Everything posted by ProDave
A few points. You don't get permitted development rights until the house is complete, so that does not help you putting a caravan in your garden. When i applied for planning I put the static caravan on. It came back with the default clause "the static caravan is to be removed upon occupation of the house." (that might not be the exact wording) I wanted to keep my static caravan for other uses. I pointed out to the planners that on the day of completion, I could remove the caravan, and then immediately replace it with an identical caravan in an identical position and it would be permitted development. They then changed the wording to "habitational use of the static caravan shall cease upon occupation of the house" So my caravan can stay but not as a residence.
Send it to me I will make good use of it. Save you the problem of storing it. Or put it in one of the Capri's. Or are they already full as "storage units"?
I remember a case on here where someone put up a 2M fence just off the highway. There was a path, then a grass verge then the fence. A planning inspector visited, stood on the public foortpah and reached out as far as he could. He could not touch the fence. Therefore he deemed it not to be "adjacent" to the highway and took no action.
DHW is heated by the Air Source Heat Pump in a Telford 300L ctlinder with the high capacity heat pump input coil. Topped up using the immersion heater to use up surplus solar PV
Aluminium Lift and Slide Door Recommendations?
ProDave replied to MJNewton's topic in Doors & Door Frames
That slider was £3079. Roughly double what I could have got a local cheap double glazed slider for. But the rest of the house has Rationel and it would be a crime to fit cheap UPVC to the sun room. I am sure prices have gone up a lot since we bought the rest of the windows nearly 5 years ago. -
Yes we have a 5kW ASHP roughly twice what the worst case heating load is. It runs without issue. The WBS is really an indulgence. Partly because fire wood is so easy to get and free here. It is used on those dull wet grey days when even with the house at it's usual 20 degrees you "feel cold" so it is nice to stoke it up for a few hours with free fuel and raise the whole house to 25 degrees and feel snug and warm. It's also a backup form of heat should there be a power cut or something break down. And useful to warm the house quickly if you have come home from holiday to a cold house (about the only time I would actually find a use for remote internet access to the heating controls so you could turn it on a day or 2 before your return)
Must it be aluminium? Would aluminium clad timber be okay? Just fitted this Rationel aluminium clad timber slider. Just under 3M wide and 2.1M tall triple glazed. Very pleased with it. All I would say is Rationel don't do triple sets, so if you must have 3 panes they probably won't do what you want. -
Glass gable ends. Looking for examples..
ProDave replied to Olly P's topic in General Self Build & DIY Discussion
Only a small example. My sun room, the last bit of the house that we are just finishing now. Maybe not the clean look some want as there is a stack of beams between the 2 panes to support the roof ridge beam. -
A live-in builder/contractor?
ProDave replied to idontknowwhatiamdoing's topic in General Self Build & DIY Discussion
Look up Woofers. They provide labour for free in return for board and lodgings. I doubt any will be builders, but I know someone that built most of his house with his own labour and some Woofers. Your approximate location would help? Mainland or remote island? -
soil stack/foul pipe excavation - HELP!!
ProDave replied to TryC's topic in Bathrooms, Ensuites & Wetrooms
So that is probably a clay or cast iron pipe in the ground. The old WC would have been the type where the outlet went straight down into the pipe in the floor. That flexi pipe and the cement is a bodge. If that pipe and hopper in the last picture is the basin waste and is going into the foul drain then you can convert that to an external stack but you will need to dig up a bit of the patio around the open gulley to do that. -
ASHP and WBS as secondary heat here. The ASHP is noisy thing is a myth. I would say the ASHP is no more noisy than the burner of an oil boiler, but the big difference is all that noise from the ASHP is outside. Why is it people complain about a small noise from something outside but are happy to put something equally noisy (oil burner) inside their house? Obviously putting the ASHP on your patio might not be the best plan, and nor would putting it on the boundary so as to annoy a neighbour. Rockwool has a longer decrement delay, which basically means the time taken for heat to pass through a wall is longer. The foam type tends to have a shorter decrement delay. You want the delay to be more than 12 hours so as the day warms up, the heat never has chance to get through to the inside before it is cooling down again. For ease of handling I recommend the Knauff Earthwool type, far less nasty to handle that the old yellow glass wool type of stuff. Re your steading? Have any surveys been done? While a steading conversion can work out well, I do know of one where they needed to lower the floor by 30cm to give room for 2 storeys, but then they started digging they found there were no foundations at all under the walls. it ended up with a re submitted planning application and a knock down and rebuild new, just using the old stone for cladding.
