TonyT
    6
Everything posted by TonyT
  1. Not the painters fault. the joiner who put the plasterboard up would be the better person to apportion fault.
  2. It’s in the TLC catalogue, maybe as a cupboard switch
  3. I have at my furthest radiator a T into the flow and return under the floor at each of the pipes goes to a handle operated valve then they join together with another T and 1 pipe goes outside. it let’s me drain the system down without hoses etc in normal operation the valves are closed, on opened when I want to drain it down. This is next to the hatch so it’s easy for me. I copied it from a heating spec we were using at the time in 2004.
  4. TLC electrical for led strip then standard micro switches switching the supply
  5. The frame fixings with the plastic part are designed for solid walls, not timber. You need wood screw or coach bolts, or similar
  6. Most houses are single phase so ask for a single phase quote 18 kVA thats approx 80 amps single phase.
  7. What’s the construction you are fixing?
  8. Open up microwave and twist off sounder from circuit board/ desolder.
  9. Do you need 3 phase?
  10. You need to decide if you want single or 3 phase supply and then work out from there. a 7kW charger can put a lot of juice into a car, again so can a 13 amp plug and socket arrangement depending on your travelling requirements, so only you know what’s good for you. Gas/oil heating or ASHP/GSHP. work on your m&e design
  11. no I mean search for a property, so you drive past a house like the look of the work, find the drawing online and use that as a starting point for your drawing. like below http://planning.northamptonboroughcouncil.com/civica/Resource/Civica/Handler.ashx/doc/pagestream?DocNo=10971130&pdf=true&filename=Plans - M00521-100-01 Structural Plans %26 Details.pdf
  12. Can you look online at your local authority online planning dept and download other extension plans, Fife council let’s you download plans, so if I saw an extension in the street I liked I could download their plan and get some ideas for layout etc.
  13. Get A2A run it off your night time tariff when it’s already cheap, and utilise the 400% efficient for of heating even more efficiently. keep a couple of storage heaters in the far flung corners of the house controlled via smart plugs to bring them up to speed and a great hybrid solution
  14. And the cables under the meter need sorted too
  15. Christ, the DNO allow approx 3.5kW per house that enough for a whole estate based in their diversity calculations
  16. That’s where I was going with that ….. you put a socket and put a labke on it saying EV charging point. Bingo.
  17. And sell me the new inverter 😁
  18. Did they specify a type of charger?
  19. SBR then mortar good tool is the multi tool if you don’t have a concrete poker, use a worn blade and vibrate the timber…
  20. Find out what size of supply you need and they quoted for and see who else will price based on the same info.
  21. Ask the Architext who is familiar with your local authority requirements it’s one way to ensure a compliant design
  22. Get the architect to specify a product and produce a detail for it to ensure it’s correctly installed
  23. Use the version that the tap twists out the wall fitting like a BC lamp. Available at double the price in online pet shops or half the price in caravan online shops….
  24. Skinhead should be sponge
