Everything posted by ProDave
Missing chimney breast in the downstairs flat
ProDave replied to Kitane's topic in General Structural Issues
How do you know the chimney does not continue to the lower flat? It looks to me that where the basin is in the lower flat could well be the stack in the corner and boxed out to make a flat wall across to the window for the basin. You will never know without an invasive survey downstairs. If this is all that worries you, forget about it. -
"Efficiency" does not matter. The only thing that matters is £ cost perk kW of generation capacity. How do lots of individual roof tile size PV panels compare cost wise to fewer large panels?
What next for heat pumps after BUS and MCS?
ProDave replied to joth's topic in Environmental Building Politics
The housing market needs to wake up, and surveyors place a lower value on houses with a poor EPC to reflect the extra running cost, or money you are going to have to spend to bring them up to a reasonable standard. the idea of paying the same money for a quaint old house. then spending lots upgrading it, and it makes no difference to the value is just bonkers. Re fuel poverty. If you are struggling to heat your house, then paying a lot of money to swap your gas boiler for an ASHP which at best might give you a very marginal saving in running cost, and at worst will cost you more to run than your gas boiler is not going to be a high priority is it? -
Once it stays below 0 even in the day, there is little humidity in the air and I rarely see the ASHP need to defrost. I think our record was -18 one year, and a friend with a Cool Energy ASHP (that I had wired for him earlier that year) phoned me to say it was not working. Looking up the error code given it was "outside temperature too low" so I guess not all of them work in real cold. Something worth checking. It is no particular hardship at these temperatures, but that is the benefit of a well insulated house, I am not worrying if I can afford to have the heating on like many do. It only becomes a nuisance when you want to go out, and the daily ritual of shoveling last nights snow away. At least i am getting some exercise. If I was not doing that and it was less cold, I would probably be chopping firewood instead.
Interesting video. But lets be honest all they have done is turn a hopelessly poor old building up to the EPC standard of the pretty ordinary 40 year old house. No particular attempt to improve air tightness, and no testing of that. I would like to see something like this taken to the next level. Install MVHR. Lets find out once and for all does MVHR improve the energy efficiency of a not particularly air tight house or not?
Indoor Humidity
ProDave replied to Marko's topic in Mechanical Ventilation with Heat Recovery (MVHR)
34% in the living room here. It's been sub zero for several days now, not much moisture left in the air. -
Yesterday the daytime high here was -5C Next few nights are going to be cold, -20 mentioned as a possibility. Nowhere near that cold yet. I expect when I take my Friday meter readings this might be the coldest week of the year. But toasty warm inside with the stove burning nicely giving the ASHP a rest (not that it needs one)
Ours is also a convection stove and has very small distance to combustibles figures from the back and the sides of the stove. But the front is a normal door, with a large glass window, and that is just like any other stove, it radiates a LOT of heat and not at all surprising it could set fire to something with a low flash point close to it. Oddly enough there seems to be no requirement to publish a "distance to combustibles" figure for the front of a stove.
Please help identify this DNO fuse
ProDave replied to sharpener's topic in Consumer Units, RCDs, MCBOs
BS88 usually. You would normally only need that sort of information for an EIC. -
Distance to flammable materials was one aspect that BC checked meticulously on their final inspection.
Thoughts on Different Brands of Unvented Cylinders
ProDave replied to steveoelliott's topic in General Plumbing
Don't come back complaining about the quirks and limitations of hot water from a Combi Vs an UVC. You were warned. -
I would NOT trade a UVC for a combi. If you have a defective UVC change it for a new, better make of UVC. Who is offering this combi and why? -
Who is offering you this combi replacement and why? Many of us here are happy with Telford stainless unvented cylinders. -
I had had enough of being a landlord. Having previously owned 2 buy to let properties for a number of years, I have a low opinion of the average tenant and their inability to look after a property that they do not own, and the (usually avoidable) repairs needed at each change of tenants. That and the added raft of legislation a LL has to comply with, including paying to be registered as a LL (In Scotland) The final straw is end of no fault evictions, so if you let your house, then decide you do want to sell it, don't bank on being able to evict the tenant quickly, if they don't respond to you asking them to move out, then it has to go through court to get an eviction order etc. You might be fine with all that, we were not, we just wanted it sold but circumstances dictated what we had to do, but thankfully it all ended well.
