ProDave
    427
Everything posted by ProDave
  1. Definitely a good plan. It will have a toilet as well which satisfies your obligation to provide a site toilet for the workers, though you will have to empty it.
  2. No but have you tried Rationel?
  3. Am I the only one not understanding this? The window is 1200 mm but the hole is only 850mm? How the hell did NOBODY notice they had made the hole the wrong size by THAT much? And to be out by that much is there a MAJOR difference between the size shown on the drawings and the window schedule? or can someone not read the drawings and made it the wrong size?
  4. I presume you will be placing contracts for various packages of work? Providing each contract is "supply and fit" of a particular part of the build, it should come to you zero rated. The VAT claim thing is for self builders who (not being VAT registered) cannot avoid paying VAT on materials they buy, so they claim back the VAT at the end. If all you are doing is project managing, not building, you won't be buying any materials like that will you?
  5. That's £3000 per square metre so yes I would say that is steep. Time for a second or third quote?
  6. Not all LED lights are dimmable. You may just have the wrong lamps in them. Or you may have the wrong sort of dimmer switch designed for filament lamps.
  7. Ariel is a washing powder. An Aerial is a device for receiving radio signals. I'll get my coat.
  8. Why is the first lift at head height? Anyone working underneath it would have to stoop? I work on 2M lifts with Kwikstage. If you have that hazard then pipe insulation taped around it with some of that yellow / black striped tape. Kwikstage etc does not have this problemwith sticking out bars.
  9. Aiming to reduce energy use to half of what old houses use, is missing the point and will not get us to carbon neutral. Not unless ALL houses fit a significant amount of renewables. Even our new house is not carbon neutral. The solar PV generates a little more each year than the house needs to heat it. BUT we use more electricity running "stuff" (washing machine, TD, dishwasher, FF, tv's etc etc) than we do on heating. So to get to being truly carbon neutral, our house would need to double it's renewables generation to power all the "stuff" And that's where it gets difficult. Most of the extra generation would be needed in the winter, when it's hard to do with say PV. And if we had enough self generation in the winter we would have a massive surplus in the summer, but the FIT scheme has been scrapped, so that is hardly likely to persuade people to invest in renewables is it? Why scrap the FIT just at the time more renewables are needed? Clear LACK of joined up thinking, My guess is the figures will be fudged. Our house would be classed as carbon neutral because we generate more electricity than it uses to heat the house, so it would "meet the target" They would just quietly ignore all the "stuff" that is really making the house, as a whole package, carbon negative, because doing so we will never meet the target of carbon neutral housing.
  10. I have met some of those Germain (or were they Austrian) Joiners in their "uniforms" We have nothing like that here whatsoever.
  11. My few comments. If you are trying to make cheap to build, don't have the front wall of the kitchen stepped out. Keep it in line with the rest of the house. The cost of that extra space will be disproportionately high. The area of the wc / rear vestibule / boot room / utility seems cluttered and an awkward path through. I don't like a "corridor" utility, no good if you want a "pulley" (clothes airer) I would make the utility just a corridor to the back door (where a window is now) with coat and boot space. The boot room + rear vestibule the utility. Even consider doing what I have, the WC in the utility, so that whole back section could be a decent size utility incorporating the WC. Which way is North? Can't comment on room positions without knowing that.
  12. It still staggers me that houses with a poor EPC don't sell for less, and most buyers don't care. All that has to change. Even the target to get all houses to an EPC C will not make them carbon neitral.
  13. I would not try connecting a socket to the supply to your heat pump. My 2 concerns, that circuit is rated for it's load and probably does not have much capacity spare. Secondly it would be physically hard to connect extra cables into that isolator switch.
  14. Well today, the tap, trap and waste all arrived. Slightly disappointed. the "extension pipe" is not really long enough. Just 200mm This means with a 400mm diameter round basin, the pipe won't reach all the way through the plasterboard into the service void. So instead the plastic compression fitting is going to have to poke through the wall. Not the look I was hoping for. I might even consider changing the trap if I can be sure a different one has a longer pipe. something they don't seem to tell you much about. Does nobody think these things through?
