ProDave
    427
Everything posted by ProDave
  1. A takeover would not surprise me, often happens to start ups with a good idea when someone big wants that technology. A few years ago I would have predicted Kingspan as the new owner.
  2. Yes but how many customers would buy this when promised a "symbiotic relationship" compared to how many would buy it if they were just promised that by clever grid controls it would only use low or no carbon renewable energy to run the heating system? There was also some waffle about bolstering the grid which to me meant exporting power to the grid to cover short term shortages, but if my understanding is correct, please tell me how they do that from a Sun Amp?
  3. It wasn't a question I could not afford it, see post above, none of the timber merchants I have yet tried could offer it, let alone shock me with the price.
  4. Was that on line or from a timber merchant? I have tried the only 2 half decent timber merchants I could find in Inverness, Woodstock and Rembrand and neither seemed able to offer me oak to make door frames with. In the last house I did the same as you suggest, frame made in 2 halves with the joint under the door stop but that was only in pine. Skirtings and architrave will almost certainly be the oak veneered offering from Howdens, subject to seeing a sample.
  5. Yep, I have read it again and am still none the wiser, and I regard myself as reasonably intelligent. When you drop in a word like "Symbiotic" into the description, that to me is a "bamboozle alert" I suspect they mean it only charges the Sun Amps when green, low or zero carbon electricity is available, if that is the case, why not say that?
  6. Now can someone tell me how to make / buy oak door frames to fill a 180mm thick wall without sacrificing an arm and a leg please.
  7. It is a bit of a fail when your "comma separated variables" file, does not have any comma's in it. There is even a clue in the name.
  8. Hi and welcome That sounds like a nice project I wish you well with it.
  9. If I am reading it correctly this is 2 doors into one bathroom which must be "accessible" I believe only 1 door needs to comply. Our downstairs loo, and provision for downstairs bathroom has 2 doors, one from the hall, and one out to the garage. BC have already confirmed that only the door from the hall needs to meet the "accessible" requirements, the one from the garage does not.
  10. This sounds like an "after completion" job to me. Built the (presumably) timber stud internal wall with the required door opening in it, then after taking careful measurements and pictures, plasterboard over the opening (what opening) Then later on with no building inspector to criticise, build the hidden door. My "after completion" list is getting bigger all the time.
  11. On our first build, we dug up a complete car door, and a wheel complete with tyre still holding air.
  12. Just for the record, my LG ASHP has the strainer built into the heat pump itself. It was one of the first things I checked when getting flow issues.
  13. Unless it trips at the point the timer switches on or off, then the fact it is "on a timer" is a red herring. It is so simple to try the pump up a speed, so why not just try that first. As I say I got so confounded by this issue getting mine to work that I put a flow meter in so I could see what flow I was achieving. As it happened I was only under the required flow rate by a tiny bit. Now I know I am comfortably above the minimum requirement and mine has not tripped since.
  14. I think the first question is where is the HW cylinder going? I would be putting it in that double door cupboard on the landing. That puts it pretty central to all points of use, so a manifold in the bottom of thet cupboard and direct to each room should be fine. Far far simpler than multiple distributed manifolds. EDIT just seen the plan for the UVC in the garage. Sory but that is the very last place I would put it, the run to e.g the kitchen would be far too long.
  15. They are both expansion vessels. One will be for the heating system, probably the red one, and one will be for the unvented hot water tank, probably the white one. Turning the pump up higher is an obvious thing to try I would run it as fast as you can without it becoming too noisy.
  16. That looks like a fantastic plot. Care to post the house design yet? If you want to build as close as possible to the old house you could leave off the wall finish on that elevation until the old house has gone that might enable you to get a bit closer?
  17. Yes I would say blocked stink pipe. Which would be unusual as in most cases the stink pipe also serves the upstairs bathroom(s) The fact you have not mentioned those suggests this is just a stink pipe. If you are going to replace it anyway, cut it off a metre or so above ground and rod down the pipe with drain rods to try and clear the blockage, but if it has collapsed underground then it will be start digging.
  18. This is going to be a good thread. So a set of bookshelves, and when you remove the "special" book, the shelf opens to reveal a door. @Onoff will design the actuators for you. P.S This must be the most inventive idea to get the council tax band down, hide half the house from view so he values it as a small house......
  19. Do you have motorised valves? Are they opening quick enough? Mine expects to see sufficient flow just 10 seconds after switching on, that is a tall order for a motorised valve to open that quick.
  20. Most folk just quickly learn how long it takes to heat up, and use a simple conventional programmer to turn it on for instance 2 hours before you want it to be warm. At the other end of the day you can turn it off before you have finished as it takes a similar length of time to cool down. Why make things complicated? The few times I have seen a complicated controller, it is not being used because nobody can understand it.
  21. Reminds me of an old friend. His wife threw a pan at him, he ducked, and it went through the glass of the back door. Of course the broken window was his fault for ducking,
  22. This one? https://www.zoopla.co.uk/for-sale/details/47684293?search_identifier=5fc46c9efda757debeac1c888138d11d Planning for 2 dwellings
  23. Looking for the next project before you have finished the current one is the sign of a serial self builder. Help is available.
  24. And that quote gets "gobbledegook of 2018 award" Anyone care to have a guess at what it actually means?