It is NOT that simple. HMRC just take your original purchase price (which could be a LONG time ago) and your sale price, and draw a straight line and assume the gain has been linear throughout your ownership. Then the period of time it has not been your principle residence is charged pro rata CGT. the actual calculation to make it so is in true hmrc fashion a bit more complicated. The point of that being there could be a house price crash and you then sell it for less than it was worth at the start of letting it, but tough the hmrc calculation still shows an overall rise since you bought it donkeys years ago so you still pay on the "gain" while it is let. CGT allowance is now pitifully low so you almost certainly will be liable for some CGT and it has to be paid very swiftly after the sale, no more waiting until the end of the financial year as it used to be. We did this with our old house, as at the time we could not sell it, and like the OP we could see old house from our new house. It was not what we wanted to do but the best offer we had at the time and I would not want to do it again. BUT 6 years of rent from it before it sold did wonders for our final retirement position.
MCS is the root of the problem, I am sure many agree. Their heat loss calculations often come up with silly answers and result in an over large heat pump, particularly for new builds, and their pricing structure seems to end up with a very large figure, even after deducting the £7500 grant, leading many to conclude the only person benefiting from the grant is the installers who pocket a very large sum for the install. A TOTAL re think is needed. Zero VAT on heat pumps even to retail customers would be a good start. Get rid of the MCS monopoly. Allow anyone to install them, and then submit their invoice for parts, labour and material to receive some of the cost back as a grant. Make fitting of ASHP's permitted development under planning. Of course it won't happen, too many vested interests. Ask Norway how they do it? I bet they don't have anything like MCS? First thing is ensure from NOW (not some date in the future) all new builds have a heat pump for heating. Just write it into building regs. No heat pump, no completion certificate. No bureaucracy, simple. Or just make a properly calculated SAP EPC A mandatory for new builds. Same for at least some PV on the roof. Swapping out boilers for heat pumps is not proving value for money under the current schemes, concentrate on new builds first then find a better way to encourage heat pumps in existing houses. -
Thanks,not seen that sort of offer before. All the kit and paperwork for free and you just pay your plumber and electrician to connect it all. Surely for a self builder that has to be the best way to avoid the sort of silly prices a lot are being quoted?
Switching Electrical Supplier Before Meter is Installed
ProDave replied to The Noust's topic in Electrics - Other
I would escalate this to a complaint to the CEO of Octopus. Have they explained what the problem is? I don't believe it is just because you are in rural Scotland though getting a smart meter to communicate may not be a trivial matter (but at least it would be a meter and you can get on) -
And what price has MCS quoted you? Have you looked instead at just buying a heat pump and your plumber and electrician fitting it? Assuming it is a new house what does the SAP say about heating requirements?
Is this a light on the actuator or on the UFH control box? Post a picture of both the control box and the type of actuator you have so we know what you have please
Neighbour building an extension, must he render my side?
ProDave replied to qamar's topic in Planning Permission
What makes you think he is intending not to render the side facing you? Are you suggesting you will deny him access to your land to do that? -
Not sure about England, but in Scotland the only way to do less than 6 months is a short term holiday let.
Kitchen sink drainage directly down in slab or outside?
ProDave replied to Sunil237's topic in Waste & Sewerage
At what point in the construction did you tell the builder you wanted internal drain pipes? -
The UK’s electricity was the cleanest ever in 2024
ProDave replied to Alan Ambrose's topic in Environmental Building Politics
The US president elect wants to "turn off the windmills" No I don't support that view but the next 4 years could be "interesting"
