dpmiller
Everything posted by dpmiller
Discount Offers of the Week
dpmiller replied to Ferdinand's topic in General Self Build & DIY Discussion
cheapo chansaw? Won't get better than this from B&Q https://www.diy.com/departments/fpcsp52-petrol-chainsaw/1709118_BQ.prd bought one last year (at £65 or so) and it's super. -
Give someone a decent house, and they break it.
dpmiller replied to ProDave's topic in General Self Build & DIY Discussion
So a standalone pump connected to your choice of tank would be a better option? Like Ecocent Energy, or the Ecocent MVHR and kill two birds with one stone? -
GSE trays fit a bit like a velux window flashing-wise and the PV panel then sits down into the tray. Depending on the choice of roof covering there's a fair saving in cover.
Are the rising walls in ICF or block?
NIE Networks look after the infrastructure and between the quote and the install there's a form that your spark fills in- details of loads, renewables etc, and a signoff that the install is per the 17th. they also look after the meter install, regardless of the energy vendor.
Yes, the main ducts will be covered too. The unit itself is basically a big lump of polystyrene, not much more to do there.
- 367 replies
- ireland
- timber frame
remind us what zone valves you have plz.
It's a cold-roof build. All the radial pipes will be within the ceiling insulation (200mm between joists, 200mm over, with the ducts in-between) and there's a foiled fibreglass wrap to cover the galvy ducts with.
- 367 replies
- ireland
- timber frame
guessing it's to give DHW priority over heating?
Productive weekend. First few sheets of PB up downstairs, more tiling (both side wings complete, ridge tiles on etc), and the main ducts in place for the MVHR. Still need to strip them all back out to seal joints/ make up hangers/ insulate etc.
- 367 replies
- 2
- ireland
- timber frame
ta. Tried a couple of Lidl's finest fake Fisher plugs and they took OK.
cheapo chinesium wifi thermostat.
Electrician's insulator stripping tool.
dpmiller replied to epsilonGreedy's topic in Tools & Equipment
I've used plenty over the years- never really liked the Stripmaster, but *do* rather like the new automatic jobbies like in post 2 above. Other than it being right-handed of course... Nice clean strip of inner and outer with a couple of squeezes. -
I've got some ridge end caps to fix "up above". They're pretty heavy clay and I woudn't want'em falling off... They're drilled for two fixings on the face, that's not a problem. Likewise, I'll need to pop a bit of treated timber in between them and the blockwork to space'em out for the verge trims and future render. Again, not a problem. But has anyone a recommendation on fixings onto the blockwork? Unfortunately I use that term pretty loosely as there's mostly mortar buttered into the peak... Too soft for concrete screws obviously, so are any specific plugs a definite go-er? Don't want to risk bursting the mortar. Or is it a case for gripfill / AN Other anchor into the screwholes and behind the timber?
Makes me glad I went with a bog-standard UPVC company- deposit on CC, bulk payment immediately before install on CC, cash to fitter on installation.
- 367 replies
- 2
- ireland
- timber frame
MT-TUA-17S-11-9240 not responding to input signal
dpmiller replied to readiescards's topic in Other Heating Systems
Half- lit means leaking slightly. Neons begin to light at 90v or so IIRC. Could be an internal fault keeping the "switch" partly on, eg a capacitor or diode; a neutral fault on the load not allowing it to take the natural leakage of the "switch" down low enough; or an induced voltage in the wire to the load caused by proximity to another. Or any combination thereof. -
Your building regs approved document should have infos- in NI it's document E, 4.36.
Yet more bad press on mass market developers
dpmiller replied to lizzie's topic in General Self Build & DIY Discussion
The first time I met our BCO, it was exactly that. He'd tripped over the blockworker on another job and mentioned he would pop in on the way past just to "see how things were progressing"... -
Plenty of focus on it, here. Laminated advisory supplied with the TF kit, all installed by the erectors, and then confirmed by the BCO for the blockworkers as it was a while since they'd clad a TF. -
looking at the way the paint is worn off that cutter, has it been dropped or bent?
Save the world, install an LPG tank.
dpmiller replied to epsilonGreedy's topic in Environmental Building Politics
Certainly with diesels, the sweet-spot of efficiency vs emissions was reached about fifteen years ago. Since then, each added emissions tier has required inefficiency, followed by *more* added tech to scrub it back clean again. Only the latest stuff with Ad-Blue hits that spot again IMHO. There's a fine balance in combustion- the most efficient combustion creates the least CO2 and particulate per mile and the best mpg, but at the expense of NOx emissions NOx emissions were historically controlled by making the combustion cooler and dirtier. -
so streaming 24/7 regardless of actual useage?
