dpmiller
    4
Everything posted by dpmiller
  1. me neither, but then I'm not the one that was wandering about the top of the steels.
  2. I'd gone quiet for a bit... Pace has slowed a touch for the fiddly work round the dormer etc. But the ceiling joists are all in, rafter ends trimmed off, fascia, felt trays and vents all on. Oh, and the firebattens for... the windows. which arrived today. But won't be fitted for a week. installer feels the scaff is a bit close as he needs to fully open them etc, so we'll just have to wait for the TF guys to complete their stuff and then we can pull the hop-ups off and then the doors and windows can go in kiddies. In the interim, they do look pretty leaning together in the kitchen. The sticks of lath leaning against the scaff are hinting at a weathertight roof tomorrow or Friday, yay!
  3. Right then just waiting on some drawings from Schiedel, WRT using their Ignis Protect to bring stovepipe through the TF and into the Swift Air. Means I can just build a TF panel to fill in the current gap (w/ stud centres to suit the Ignis)and plunk it into place. 200mm masonry alcove freestanding on the inside for the stove, and all airtightness, insulations and cavities intact. Sounds like a winner?
  4. Thanks Jeremy. Our verge trim is a 50mm special for the chosen clay tile so there should be space there to sneak the edge of the GSE side flashing in too. Gets us pretty close to the edge without needing to faff too much. What about at valleys? We'll be using an upstand dry valley like your own, I presume the mounting plate could overlap the valley tray as long as the side flashing was trimmed back as necessary?
  5. planning Q for @JSHarris or anyone else with experience of the GSE system- what's the closest one can get to the verge- as we're using a Kytun- style strip, can the GSE tray go straight into that or does there have to be a side flashing (what's it's width, fitted?) or must there be (say) a slate and a half first? And is there really no other treatment required if you end the tray into the gutter at the eaves? Does it need to stop short to stop the water from cascading off the panel and past the gutter? Now that we've roof timbers in-situ and we know how wide the valleys are I'm trying to take a punt at how many panels we can cram in. I've tried Midsummer's online planner but I'm not sure how much side flashings can overlap valleys by etc...
  6. what happens if there are marked daily swings with your system, @TerryE? Say ambient is 15c one day, 7c the next or v/v, as we're seeing locally at the mo...
  7. I asked for- and received- quotes for both plain timber *and* and upgrade to posijoists from a number of TF companies. The upcharge varied between 2-3k depending on whether they were re-sizing for screed upstairs as well.
  8. ...and looking in some more detail the system is 40mm to combustibles so we don't need such a gaping hole in the TF which will minimise the area that is a thermal issue.
  9. cheap pex-al-pex, a touch cheaper still for a km. https://www.ebay.co.uk/itm/Underfloor-heating-pipe-16mm-PEX-AL-PEX-200-meter/323543239742?hash=item4b54ae0c3e:g:TWIAAOSww7tb5wq-:rk:8:pf:0
  10. @JamesP where does your 85k figure come from?
  11. What parking will you have when complete and will this satisfy the planners?
  12. Weather pants today. But the guys worked on and the roof is now about 75% done. Roofwindows trimmed out, valleys mostly complete, ladders and cavity barriers on, porch overhang constructed. landing now has it's view Symmetry
  13. how bad is access, and how are you planning to get all the other supplies in?
  14. Funny that, innit? When we were talking about this last they seemed to be about eight quid or something?
  15. Guess what I tripped over at the back of the BES catalogue: https://www.bes.co.uk/wall-mounted-rcd-mcb-enclosure-18840
  16. certainly need a gap under for shrinkage.
  17. timber or block build?
  18. "Digger at sunset through patio doors"
  19. working on that... looking at using Schiedel Swift Air to sort air supply too, but Swift air can be used two ways- https://www.schiedel.com/uk/products/ceramic-system-chimneys/swift-air/ look at recessed vs freestanding, either of which could sit within the external chimney area I have to play with.
  20. Just re-reading this one and I've a query- is there any reason why the inner skin of this kind of buildup (my own is somewhat similar) can't use thermal blocks?
  21. Getting remarkably housey. I've got to say, I'm astounded by the quality of the timber used throughout, it's all so much smoother and cleaner than I'm used to seeing. Awesome first week. really getting a feel for how the rooms are shaped now. Looking at the master bedroom last night Sandy couldn't help feeling that it was small. It's way bigger than what we're used to *but* felt short front to back. A bit of measuring later and we reckoned we could lose 200mm off the walk-in robe without worry, A quick word with the gaffer this morning and...Move a wall? no problem. done. just like that. I'm liking the hallway. There are a couple of large windows to insert here for a view out from the landing but for now the expanse of the sloped area looks great. I'd originally wanted Velux Integra Solars but as the TF co is just down the road from Keylite and they've now a Solar electric variant of their Polar UPVC windows we made a change.
  22. does the valve's microswitch report back to the ASHP? Any chance NC and NO are reversed?
  23. Gtec db, Siniat standard and MR boards. All 12.5mm, and supplied under our TF contract.
  24. I've got a big stack of it waiting for my attention...
  25. Day two. Scaff modded, all FF walls up, steels up, crane gone.
