the argument if you have more toilets you must use more water, No you don't you just use whichever toilet is most convenient at any particular time. We like to spend time in bed with a cup of tea in the morning, a good view with nobody overlooking us is important. If you don't like an en-suite how about a Jack & Jill?
  18. look out for a batch of joists on ebay very soon....
  19. That's a relief. It will cost you time, but not money.
  20. Embarasing question time: WHO got the measurement wrong on the order?
  21. The 3 year living room refurbishment?
  22. He might be finishing that with only 1 arm....
  23. I am far from convinced about economy 7 Usage so far shows heating and DHW is a minor part of my electricity usage. I use more per week on "stuff" and can't find a way to reduce that. So even if I could do all my heating and hot water on the cheap E7 overnight rate, the penalty is the day rate is a lot more than a standard tariff so I expect the E7 saving would be wiped out by the extra daytime cost.
  24. I would make an en-suite to the master bedroom in both, e,g in the right hand barn, turn th bathroom into an en-suite leaving the shower room for general use. What is upstairs in the left hand barn?
  25. The conversation I have had is he prefers to sell by the pallet of 27 panels and if you buy 2 pallets he will pay for the delivery.
