Gus Potter
    34
Everything posted by Gus Potter
  1. Ok. to stick my neck out when folk on BH buy stuff from their local merchants their profit margin is 20% based on the delivered price. That can be split up between the haulage and the uplift on the material. Sounds high but you may get a big delivery and then some small ones. In terms of my work flow as an SE/ Architechural designer it was plentiful during COVID as everyone wanted to work from home and open up their house, build garden rooms / offices and so on. In the back ground I also had the industrial stuff that was on a long programme. But I can see that things are getting back to normal where we need to compete for work. The folk that have made hay over the past couple of years and not set aside money for the lean years will go bust. For self builders I think the labour cost will come down but material costs will remain fairly high due to the cost of energy and transport. It would be good to say hey.. builders labour rates are going to go down.. but fuels costs are rising (running the van), insurance is not getting any cheaper and so on. If you are lucky enough to be a builder in Scotland.. John Swinney has just increase personal taxation again if you manage to build up enough of a nest egg to consider taking on an extra member of staff.. so add that to your self build bill. In the round I think that prices may stay roughly where they are if you are doing a self build.
  2. Good point of note. If you have a house say built circa the 1950's then please check that you don't have a separate rainwater and foul drain system.. your plumber should know this. If you put your sink waste into the rain water drain this goes straight to the watercourse and kills wildlife.
  3. Yes but... setting aside the structural design side... but that calculation is for an individual element of the structure. You need to look at the area of glazing, the floor and the roof to make sure it all complies.. you may need to do what is called a compensatory calculation which trades off the parts that may fall below the standard and beef up other bits. Have a think about this race to the bottom folks. You may be trying to do this on a building notice / Scotland is a bit different but the jist of the rules apply. The thing I say to my Clients is this.. you may have some smart arse telling you the minimum you can get away with but if you want to stetch PD or the building regs.. fine but think about when you want to sell the house.. you are inviting grief. How are you later going to prove that what you have done is ok.. you could save money now but later you will now realise the true value of all the hard work you have put in.. and that is why it is good to get BC approval rather than doing it on a notice? To insulate properly on a raw kit costs buttons in comparison to your overall asset value. You need longer screws and you often bring the walls in a bit.. but?
  4. For all.. Recommendation.. pick @saveasteading brains.. you could save a fortune.. but you will get true professional CE advice for free so what about chucking £50 quid to BH as a donation?
  5. I live in hope! I design a lot of slappings in walls, to make open plan houses and so on. To do this I need to open up parts of the walls and ceilings to see where the joists run and so on. Used to be great in the old days when folk had just carpets, now there are tiles and all sorts so you can't lift floors above so easily. For all on BH.. on modern homes you find that with engineered joists and so they run in all directions and the services can be a bit bizarre, also in modern homes there are a lot more "services" .. and there is no real coordination... what is hidden in your floor depth is a lottery for someone investigating it. Also used to be great when sparks did a proper job.. ie running their cables mid depth of the joists (they know they should) with a small sag so clear of the ceiling. Got caught a few months back. Used to use an insulated plasterboard saw and sometimes don't turn off the all power.. then started using a multi tool.. makes a professional looking cut when doing a structural investigation but once the hole was open here the spark had left a coil of cable lying on the ceiling..the socket ring main. I nicked the cable. The multi tools are great but you have no feeling.. if using a hand saw you sometime get a feeling.. like driving an electric car cf an Astra van. Now it's out to the van and get my "near disaster avoided kit" to sort it as a temporary measure. I also keep in the van.. a distaster kit.. yet to be used.. luckily! Here is a thing for all on BH.. I'm an SE and you may be wondering.. what is Gus doing? I'm just being practical and trying to get a handle on how the building works and where some the booby traps lie for the builder that will have to implement my design. I could pass on all the risk to the Client but it's about getting a balance. If you don't take a bit of a risk when opening up old buildings you are designing on complete guess work and that generally ends up in tears. Yes I nicked the cable but I always explain to the Client before I start.. the more we explore now the better information we can give to the builders and this protects you. When I nicked the cable they were fine about it. It would be great to find a tool that has xray specs! Can it find cables, pipes and studs?
  6. As an immediate and temporary solution you could modify the hopper below to stop the overspill. You'll probably need to dig a bit of a hole and need a straight coupling to connect the hopper to the existing pipe. @Nickfromwales may pitch up with a better idea so will defer if so.