  15. We too have a burn running right through our plot. But we were not asked to provide any flood risk analysis as looking at the SEPA flood maps our plot is not at risk. It correctly shows that the field behind us does indeed flood (though little more than a large puddle) I just applied common sense. Make the finished floor level of the house much higher than the rest of the plot. Basically the vehicle entrance is o the highest point of the plot and that sets the garage floor height and then there is a step up into the house. this puts one part of the house a metre above the ground level. We then used all the excavatred soil to raise the ground level on the house side of the burn, but deliberately left the other side of the burn at it's original level, so if the burn is in spate and is going to over top, it will flood the other side first. The obvious things are keep the building as high on the land as possible, even to the extent of raising the area where the house is built. It is also worth considering the local topography and how the land will flood. The road we are on slopes significantly down to the river that is about 1/2 a mile away and 100 metres lower. It is impossible to imagine any event that would result in standing water here. Whatever level of flooding occurs, it will be running down hill. So obviously don't put anything in the way that would block it. I think flooding on flat, low lying land is very much harder to predict and do anything about. With standing water, it seem sand bags etc are just about next to useless.
  16. Re visiting this old thread, because after working fine for well over a year, in the last week, my ASHP has thrown up 3 spurious CH14 low flow errors. the common theme once more being this happened over night with no demand, just as they did before, so the unit refuses to start in the morning without the fault being reset. So I had another look and think I have a hunch what the issue is. In the summer, I connected a wire to the "cooling" thermostat input to test it's cooling function. That is unused at the moment, but the wire is still connected. Now I previously had an issue with the heating thermostat input being over sensitive, and I cured that by fitting a pull down resistor and a snubber. But I never thought to do the same when i connected the cooling input. It is reasonable to assume they both use the same input configuration, and either will trigger the ASHP to start so it's reasonable both will trigger the same start up checks for flow rate with the same fault mode if a short spurious input is detected. So today I fitted the same snubber and pull down resistor to the cooling thermostat input. I will now see if that has cured it's latest bout of flow errors or not.
  17. It must be 35 years since I visited Barra. When I was there, the Vatersay causeway had only just been completed, and I found I had missed out, two derelict houses on Vatersay had just been sold for £5K each.
  18. The middle dial is set for "comfortable" and never gets moved. Most of the time my HW is only 48 degrees so that would be "bloody hot" but not scaldingly so.
  19. Hi and welcome @Nick A Are you on Barra? That's the only Western Isle I can think of with such a long ferry crossing.
  20. I have always fitted them for comfort, so you know the water temperature won't vary and you don't have to fiddle. I have never thought of them as a "safety feature"
  21. As above. We have two bowls and two appliances all connected to one trap. the pipework above can get a bit smelly if you are not careful. It is the pipe from the half bowl sink that often gets smelly as it's not used much. I tried to mitigate that by putting the trap under the half bowl not under the full bowl, to eliminate a dead, seldom used leg of waste pipe. If the trap is blowing dry then you have a stack ventilation problem. The Klargesters do seem to work. The "complaint" we have with them is the moving mechanical parts immersed in the smelly stuff, and none of us would want the task of repairing something when it goes wrong. The air blower ones are nicer in that respect as the air blower is not immersed and is simple and easy to swap when it needs servicing.
  22. Welcome to the Forum. We call that a "20 minute day" If you don't like the weather wait 20 minutes. Or if it's not raining now, it will be in 20 minutes.
  23. One feature of our plot, is the field behind us floods most winters. Only minor flooding, little more than a big puddle, when the water table gets so high it cannot drain it forms a puddle. What then happens is it starts to flow under our fence, across part of the garden into the burn. To fix that, I installed a French Drain along that fence line with a pipe draining directly into the burn to stop that part of the garden getting waterlogged. We have had a very wet spell for some time now, no torrential rain so no problems, but it has been persistently wet for a long time. Yesterday SWMBO mentioned the outlet pipe from my French Drain was dry, so I went to have a look. Round behind the shed, in the field margin I found this has appeared. All the water that previously would have been emptying into my French Drain is now disappearing down this sink hole that has opened up. It sounds like it is dropping some distance, you can hear it hitting the bottom. At the moment I can't see where it is ending up. It has to be getting to the burn somehow so my plan later is to get a bottle of cheap food colouring and pour that down the hole to see if I can see where it comes out. My guess is it's an old land drain put there previously to drain the field that is now blocked at it's source but the water has found another way into it.
  24. What prices are you seeing from EE? We don't get a three signal at all, but get a good EE signal, but I don't see anything that comes anywhere close to the cheap unlimited deals that three offer.
  25. I could just erect a scaffold tower next to it to take the top off myself.
