ProDave
    427
Everything posted by ProDave
  1. So now +12 today, 24 degrees higher than last weeks low. Today was the first day since Christmas that the hosepipe was not frozen, so both cars cleaned today to get some of the grime and salt off them.
  2. When mine (different make) started to seem non optimum, investigation showed the stainless steel inlet vent has a Gauss filet on the input that had become almost entirely blocked with dust. Cleaning that out restored normal operation and is now on my annual maintenance list.
  3. What worktop? Anything other than a simple straight run, I would get a trusted joiner in to cut and do any joints. That is just what I did with our island, a joiner I know and trust did a very good job of all the cutting and finishing of the oak worktop, far neater than if I had tackled it myself. Likewise the main worktop was stone on on supply and fit contract.
  4. My only thought is you will discharge the battery you are connected to, so they will end up imballanced. So connect it with large croc clips and periodically move it to the next battery so they all get discharged just a bit until you get the main inverter / charger sorted.
  5. Excellent news Jeremy. The 0.5L expansion vessel you mention seems tiny? What is that for? That won't take up much expansion of hot water. Compare that to something like a 25L expansion vessel on a typical UVC and even the closed UFH circuit in our house has something like a 10L expansion vessel.
  6. ProDave
    Damp advice
    Chances are, a lot of the "damp" is condensation due to moisture in the house hitting cold walls and possibly not enough heating in the house or ventilation of the house. If you dared to ask a "damp specialist" then of course they will say it is damp and give us lots of £££ to fix it.
  7. Those figures would leave me with very little confidence at all
  8. Is that not a WEE responsibility for the manufacturer?
  9. Nice to hear from you again Jeremy. In your absence a few other people have had failure's with sun amp's and inability to get them fixed in any way. This has left some of us thinking this is a promising technology let down by in many ways poor design and certainly not been designed to be servicable in any way. Compare this to a stainless steel UVC and an immersion heater. The heater is an easy swap that any plumber can do, the expansion vessel likewise is servicable and the tank itself rarely fails and usually has a long guarantee. Given the potential to fail, and then it's irrepairable and out of guarantee, then you really really really have to want a Sun Amp to tolerate these issues compared to an UVC.
  10. The planning system NEEDS to be streamlined to scrap all these reports about newts and bats, complicated and unecessary conditions etc. ALL they do is result in exactly the same building being built, but at extra cost and time to the applicant and extra work for the planners. All at a time when the planning system needs streamlining to make it quicker and more efficient and pass more planning applications quicker.
  11. THAT is the bit that is so wrong and would be so easy to correct. No wonder the cheaper generators are making big profits, because the system over pays them, making people talk about windfall taxes to punish them. All that is needed is change the way the market works so they all get paid a fair price for what they generate but not excessive, and no excessive profits to upset anybody. I would love whoever devised this market system to explain why they think it is right the customer should pay inflated prices and thus pay excessive profits to the cheaper suppliers. We keep being told the more renewable generation we have, the cheaper our bills will get. Under the present system that is a LIE. Prices won't get cheaper until there is enough renewable to power the lot and we don't need the gas generators to bid for any.
  12. This was a relevant recent thread worth a look. For the roof they have insulated with wood fibre between the rafters The interesting bit is they have done half the roof with a ventilation gap and half without to see if it is necessary with this type of roof
  13. And attached. and in a mild climate. Your challenge: Achieve that low usage in a detached house in the Highlands, where tomorrow it is forecast to just creep above 0 for the first time in 2 weeks and has been down to -12 in that time. I often speculate just how low my heating bill would be if i had built an identical house in your climate. I am using 1400kWh per year here for heating but because none of that is off peak, all standard rate that's just over £300 per year for heating.
  14. I would first pour a few cans of water down or even run a hosepipe. Where does that void under the bricks go? If water runs forever it could be a bigger void? Try probing into that space with drain rods? Pure speculation, that conservatory has been built over the foundations of some previous structure. Can you see any similar houses in the area that look to have some form of original looking single story building on the back or an outside privy or coal house etc? That might give a clue what was there? Old OS maps from just after the house was built might also be useful.
  15. I think it is meant for stripping tv / satellite coax cable.
  16. That looks to me like there was a raft foundation but that rough edge looks like it may have been hacked back perhaps at the time the block paving was laid? That lone brick under the concrete slab is a curiosity, just where the hole is? I would carefully enlarge the opening to truly reveal the extend then try and get some pictures sown in the hole. I bet that has never been seen by a building inspector, but that is not unusual for conservatories.
  17. someone needs to work out a venn diagram of how they overlap? Excellent summary. Shame the people that write our net zero plans don't bother to analyse the real situation and work out that their plan can never work.
  18. Yes swapping a gas boiler to ASHP will reduce CO2 emissions but I get the feeling people expect it to reduce CO2 emissions to zero. It won't, at the moment and won't until we are generating all electricity from non fossil fuel sources.
  19. I would want to know where that downpipe is going and where it expects the rainwater is going. It is either a crude soakaway built way too close to the conservatory, or there is a pipe to take it away that has failed. Either way to me it looks like a lot of soil has washed away and I would want to be lifting more blocks and digging a proper hole to investigate exactly what is happening before deciding how to fix it.
  20. Buy a second one of the type you have and get busy on it with a file to adapt it to fit the other one.
  21. That is a difficult and expensive solution looking for a problem to solve. Especially on a new build why would you? and most certainly not as a retro fit.
  22. If I had received that bit of timber from the merchant, I would either have rejected it, or chosen to use that particular piece in a place where it was being cut into short lengths. Same as I do for a warped bit of timber.
  23. I used Unistrut to build the frame for mine. FAR cheaper than any of the aluminium PV mounting rails. Some have used scaffold poles or similar.
  24. A garage ceiling built to modern regs should be 2 layers of 15mm pink fireblock plasterboard, with the joints on both layers staggered. I very much doubt you have that much now. So best bet is take down the plasterboard ceiling you have, insulate between the joists with rockwoll etc then re board with 2 layers as above to modern specs.
  25. The push at the moment seems to be trying to persuade people to swap gas boilers for an ASHP. A perfectly set up ASHP should be a little, not a lot, cheaper to run than a gas boiler. If not perfect it could well cost more to run than the boiler it replaced. So trying to persuade people to "invest" in a new heating system when they are quite happy with their old one and at best will only get a marginal saving, it is no wonder they are not queuing up to take up the offer. you have to WANT to do it for other reasons, the main one being reducing CO2 emmisions. So are we targeting the worng market? Why not instead target people using electric resistance heating currently, like electric panel heaters, storage heaters, or even electric boilers? Those users would see their heating use of electricity drop by about 1/3 if they swapped to an ASHP, saving them real money, not just marginal, and would reduce strain on the electricity grid which is already struggling at times. So that would give an immediate reduction in electricity used for heating, and reduced electricity use would mean fossil fuel generation required less frequently so an indirect saving in CO2 emmissions. But the point is the customer would see a very real reduction in running cost not something marginal, and rather than increasing electricity use, it would be reducing it. The boffins could do the sums to work out the CO2 reduction per kWh of electricity saved * and market it as CO2 reduction. * It IS CO2 reduction because until we reach the point where no fossil fuel at all is used for electricity generation, then each 1kWh of electricity saved at the moment is 1kWh less generated by fossil fuels. By the same token, installing an ASHP increases the electricity you use so that will increase fossil fuel generation at the moment so WILL result in increased CO2 emissions.