  7. Go back to basics. Look at the attic, roof pitch, have you a load of downlighters installed in the ceiling below the attic. Do you have some 350 - 400mm thickness of glass wool in the attic? If you do then check the ventilation. A modern condensing boiler will help a lot but have a review of what insulation you do have. Have you had a look under the ground floor.. what kind of solum space do you have, is the solum damp? Does the 1920's part have a cavity wall construction? not sure? I would make sure you have a very good understanding of your old house before plumping for an insulation and heating strategy. As a word of caution.. be very carefull when you are insulating and vapour checking the interface between a warm and cold roof. It can be very hard to get right.. I struggle often to detail when you have say a large warm flat roof dormer interfacing with say traditional pitched roof. Every roof is different so you can't just copy and paste details! While sometimes you can make it look good on a drawing you need to try and do something that a builder will actually make an attempt at doing right on site. If you want post more info on the construction you have, ground levels and so on.. your heat model could be horribly wrong! Best to identify the right strategy now so as not to waste money and cause a potential costly problem. Once you have nutted out the basics of the construction you will have a slightly more valid model to play with.
  8. Spot on. Please be careful here. Like all things TF takes a bit of learning about. Structural stuff: First thing is building stability. With TF you get about a 25% contribution from the external leaf of masonry, no masonry.. debatable contribution from the outer skin. Next is insulated plasterboard on the inside. If normal plasterboard straight onto the studs you get a contribution (last resort when stuck on the sums) from that provided you are sure it is not going to get wet. Insulated plaster board.. no as the fixings tend to bend in the insulation. You have openings.. these can drastically reduce the racking resistance and if large bifold doors ect these can completely change the way the forces act.. often you need to check that the existing building can cope with the extra sideways load and pulling / tension effect it has on the existing house walls. Depending on where you have the openings a tall narrow TF panel can generate significant uplift at the bottom.. so you need to check the tie down strap nails and make sure you have enough ballast in the underbuilding to resist the tension in the straps generated by the over turning effects in the panels. Turning now to the vertical loads the studs need to carry. You can put a surpising amount of load down a TF stud when is is prevented from moving along the plane of the wall, its minor / weak axis as the OSB restrains it. But when you couple this vertical load with a wind load it has a reduced capacity.. quite a lot. You need to check the case of wind pressure bearing down on a pitched roof coupled with the weight of the roof.. often it is okunless you live in a windy spot and the roof is not flat. But if the stud length is over 2.4m in height this can suddenly becomes and issue as the TF is holding the external skin. Last but not least.. you need to look at your windows and doors.. how much defection can they cope with both vertically and horizontally. Some detailing stuff: Make sure you get your cladding details sorted. You may want to put a chamfer on any horizontal battens to channel water to the cavity where it can be properly dealt with... it's these apparent minor details that matter a lot for a durable build. Have you checked to make sure you don't have a fire boundary condition? Make sure you get the cladding ventilation and insect grills nutted out both top and bottom, soffit details and so on. Make sure you get your fire stops right and that there are corresponding studs behind. Have you decided on how you are going to do the corners of the kit (California.. don't like them structurally) how you are going to insulate and the sequence of work to be able to do it. Yes but this may be a good opportunity and avoid a howler.. why do all this work and risk that when you come to sell someone asks.. is that ok and can you prove it? The above sounds like a bit of a rant from me but you have a great opportunity here to learn loads and practice on your own house. I started out a while ago.. bought my first flat and learnt how to get started on the practical side of the building trade and earn a living. In summary if you want post some plans and elevations (rough dimesioned sketches will do as you are not tested on your drawing skills on BH) of what you propose and plenty folk on BH will chip in with advice and tips. It may be that you will conclude that it is your best interests to pay for some SE type advice.. but .. do a good job.. let the SE see you can and they may put you on their list of "good guys" and work will flow your way to boot!
