Most domestic would be copper pipes between the internal and external unit, fully insulated with a condensate drain connection.
Depending on make and model power is taken to either the outdoor/indoor unit and an isolator is installed then generally a 4 core cable between the units for providing power and communication between the 2 .
many have remote control for temp change or you get wall mounted, modern units also can have an app for user control.
the outdoor unit is generally pre charged with refrigerant gas, and depending on the distance between the 2 units more gas may be required.
I’m agreeing with Dave on this one, fine for a bit if DIY on your own property, but if you have paid contractors utilising it and there is an accident it’s not going to be good.
Of course unless it’s erected by a competent person who signs it off and signs the scaff tag.
Get a plug cutter set to remove a hole in scrap wood, drill hole in top timber and screw into post, then pop in timber plug to hide screws,
or angle brackets
or toe nail screws underneath.
lots of options
https://www.johnlewis.com/john-lewis-elliott-desk-lamp-gloss-slate-blue/p4285391?s_ppc=2dx92700075585127963_mixed_home_BAU&tmad=c&tmcampid=2&gclid=EAIaIQobChMI6rnnko2s_wIVDpbVCh3WSQMxEAQYAiABEgJpD_D_BwE&gclsrc=aw.ds
problem solved
Sure there could be a block of wood on the inside of the door that hits the micro switch
I found when I did mine 20 years ago it was best to have the parts to let the joiner see what was involved, how much travel the microswitch has etc
im sure there are options in the Hafele catalogue but don’t know that one so well compared to the TLC one