dry rot Dry Rot - collapsed floor into basement
ProDave replied to Brovashift's topic in General Structural Issues
Without entering the property, how do you know it is dry rot that caused the collapsed floor, not wet rot? What is with the corner with the Quoins? Why do they stop above the ground? It looks like some have been removed and replaced by bricks? The brickwork referred to above between the two windows looks to have been replaced. Why? -
Struggling to commission my Rehau UFH system
ProDave replied to Edward's topic in Underfloor Heating
I am not familliar with this system. Any pictures of the hardware as you have it set up? -
Yes 100 Amps per phase is about 23kVA so 3 phase will give a maximum of 69kVA What rate are you expecting to charge your car? and only one EV or more?
replace old oil boiler with new or go ASHP
ProDave replied to Lee66's topic in Boilers & Hot Water Tanks
This sounds like a golden opportunity to renovate the bungalow while doing the extension. Start by under floor insulation (I bet it has absolutely none at the moment) and UFH in the original part, probably a closer pipe spacing for the UFH in the original part. Carry on with the oil burner for now, I suspect in the next 5-10 years there are going to be serious grants to insulate and replace old fossil fuel boilers, there has to be with yesterdays CO2 reduction plans. -
I would go for 21kVA and see if they flinch or try and negotiate.
I would keep the thermal store, needed when using the wood burner, but I would not heat it with the GSHP, I would only heat the UVC from the GSHP. Use all 2 port valves (I hate 3 port valves, and choose carefully, some can be normally open, some can be normally closed.
LG Therma V mono block Air Source Heat Pump
ProDave replied to ProDave's topic in Air Source Heat Pumps (ASHP)
I have my hot water on a timer so it does not come on until 11AM, by which time the PV should be generating well, and then it is set to 48 degrees. This still leaves plenty of room to heat it hotter by surplus PV in the afternoon. -
Ventilation and energy saving for a flat in a badly converted mill
ProDave replied to PeterB's topic in Introduce Yourself
I would say with your high CO2 levels and feeling of being stuffy that the air tightness is pretty good, so I would be looking at mvhr in the loft. First thing to check is does the lease include the loft to allow you to do this?- 2 replies
- ventilation
- iwi
(and 5 more)
Tried several and the best I found was Wickes large tubs of cheap white emulsion, watered down a bit for the first coat. The own brand from the orange DIY shop I found to be the worst.
My guess is the "under offer" sign screams "building is vacant an not in use" Put up a "garage in constant use" sign and that will help. The tapered bit, to a casual observer looks like part of the highway, there really is nothing to say otherwise. you could try painting a white line just inside your boundary and painting "private" on the bit inside the line?
- 13 replies
- listed
- listed building
A picture might yield better suggestions to stop unauthorised parking? You can paint what you like on your land (once you own it) for instance a yellow cross hatch?
- 13 replies
- listed
- listed building
Kitchen Electric / Oven Isolation switches
ProDave replied to wozza's topic in Electrics - Kitchen & Bathroom
Normally even the dishwasher socket has an isolator switch above the worktop. Does the room with the CU back onto the kitchen? How about isolators there? -
I would reduce that hysterisis to no more than 5 degrees. Why have the thermal mixer set to 40 degrees? that won't be hot enough for washing up in the kitchen. -
Also find out WHO is responsible for maintaining it? What about shading? A structure that high could leave the garden dark and sunless. Certainly no view in that direction. And what is at the top of the wall to look down on / fall down on you? Picture?