  9. Spot on. To expand on the chat I was having with the manufacturer today. They said they needed 20000m ^2 trickle ventilation on a new build . The only way to achieve this was to add a head extension to the window and fit double vents and one at the hopper.. remember window frame looses more heat than a modern argon / filmed glass unit. For a bit of fun they did a hot box test and you had massive heat loss at the vents.. but does the window need to comply with or without vents? Most trickle vents in Upvc are formed by routering out the outside and inside, have yet to seen sleeved ones on the commonly installed windows .. every day is a school day. The outcome was they said to the developer.. will be cheeper and more Architecturally pleasing to fit MVHR.. problem goes away until each occupant say in a block of housing wants to live their own individual life. My grip is this. I do a bit of work on historic structures. I make the argument to BC that they leak air like sieves and say.. my Clients are grown up.. if the buiding gets stuffy they will open a window! If you ask for big trickle vents you need to justify why.. yes you are BC but I will challenge you on these techinical matters, in particular how to you justify the heat loss and environmental impact.. that gets them thinking. They stick to the regs but you can turn this against them at times.. by saying if you stick to this part of the regs you shoot yourself in the foot on energy conservation so "tell me what to do" I wonder.. why can we not just educate the public.. if your house feels damp, you are boiling up potaoes / drying a bit of washing inside.. open a window? My Mum does that and she is 91. If it is windy then the house will air quickly.. we need some common sense in the regs rather than this blanket prescribed approach that we need to conform to because some young polititians who are over paid for their talents decide that this is the best way to get re elected at our expense.
  10. Yes potential big changes ahead! In Scotland we have been doing TF for a long time. I remember having discussions about having to jump from a 95mm stud to a 145mm deep stud to get enough glass wool in, no insulated plasterboard, air tightness (tapes and so on) was something that we needed on the space station / for astronauts but not that much to do with us. Yes. The last time there was big step change in the building regs all the "greenies" came up with these ideas.. in Scotland they produced insulation standard details.. and they came to present to the IStructE (the SE crowd) where I asked if they had given any consideration as to how their changes may impact on the structural design and just how environmentally friendly their ideas were.. did they know about the unforseen consequences? .. say diaphragm action.. this is where we use say walls and floors to stiffen and make a building safe.. blank faces all round there! They clearly were implementing policy with no idea about holistic design. I think this will be the same case. As before some folk are going to feather their nest at the public's expense. If you want to achieve good environmental design then it takes time and thought.. unfortunately most of the policy makers are just looking forward to the next election rather than say over the next 25 years. It can be done and all the professions will adapt eventually. I am big supporter of good practical design that is of real benefit to the planet. Maybe using cold formed steel in the domestic market will make a comeback.. in which case
  11. Hi Paul. I posted before I saw you reply. Don't panic just yet. What can you tell us about the perimeter soffit ventilation and let us know if this is an extension and if so to what kind of house? traditional masonry / timber frame. What can you tell us about how this structure joins into the existing building? Is there any funnies? say extractor fans from internal kitchens and so on that need to be considered? I would want to look at this in the round to make sure that you are not doing anything that is going to impact on the existing house.. just to tick all the boxes.
  12. To tidy it up a wipe over yes. Not a bad looking job otherwise. Good to see the air tape, make sure you seal the walls to the ceiling when you get to it. @ProDave makes good points about not penetrating the air tight layer with the lights. What's the length of the wall where the sliding doors are installed and what is the joist span? Cold flat roofs are a bit of a nightmare to ventilate when they are large like this. Sometimes they work fine.. your house is on the top of a hill in the country with plenty wind to drive the cross flow ventilation, other times not. Is the roof ventilated all the way round? I assume it is some kind of extension so where it meets the wall is likely not vented. I take it that you are going to put insulated plasterboard on the underside of the ceiling as 75mm of PIR between the ceiling joists looks a bit scimpy? On the plus side you have a 100 deep ventilation void so that is helpful, it could be 50mm or less. Yes we have had cold weather and little wind recently so you don't get good cross flow ventilation, on a pitched type roof you get the benefit of convection currents. The first thing I would look at is the soffit vents round the outside. Have you done something to accidentally block the air flow? say by infilling at the wall head with insulation? But mould can grow quickly in the right conditions escecially when the "wet" trades are taking place and the windows and doors are not left open.
  13. Had a chat today with a window system manufacturer. Jist that I got and to distill a good bit was.. they test their windows with a "hot box". The window is fiitted into a box, they put a heater on one side and measure the temperature on the other. This lets them calculate the overall U value of the glass and frame. Dead simple and they then can develop a model for all the small and varying window sizes in between. But then we started to talk about trickle vents and how much they impact on the window performance. The new regs for trickle ventilation (Scotland) are quite onerous for new build. One problem practically is that the vents break the thermal barrier between the window frame layers and this really shows up in infra red. We never got to discuss if the trickle vents get sleeved but if not I can imagine that the draft will "whizz" round the internal voids in the frame? I wonder if the trickle vents can set up internal convection currents in the window frames? Of course if you have a MVHR system it becomes a mute point.
