Roundtuit
Everything posted by Roundtuit
Yeah, you could be right; more 'poly' than 'crete' Good luck!
The Aco polymer concrete channel isn't very easy to drill to be honest, and it's quite brittle and I think you'd break it if you used a hammer drill. I put a few in last week; broke the first one trying to break out the 110mm knock-out, so tried drilling the perimeter of the next one out with a 6mm masonry bit. I drilled two holes, switched to hammer and the whole knock-out fell out. Once they're concreted in, they feel solid. For 11 quid, I'd get one to play with before you commit.
Ah. Let's call it a Party wall then! In that case, I think all you can do is politely insist that it's all done properly (planning app, party wall surveyor etc) and hope the cost puts him off!
If it's your extension that you had built, presumably on your property, why would it be a party wall? Unless there's some agreement that you built partly on your neighbours yard, surely it's all yours? Or is that a whole new debate...?
kill grass and weeds permanently
Roundtuit replied to deuce22's topic in Landscaping, Decking & Patios
I'd go 24ml/litre, and yes, it will probably take multiple applications. I've had most sucess cutting the woody stems to just above ground level and painting the freshly cut ends with a 20% solution. Incidentally, I've just gone over a trial patch of ivy I want to keep with a 1/4 dose to try and take out the grass weeds in it; I don't expect the ivy to take much harm... -
You'll get a more informed reply from any number of other members, but that doesn't sound like much insulation. If you don't want to disturb your sub base, maybe raise the slab a bit to accommodate some more?
Smoke problem from neighbours
Roundtuit replied to Savage87's topic in Mechanical Ventilation with Heat Recovery (MVHR)
We intake from a north-facing pitch, and exhaust from a south facing pitch. No issues that I'm aware of, and not uncommon to use different aspects according to the designer. -
How did you hide your cables for wall hung tv?
Roundtuit replied to gwebstech's topic in Brick & Block
+1. I ended up retro fitting my tv to the wall, mainly because I didn't have the capacity to deal with that sort of detail at the time. As we have a 25mm cavity, it was easy enough to cut a couple of holes in the plasterboard and run the cables behind without having to move any sockets. -
I know it's semantics, but just for clarity, can we define a 'terrace' please? A terrace for me is like a patio or walkway at ground level. Your image looks more 'balcony', unless we're talking about some sort of roof over a patio?
I got on ok with Brewers. I guess it depends on how big your gaps are... ?
I tried to get vehicular access over about 3m council owned common land about 15 years ago without success. The council refused point blank as it risked setting a precedent. Maybe try for temporary access while you build, as a starting point?
- 18 replies
- common land
- vehicular access over common land
Can't remember what your floor build-up is, but room-sealed stove with air supply ducted in? Mine takes fresh air from a vent outside just above ground level, through some 110mm soil pipe under the floor and up into the wood burner. If you don't do that, you'll need an air brick or vent that can't be closed I think.
Any chance you can move your air intake to a less vulnerable position? -
help please regarding permitted development
Roundtuit replied to Dodgy-diver's topic in Planning Permission
You need enough room from the boundary to work to fix cladding, unless you can reach an agreement with your neighbour... -
Hi. Just for clarity, this door is between the kitchen and what?
Hi. Not sure if this has been covered, but can you ask trades to zero rate jobs after you've had BC sign off and made your vat reclaim? For example, if I got the house signed off and vat reclaimed, but then got someone in to do some landscaping (as stipulated as a planning condition), could I reasonably ask them to zero rate?
Taking my neighbours tree down wqithout his consent
Roundtuit replied to Tony K's topic in Party Wall & Property Legal Issues
Too right... he should be clear that if you assert your rights to trim back growth, there's a good chance the tree will become unviable and wil need removing. Best shortcut that and take it out now! ? -
Regardless of foundation design, if it's still only 10 inches from your build, I'd suggest it still needs to go. You can trim the branches back to leave your neighbour half a tree before you start, but are you going to be able to do that a couple of times a year in perpetuity to stop it encroaching? The landlord probably doesn't give a toss about the tree as long as it doesn't cost him anything, and he's possibly keeping his head down out of embarrassment at his parking-space deal duplicity being outed. I'd persevere at making contact again and reaching an agreement to relieve him of the burden of tree ownership f.o.c -
Front garden excavation for drive
Roundtuit replied to Margaret dailey's topic in Landscaping, Decking & Patios
As everyone has said, the risk is too great to do this half-ar$ed. To do it as it needs to be done is not going to be cheap. I like a challenge, but if I neeed that parking space, to be honest, I'd be thinking about moving house rather than this project. Sorry it's not the quick-fix you were hoping for ? -
Yes, the Gem can divert power to a second 'appliance' when the immersion switches off. I haven't found a use for it yet, but I think it's used for things like water cylinder de-stratification pumps. If I had battery storage, I guess it would be battery first, then immersion for any surplus.
Sorry, I was referring to the mechanics, not BR requirements. All I know is that my ashp installer got a bit twitchy when I told him that he didn't need to worry about a legionella cycle...
Correct. Although if you've no PV immersion controller, you'd probably use the ashp's legionella control programme. I've got the Apollo Gem, and the immersion heater is wired directly in to it, independent of the ashp. It has it's own programable legionella cycle and boost facility if you need it.
