Everything posted by ProDave
A well known user here @Jenki built his own version of a rigid polytunnel, have a look at his blog.
You have an electrical problem. Are the lights on top of the actuators really flashing? or is that an ailiasing problem with the camera? If they are really flashing, they should not be, and the pulsing of the flow meters looks like a pump is rapidly turning on and off. Post some close up still shots of all the electrical control boxes, pumps and motorised valves etc so we can see what you have. Has it only just started doing this.
size of excavator for baseworks?
ProDave replied to sunflower's topic in General Construction Issues
The soil at our site is so soft the trench sides would have caved in with that. To do similar on our site I had to put down some old scaffold boards to spread the load futher. -
Crushed so they interlock together and are stable, as opposed to round gravel that is more prone to settling.
The bungalow 0.5m from boundary might allow scope to stand scaffold legs there with permission of course. But do you really want a house that wide on that plot? I would consider a narrower and deeper house preserving decent access to the back garden on at least one side. Having the only parking in front of the house is a red line for me, no possibility of garage or car port.
What is either side? If no immediate building, is is possible to ask one or both of the neighbours for permission to stand one row of the legs of the scaffold in their gardens?
Timber Frame Soleplate overhanging cavity
ProDave replied to john0wingnut's topic in General Structural Issues
Why is this such a big issue? I wired an entire 2 storey timber frame house with this "problem" The foundations were built assuming a 100mm TF so 100mm block for the inner leaf, but then they decided to build the frame in 140mm. So the sole plate for the frame overhung the block by 40mm on the inside. BC never raised any issues with this and the house is still standing 15 years later. -
What is your plan? You say "decking" do you mean timber decking level with the paving? If so you don't need all that MOT1. Compacted MOT1 drains very poorly, you would have been far better infilling that with crushed gravel that would allow natural drainage. At the very least try digging out a bit of the MOT1 back down to soil and see if that drains.
I suggest you delete that file, re name it so it does not reveal your address and re post it.
I read the OP wanted to remove the back box completely and end up with a blank wall. Have I got the wrong end of the stick?
If that is a plasterboard wall, the back box will be mounted on a noggin. I would remove the back box, screw an appropriate thickness packer onto the noggin such that when you then screw a plasterboard patch into the hole it is about flush. Much easier to then fill the gaps.
Are you discharging into a loch? I didn't think SEPA allowed that?
Perhaps one of the other members with a recirculating hot water system can comment. I can see no reason it should stop delivering hot water if the pump is not running, it will of course take longer for the water to reach the tap.
Which circulation pump? Do you mean hot water circulation, a system used where you have long pipe runs to the taps to give quick delivery of hot water. If that is what is running 24/7 then rewire it ideally triggered by motion sensors in the bathrooms etc so it only comes on when there is actually someone there that might want hot water. The rest of the time it is just sucking heat out of your hot water tank.
Still not understanding fully. Where it says "exits wall low then through floor" i take it that is 110 between joists under the bath almost to the end, turns right, through 2 joists to WC? If I have got that bit wrong no point continuing until I understand it.
Snap/clap noise in kitchen/living room 2nd floor flat
ProDave replied to HL123's topic in General Construction Issues
How often? Always at the same time? start logging exactly to the second when it occurs and see if there is a patern. It sounds to me like an electrical contactor (big relay) closing and opening. -
I concreted my conder in, you gradually pour the concrete at the same time gradually filling it with water so the water is about as high inside the tank as the concrete is outside it. I was wrongly advised by the installer in our previous house who just back filled the septic tank with gravel. That house now has a tank that you can only pump out in the middle of a summer dry spell, and then refill with water PDQ. To pump it out in winter would be asking for it to float out of the ground.
I can finally drill! Oh wait. What is the matter here?
ProDave replied to Garald's topic in General Joinery
Once you have tried an SDS drill you will NEVER want to use anything else for masonry. -
I would not put a 100A fuse in your switch fuse as you have no discrimination from the DNO's 100A fuse. I have mine fused at 80A and have never had any problem with lack of power. If you re run the calcs at 80A you might get better cable size options. You mention 5 core so you are talking 3 phase neutral and earth, so no way will you ever require anything like 100A per phase if you have a 3 phase supply.
Any online supplier for non-standard sized MDF skirting?
ProDave replied to markharro's topic in General Joinery
But they would only be 2.4M long so more joints compared to buying MDF skirting. -
The point about the hiab is this is standard with most builders merchants trucks, they are used to unloading pallets of bricks, roof tiles, plasterboard etc. but before choosing to order from a BM one of the suppliers I was talking to would send it on a flat bed and would require something to lift it off on site. It would be well outside the reach of my small digger to lift it off a truck. I once tried to get a BM to lift a lintel off their truck straight onto the wall where it was going. They flatly refused. I used my digger to lower it into the hole and it took 3 goes to get it the right depth and level. This unloading thing when I was ordering windows, and negotiating on price, I found their standard delivery truck would require a crane or telehandler to unload. I did manage to negotiate delivery on a truck with a hiab at no extra cost. I really don't know why this is not standard in the building industry. Though I guess delivering to a large developers site there will always be some lifting gear available.
