dpmiller
Everything posted by dpmiller
Well not really, but this is the closest section I can think of to put the Q... Above our porch- and in a similar fashion at the rear of the house- we've small triangular areas that need building up as spandrel panels to continue a return block wall. Crappy photo of the scenario below, the blockwork will rise as a vertical edge to the left. So I've 150mm of depth to fill (100mm block + 50mm cavity). The outside will be half inch renderboard but what else? 140mm treated CLS straight onto the TF, or is some counterbatten a Good Idea? Studs are all 400ctrs max...
Removing hardstanding up against a 3rd party wall
dpmiller replied to Sjk's topic in General Self Build & DIY Discussion
where is the boundary? -
My preference wouldn't have a Riello burner... I'm mightily impressed with our Turkington/ Turco condenser but i don't think you's go far wrong with any of the usual suspects- Grant/Warmflow/ Firebird etc. We've got all these close to home so tend not to see so much WB or HRM this side of the wee pond. /except for the special models that WB made for NI "refurb" installs, long after condensers were mandatory...
yes.
how high up the pipe? same as the level in the header tank.
same thng really.
Grand here actually, they haven't lost much time and the blocks are sitting up and sheltered from any rain but getting a nice blow dry. Oh yes, knew there was something else- the new Keylite windows arrived. Seems the Polar Solar models are actually only to hit the market in the new year (even tho they've been in the price list for quite some time) so we got an early delivery. Waiting for the system chimneys to arrive imminently and all the sills are ordered and in production.
- 367 replies
- ireland
- timber frame
And so time passes. Most of the windows went in on Tuesday. There are a couple of booboos to sort, a unit damaged, a couple not to spec, and an umm... tolerancing issue with a couple of the openings. All to be addressed over the next few days hopefully. Blockwork continues. They're approaching GF lintels now and were awaiting a visit from the BCO to confirm what heads he'd let us away with.
- 367 replies
- ireland
- timber frame
One caveat on the single-phase motor- starting current is high and too much voltage drop can fry the motor so the rest of the garage wiring needs to be to-spec. A 3Hp motor will take between 10 and 13A full load but it's starting current could be double or even treble that.
yup.
Surely it's the mains into the CW tank that's the problem? Stopcock not fully open/ crap in the float valve?
Best simple ideas and concepts to design in to new build
dpmiller replied to albert's topic in New House & Self Build Design
Quite fancy a single post lift myself. The portable low/mid-rise variety are great for tyres and brakes but I reckon I'd prefer to be standing for the real underneath stuff. With the pallet-truck singlepost jobbies you can shunt them out of the way when not in use or even (door height allowing) wheel them outside too. -
generally there's a recess round the edge to set 8x3s into. -
try a cable tie or two instead of the jubilee clips.
so someone else does the dirty work then they sign it off?
Paraffin wax changes state at a nice low temp and is used by the bucketful hot and liquid in Histo labs. Nothing to be afraid of...
I like the paraffin wax option.
Check on Reading Commercial Gas Meter
dpmiller replied to Ferdinand's topic in General Self Build & DIY Discussion
IR is better for big open spaces- heats you, not the air. -
The Build - Mission accomplished! We're in!!
dpmiller commented on Redoctober's blog entry in Our Journey North of the Border
Lovely. Many congratulations. Gives me something more to aspire to... -
I might've asked this before but what *is* the "breakdown" temp, where the goo starts to cook? Surely a hard limit on the immersion element temperature would be all that is required to safeguard it. We see similar strategies in Autoclaves for redundant boil dry and overheat protection; some have a capillary stat clamped onto the element, others ( in an external boiler) have a PT100 in contact with the element, going to a spare way on the microcontroller.
What about the "high temp" units http://www.earthsaveproducts.com/product/high-temp-12kw-air-source-heat-pump/ I believe some are just r134a filled, but there are others that are dual compressor/ stage?
the rubber end bit normally has a bit of a cuff on the inside. Sure your barbed fitting won't push on down into this?
Since when was 21c cold?
