Everything posted by ProDave
Do NIE ask for calculations? If not just pick a low figure like 12KVA and re apply. They are not going to connect you with a thinner cable just because you ask for a low rated supply. If they question the change, tell them your original estimate was made by someone not understanding how it is done, and now you have a more accurate understanding of the energy needed for your house.
And you could also add that he did not serve the correct notice on the owner of the land (as you would if applying for PP on land you do not own) so the application should be invalid because of that.
So it is just the handle broken. A smaller pair of mole grips would be a closer match to the other handle.
In your formal objection to the planning application, state that the applicant does not own the land he is proposing to use as an additional parking space, so he would not be able to create that extra space, thus the application if approved would leave insufficient parking space on the property.
So based on that you requested a 40KVA 3 phase supply and they came back with the big quote? NOW go back and ask what you could have without major network upgrades? In my case the answer was 12KVA single phase which ended up costing me £1K and has proved totally adequate. If I really needed 3 phase here, there would be at least half a mile of single phase 11KV overhead line to upgrade to 3 phase then a 3 phase transformer to install. That is likely where you get the silly high prices.
Curved ceiling / Vaulted rafters insulation
ProDave replied to InspiredSloth's topic in Building Regulations
I am still waiting for the pictures to show me in what way this roof is curved. -
Thoughts on warranty claim for a defective roof
ProDave replied to Paene Finitur's topic in New House & Structural Warranties
There is a lot of water arriving at the left hand end of that gutter, but the only down pipe is at the right hand end? Have you stood outside in heavy rain and observed how the water flows into the gutter and does it over spill? I would be looking to re jig the downpipes so there is a downpipe from the left hand end and try and route the upper pipes directly into that rather than onto that roof. -
I disagree with that and think your chosen AI tool has got it wrong. If the house is at negative pressure with respect to outside, it will draw air in through any leak path, which if anything will draw air DOWN the flue.
Oh yes please (fellow riparian owner)
I bet the outer part of that square is a cover that will just pop off if you get something flat like a chisel under it to prise it off and will reveal some fixing screws. The grub screw is probably to clamp the bar, not hold the handle in place.
Did YOU fit it? If so you will remember how it is supposed to come apart. If not, you are guessing how it is supposed to dome apart. Try taking the handle the other side off?
Can you post the answers to this blog entries "spot the car" competition please?
But given that my daily driver is now a Toyota Hilux pickup, the MG is my economical summer run about.
I miss read the OP that said: "I would like to increase my privacy and build a fence 1meter 60/70cm tall so their car won't look straight in my window." I read that as a fence 1 metre or 60/70 cm high. NOT 1.6 or 1.7 M tall. Sometimes I read words too literally.
I keep going on about housing perhaps because I speak from a position of smugness that I live in a low energy house heated by a heat pump and with solar PV to self generate a lot of our own energy. Compared to out last house, heated by oil, I have saved more CO2 emissions building this house than I would if I stopped driving completely. But even new houses I still don't see the many, let alone all being built to the same standard mine was. So the problem is most definitely not being taken seriously. And that is even before anyone dares suggest how we are going to tackle the old poor quality UK housing stock and who is going to pay. That data set in the OP gave a total figure somewhere of 16% for housing which is where I made my comparison then went on to break it down into subsets which is where someone picked up a lower figure. I think my point when moaning about the future of transport, is moving to a low energy house made no change to my lifestyle, or any change it did make was positive. Any such changes to future transport are largely negative in terms of cost and convenience to the end user.
Generally up to 1 metre tall or less a fence does not need planning permission even if right next to the road. Does your house / estate have any covenants that might stop you putting up any fence in this location?
The fact the gable end is insulated suggests this is a room in roof, so why has the roof not been designed and built as a warm roof not requiring ventilation? SO much easier to detail properly. Is it too late to change to warm roof?
Too much data not presented clearly. The things I took from it though is transport is NOT the biggest contributor, but the way it is being taxed and penalised you would think it was. Instead it is just the easiest to tax and blame and try and shame people into travelling less. It is actually housing that is the worst, why are houses not being taxed like cars depending on their energy usage? And "poor" houses banned from cities? (Rhetorical question not expecting an answer)
Seen it regularly. In MOST houses, take a light switch off the wall on a windy day and you get greeted with a blast of icy cold air coming out. Unless the house is build properly air tight, then all the voids are usually linked by cable and pipe holes all leading to the cold loft.
It is the designer that should specify it, not the glulam manufacturer, they just make what is specified on the drawing. Likewise the installers (should) do what the drawings instruct them to do.
Surely a proper drawing exists somewhere detailing the fixings to be used? None of those look adequate or anything like as substantial as the brackets used on ours, and specified on all the drawings. The fixings of the rafters to the Glulam look inadequate to me as well as the brackets fixing the glulam to the gable.
I would certainly rebuild it and re point it, just so it looks right. I love the way the old shelves got boarded over, still with stuff on them.
We had that in our last house. Sitting during the first gale watching the glass flex debating will it pop or not. 22 years later it is still there no damage and no doubt flexing today in the strong wind.
