ProDave
    427
Everything posted by ProDave
  1. If you still have the old type of ball cock valve that shuts off the water slowly and can take ages dribbling to fill the last little bit before shutting it off, then change if for a modern fill valve, that will fill at full flow until quickly shutting off when full. You will never again want to go back to the old slow ballcocks.
  2. So that is not a rainwater pipe, but outflow from a bathroom? Bodgit and scarper plumbers strike again. Replace that downpipe with the proper round downpipe that will mate with the other black pipes all the way down.
  3. They may be a reputable company for complete light fittings, but I have not found spares on sale anywhere yet. Perhaps try contacting Siteco directly and asking them if they can supply you with a new driver?
  4. Most likely to be the driver. Trouble is I can't find that exact driver anywhere. The important thing is you want a constant current driver set at 145mA or an adjustable one that can be set to that. Most I have found are 300mA or more. Then it has to be small enough to fit in the space occupied by that one. If it were mine, I would open up the case of that driver which may involve cutting it open of the plastic is welded or glued shut. Like @Temp my money is on a failed capacitor or 2 which is probably repairable. Even if you then had to glue the case of the driver back together. P.S the U Out 340V DC makes one not trust much of what is written on it.
  5. Can you post a closer picture of the Sireco module. Even if I zoom in, it is too fuzzy to read the numbers.
  6. That looks like a 1W switch (simple on /off) A 2 way switch would have another terminal in that hole circled in red. For the few p you save I only buy 2 way switches
  7. How much did you use in your house? No more than 500M in mine, if that, and by buying new offcuts you can get it pretty cheap. e.g 90 metre "offcut" for £60 with postage https://www.ebay.co.uk/itm/316187121886? 5 of those would have done my entire house. At that price, just put it in, it gets used, or if not, you have not wasted much.
  8. I used to build industrial control systems and there is a defined risk assessment that considers likelihood of a failure and consequence of a failure to determine what sort of control system was required. For most of what we did (machines that could kill if the safety systems failed) that was 2 contactors in series, with a safety relay monitoring the state of the contactors and would not allow the machine to start if it detected one of them had a stuck contact. Now given a boiling unvented cylinder could explode and kill someone if the safety systems failed, I would not want to be the one standing up in court explaining how I designed my own 24V contactor driven "safety" controls rather than using industry practice as described in the installation manual. I did encounter an ASHP installed to it's manufacturers instructions (I forget which make / model) and that connected to the immersion heater in the UVC WITHOUT a thermostat on the immersion heater itself. I was most uncomfortable with that, but I neither installed it or altered it, just observed what was fitted.
  9. I am not familliar with the heating system you propose. Is it warm air heating delivered by the MVHR? If so previous discussions suggest to deliver enough heat it will have to run at much faster flow rates than normal mvhr. I would put those UFH pipes in and go that way. You will almost certainly only need that on the ground floor as we have. What do the heat loss calculations say is the heat input needed on the coldest winter day you can expect?
  10. Does your heat pump expect to connect to the immersion heater? If so that dictates a lot of the controls and you have to work or adapt around that. In my case the ASHP does connect to the immersion heater (though I have disabled all use of that in the settings) and it does so with a control box supplied with the heat pump, which contains a contactor and mcb's. To integrate that with my PV dump controller, I modified the supplied box to single pole switching, so only switching immersion L via the contactor, and then connected a solid state relay in parallel with the (now single pole) immersion contactor switched from my dump controller. The use of a remote SSR for the dump controller was a big motivation for making my own. The immersion heater will have it's own normal thermostat and secondary over heat protection should that one fail. The cylinder mounted thermostat with a probe in a cylinder pocket is to protect the cylinder from over heating when fed from an external heat source, so should be wired to close the motorised valve on the cylinder input coil if the cylinder is overheating.
  11. Okay 1 more. First self build, over 20 years ago now. Originally planned a square shower tray. UFH pipes laid out to suit that. Floor marked with big marker pen showing where every single pipe was. Changed plans. Decided on rectangular shower. Waste in a different place. Cutting the hole for the waste, a fountain of water started to come from under the floor. Yep I had failed to see my own markings and cut right through an UFH pipe.
  12. Neither. For simple white switches, I don't think you will beat Click Mode for quality, value and reliability. But Screweys don't sell them. Toolstation do. https://www.toolstation.com/click-mode-10a-switch/p73508 A little "quirk" of these switches is the switch mechanism can be removed from the plate, enabling you to mix normal and intermediate switches on the one plate. Almost like a grid switch.
  13. As above , if it is just a workshop / shed (i.e. you don't intend to fit a car in it) I would be very tempted to have two buildings within the size limits for permitted development and not requiring building regs. Given the aparent L shaped nature of the garden from your plan, I would personally tuck the building(s) just around the corner to the right so not obstructing the straight run of garden from the house.
  14. Yes is does sound like it is not shutting off. Only way to find out for sure is remove it, then you might as well fit the new one. PITA having to drain down to do so.
  15. ^^^^ Ah yes safe zones. Everybody know never to drill a hole in a safe zone without checking first. Except the person hanging something on the wall, and then of course they measure meticulously to ensure the thing they are hanging exactly lines up with the centreline of the switch. BULLSEYE
  16. These actuators are a pain to test as they don't work with the actuator off the valve, the mechanism relies on being on the spindle of the valve and just won't work properly if you try and energise it off the valve. I always find it is difficult to tell if water is flowing as you don't have a flow meter, you can only go by is the water hot both sides of the pipe etc, so when it closes you have a while to wait to see if the pipes cool down or not to confirm if it has closed and water has stopped passing.
  17. You should be able to shut it off with little force. Does it turn freely with the head off? It will only turn roughly 90 degrees, and as you say the closed position should be a soft stop where the flow is plugged. If the plumber could not check that and passed the buck to an electrician, time to get another plumber. Is the valve seemingly opening and closing correctly with the head on? Can you see it rotating?
  18. Better than that, but no photos. Drilling a 16mm hole through a thick stone wall for a cable. When it broke through on the inside, I cut back a bit of the plasterboard, to find the drill bit had emerged through the wall between two 22mm copper pipes that nobody knew were there. An inch either way and it would have been a wet problem to fix.
  19. Obvious question WHY 11M from your ow house? Difficult without seeing a site layout but logic would say if closer to your house they would be further from neighbours so less likely to be a problem.
  20. A previous job, one of the engineers never seemed that bright to many of us, and nobody was really sure what he was doing. Then after a while he was sacked and marched off the premises immediately. It turned out he was spending most of his time running his own business.
  21. Thank you for coming back and reporting the outcome.
  22. How much do the water company know or want to see? If nothing, just make sure the pipe they are presented with is 25mm and the correct depth. They don't need to know it then goes to 32mm. Don't even mention that unless asked.
  23. Yep that's a back to wall pan with a flush pipe. NOT a close coupled pan with a donut and a clamp to pull the cistern down onto the pan. If you choose to change the cistern, probably best to use the existing flush pipe that is already cut to length. You assemble the fill valve and flush valve into the cistern and fill the cistern with water before you fit it, so you can leave it a while and check it is not leaking from either the fill or flush valve, if all is well empty it and continue fitting. If it then leaks it must either be from the flush pipe at either end, OR the waste pipe coming out of the pan if the pan connector is leaking.
  24. Check your cold feed pipe location. Most concealed cisterns have bottom entry but looking again at your picture yours appears to be side entry. @Nickfromwales are you thinking of the donut on a close coupled cistern? I think this is a back to wall pan against a ready built unit with concealed cistern and a flush pipe.