  14. Paving is blessed will rogues and thieves. If you want post your specification and make sure you give details of the sub base and ground below if you know this. Also let us know what your design axle load is. Normally 5 tonnes for domestic at the entrance. A drive at 100m long is going to cost a bit so there may be other ways of doing it. You could burn your way through a lot of cash for no real benefit. Do you have any planning / BC caveats re fire engine access and so on?
  15. That is indeed civilised. The main thing is that whether you are an Architect, CE or SE you realise that you carry a lot of responsibility. They all can be a great profession but you can often be held responsible for your actions and that is often not commonly recognised in day to day life. There are other job that pay better with less personal responsibility.. banking for example?
  16. Hello @ETC Thanks for the clarification. I suspected I had not got it right. SE's need to keep run off cover also. In an ideal world when you retire from say a practice the younger folk take on the "office" and agree to pay it off in installements while taking on the costs of the run off cover.. call it succession planning. I work with some younger Architects and they have been discussing CPD, I thought (wrongly) that you had to do this now. CPD comes in all forms, some is technical but all construction professionals should have an appreciation of what is going on, not just the construction industry but the world in general as this drives informed decisions. That is what makes a true professional. For our SE stuff CPD can come in many different forms. Believe it or not me posting on BH can be counted as a couple of hours over a year.. we say that is pro bono and justify it by saying.. it's "good for the sole" we may also do some charity work and so on. Thanks again for the info and explanation. Now I know!
  17. As the mould / damp bit is at the bottom I would take off the plasterboard on the window ingoe where it is at it's worst. Yes there will be a bit of disruption but it is the best way of getting to the bottom of the problem.. UPvc windows are fine .. it's the fitting of them that 99% of the time causes the problem. Two basic things I would look for and suspect.. 1/ Window fitters are notorious for not closing and installing the cavity closers properly. They will shove something in for good looks but particularly on a retro fit you often have mortar snotters and wall ties in the way. They are pushed for time so often don't care. 2/ You have a cill that should be sealed to the bottom of the window frame so that the water drains out through the front, usually done with a bead of silicon when the cill is fixed to the window before installing. Check to see if there is dampness when you open it up. To make sure get a hose and spray it on the window for 10 -15 minutes and look at the bottom corners.
  18. Yes some Architects give up their Archictect's registration... RIAS in Scotland as to maintain your registration you have to do CPD and so on which can be quite onerous. You need to keep paying your professional registration fees. The main thing is that once they give up their registration, "retire" the can't call themsleves a Chartered Architect as it is a protected title, I think they may be able to call themselves Chatered Architect "retired" @ETC do you know? However there is no bar to continue working away and insurers are quite happy to keep writing the PI cover. Why would they not.. someone who has that amount of experience is less likely to get it wrong than someone just starting out? The main thing is; if they finally hang up their boots you make sure they have run off PI cover that usually runs for 5 years or you can say.. We will carry the can after a year, or less and just enjoy working with someone who knows a lot. Now often if say an Architect has been working for a practice they will be over the vat threshold, once they wind downand start working solo their turnover drops below the threshold so great for folk wanting an extension say... not vat on the fees to pay. I would encourage you to look carefully at what is on offer.. you are going to get a wealth of experience, sage advice from someone who has seen and done it all for probably a not bad price?
  19. At a quick glance the bit to the side is fairly benign SE wise. But if you extend to the rear then I think you will have building stability issues as others have mentioned. This can often be resolved using a steel box frame.. but it will stick into the room a bit. That sounds bad but often in practice it lets you still have an open plan space that you can separate into different "zones" say dining room, kitchrn and so on.. still feels open plan if you can post more drawings showing the rear elevation. Initial guess would be about 6.0K for a box frame to open it all up.. but we need to see how the roof works first!
  20. To add a bit and for clarity. When retaining walls get to a certain height they can become expensive if the ground is not playing the game. An easy way to mitigate this to introduce restraint at the top. For all.. sometimes you can brace the top of the retaining wall off the house.. and that can save thousands!
