Roundtuit
    2
Everything posted by Roundtuit
  1. Looking at that sort of money, I'd be seriously thinking about re-locating the tank somewhere else and updating your hot water system tbh.
  2. For small pictures I'd use a plug and screw; for bigger pictures, two plugs and screws, spaced appropriately. For heavier stuff, try and position it where you can screw into a batten and just use wood screws.
  3. I bought a used Leica Rugby 100 with receiver for about £200 on eBay, whilst I was getting twitchy waiting for pp to come through. I checked/adjusted calibration and it's accurate to within a few mm over 100m, so plenty good enough for landscaping and shed bases etc (which is all I've ever used it for). If you've got the time, it's worth a look.
  4. Hi, and welcome. This is a bit of a 'how long is a piece of string' question, but I can give you a few thoughts as a starter from experience restoring a listed Georgian house: - rule #1. Start at the top and chase the dust down and out. It sounds like the work in the bedroom is significant, so I'd get it done before you get any nice stuff done downstairs. - Walls & ceiling. Sounds like lath and lime plaster. If it's in decent condition, still bonded to the lath, it's going to be easiest to keep it as is, assuming you're happy with what is probably a rough-ar$ed finish after you've got the woodchip off. If you want better (i.e smoother), then it has probably got to come off and be replaced with plasterboard and skimmed. If it's not subject to any conservation constraints, that might be the best bet, as you can re-wire, insulate and add vapour barrier as necessary. It needs to be done with caution though; the lath stops the studs from twisting and bowing, so get advice before ripping it all off. - wobbly wall. Sounds like a partition wall that's no longer tied in properly. Needs further investigation. - Floor. If you want exposed floorboards, you really need to lift and shuffle up to fill the gaps. We did one room this way; the job was a pig, but the finished floor was great. Expect to loose some boards through damage, but you really need to try a few to find out how easy they come up; we robbed some spares from another room that was due to be carpeted. If you want to sand it, don't under estimate the amount of dust! - fireplace. The chimney breast brickwork was never meant to be exposed, so it might not be as pretty as you hope. Again, opening up a fire place is potentially a very dirty job, depending on the condition. Take it gently; we opened up two fire places ok, but our neighbours had a lintel collapse/massive soot-fall/big insurance claim. I guess your approach really needs to reflect what balance you want to achieve between retaining historical fabric, restoring or maintaining period features, improving building performance, getting 'the look' you're after, and, of course, budget. I don't suppose that helps much, but perhaps a few things to consider!
  5. I cut several well-established ivy 'trees' off at the base about 6 years ago that were smothering some Birch and Ash trees. Some of the stems were four or five inches thick and heavily intertwined. The dead ivy branches are still dropping off now when its windy, and will be doing so for a few years yet I reckon. It does look a bit unsightly, but not bad enough to get the ladder out! I also suspect that the decaying ivy wood has an environmental value as we have both Green and Lesser Spotted Woodpeckers paying regular visits to check for bugs.
  6. I've not had much success with edging tape. For ease, I think I'd get a length of aluminium end cap, cut to suit and glue and/or screw fix it on. You'll be binning most of the end cap, but it will protect the edge and take a bit of wear and tear. It is the utility room ?
  7. Great work! By the time you're finished, your problem-solving skills will be honed to perfection!
  8. I assume simply screwing from the front through the support is out of the question? What's behind it? Can it be assembled flat and then put in place?
  9. Looks like the old lintel (like your neighbours) has been taken out to put a taller window in, and maybe moved to the right a bit. It's been done badly with an undersized bit of steel so the brickwork has dropped. Not sure what's going on with the pointing to the right; looks like it's been painted on. I'd try and get it tidied up a bit - repoint above the window, make the gutter joint look better and get rid of the vegetation - and see what comes up on a survey.
  10. Why not put the insulation into your existing structure? Not sure what the osb will be adding tbh.
  11. Fair enough; my last place was Georgian, so green was more in keeping with the period.
  12. We had a similar challenge. Our railings were about 100 years older and had multiple thick layers of paint on them. I had to strip them in-situ using Nitromors and a scraper, and went over them with a wire brush drill attachment in the awkward bits before painting (wear a mask!). It doesn't have to be perfect; no-one else will look as closely as you! Slap on a couple of coats of Hammerite, (smooth dark green is my favourite), stand back and admire?
  13. You've changed. Surely strip it back to foundations? ?
  14. C'mon. You've lost it, haven't you...
  15. Yes. Our 300l cylinder is downstairs in the plant room with no problem. As @PeterW said, if your mainspressure is ok, you should be fine.
  16. Hi and welcome! Everyone needs a lockdown project - just make sure you get the best half. ?
  17. I think colour is going to be more important than style; that's what you'll notice until you're up close. Does it have to match anything? You might also want to consider what sand is used - I've used sharp sand to blend in with existing old pointing in the past.
  18. Your plinth build-up is the same as ours I think, but your cavity looks cleaner tbh. Can't see any frame ties? - that's where most of the crap seemed to get hung up.
  19. Yeah, you could be right; more 'poly' than 'crete' Good luck!
  20. The Aco polymer concrete channel isn't very easy to drill to be honest, and it's quite brittle and I think you'd break it if you used a hammer drill. I put a few in last week; broke the first one trying to break out the 110mm knock-out, so tried drilling the perimeter of the next one out with a 6mm masonry bit. I drilled two holes, switched to hammer and the whole knock-out fell out. Once they're concreted in, they feel solid. For 11 quid, I'd get one to play with before you commit.
  21. Ah. Let's call it a Party wall then! In that case, I think all you can do is politely insist that it's all done properly (planning app, party wall surveyor etc) and hope the cost puts him off!
  22. If it's your extension that you had built, presumably on your property, why would it be a party wall? Unless there's some agreement that you built partly on your neighbours yard, surely it's all yours? Or is that a whole new debate...?
  23. I'd go 24ml/litre, and yes, it will probably take multiple applications. I've had most sucess cutting the woody stems to just above ground level and painting the freshly cut ends with a 20% solution. Incidentally, I've just gone over a trial patch of ivy I want to keep with a 1/4 dose to try and take out the grass weeds in it; I don't expect the ivy to take much harm...
  24. You'll get a more informed reply from any number of other members, but that doesn't sound like much insulation. If you don't want to disturb your sub base, maybe raise the slab a bit to accommodate some more?
  25. We intake from a north-facing pitch, and exhaust from a south facing pitch. No issues that I'm aware of, and not uncommon to use different aspects according to the designer.