  21. I shall oblige a bit but don't disagree with you .. To touch briefly on the the laws of economics and so on (see for example Ruskin) and the divesion of labour. Over time, the professions and the way we work, the things we are employed to do have become more specialised. Take Structural Engineering.. we have folk that can make highly complex computer models. To give you an example.. at the higher end a good finite element package subsciption will cost you 25k for a year and you only get to run say 5 or 10 full scale models.. that is 2.5 to 5k a pop! Now it takes a long time to learn how to make a model like that and make some sense of the results. You are probably not going to know much about all the other things that need to come together to get something built. Also you need to be able to convince others that your model is roughly approximate to what happens in real life as folks lives are on the line here. But if we are to make progress we can't be stuck in the past. we need these models to deliver efficient design, it's about verification, comparison with other computer models and so on. In summary design is often driven by cost.. to reduce cost we often need to specialise.. make ourselves more efficient but that gives us less time to appreciate and engage in holistic and good design. You can see this on BH all the time..comments like the SE is not responding and so on or the Architect is blanking us. Hopefully the Professional bodies will come to their senses and recognise that while at the moment they think they have invented a new wheel they have actually not. The best Architects, SE's and CE's, Building Surveyors etc have a rounded knowledge and will at some point be schooled again about who pays their wages.. folk on BH for example.. and be taught about the business aspect of being say and Architect and the fact that you ned put put in a bit of elbow greese to make a go of it. Yes to start with but some of us then become Architectural Engineers.. there are some great examples world wide. When I was at Strathclyde Uni they ran a course called Architetural and Structural Engineering which was recocgnised by the Engineering Council. It was a good course for students that wanted a half way house.. I think they all got jobs at the end of the course. Don't think I have obliged you on refection but hey ho.
  22. Hiya @PXR5 For me I would have a look at this all over again.. a design review now you have got a bit of a heads up and starting to appreciate the costs / things involved. In terms of appreance I would look at where the sun rises and sets, how you are going to use the space between the wall and the house. Would be helpful to have some more plans and so on.. do you like lots of plants or do you see this as a place for kids to play and a spot for your outside bar/ bbq ? let us know if you can. A bit of thought now can reallty make or break this. May be worth you while posting? The next is in no particular order it's just my thoughts. Here are a few SE / Geotechnical / risk thoughts. To get started on this the last thing you need is for your neighbours to get upset. You don't want to do something that will cause the land to slip so it impacts on their house but in real life their garden may tolerate say some 25mm of movement top end without complaint.. especially if they have grass.at the rear. A 2.4 m retaining wall can be a big ask if you are on a budget. My worry (not least) would be that when your neighbours house was built they maybe made up the gorund so you have a layer of made ground that will slip over the original ground. Lets assume the worst case for now. Much has been said about the different types of retaining wall.. cantilever, gravity, gaboin walls and so on. Once you get over say 1500mm the cost grows exponentially.. if you have good chalk ground not so much but let's just assume you have some " dodgy" clay with a bit of made ground on top and water coming from above that makes it all unstable. I'm wondering. My starting point would be.. that step back is about 800 mm.. now that could be a reinforced concrete beam ( slab) lying horizontally.. say 200 mm thick with 20mm rebar and a few lacing bars maybe.. at the bottom you could just have a small slab braced against the house. Then in between you could have a reinforced masonry wall all pretty striaght forward and easily buildable.. not figured out the sequencing of work yet but just thinking out loud. if you can get the concept structurally then the drainage is the next part.. but it is the structure that will eat up the money. Now rather than having a cantilever retaining wall or a gravity wall you now have a wall that spans on the top between the return walls? My gut feeling is that this might be a good cost effective option worth exploring. Also I'm thinking with a bit of finesse you could make this a great feature, maybe extend the beam to create some kind of detail that looks good I don't know but there may be some mileage in nutting this out so it looks and is more useable than just a retaining wall at no extra cost. In summary can you tell us about the space, where the sun is and what sort of finishes you think may appeal and what you want to use the space for?
  23. Yes and no. A lot of my work is small domestic projects.. used to do more big ones but every one is a one off and some can be very challenging on the odd occasion technically to bring in on a buildable budget and still look good. Pretty much all of them involve an element of SE work and associated architectural design work. Now I know that there are not that many folk like me who wear both an SE hat and an architectural designers hat but they are there. They way I work it is to tell a Client what I do. Listen to them, ask loads of questions about how they live and what they would like not just now, but what they want to do in the future and how they view their home.. could be an asset.. could be a forever home. When doing so I chuck in ideas and say.. part of the design process and my roll is to identify what you don't like as this narrows the field. Then say.. I'll come up with a few ideas.. some you may like and some you may think are absolutely awful.. just tell me straight up.. that is NOT what we want.. It is a good model and I do ok out of it. It takes a bit of guts to sit in front of a Client and say.. I'm may suggest things you may find horrible.. but this it is ok to do this and your job (the Client) is to say.. Gus that is crap and not for us! Once make your Client feel comfortable that they can just say.. that is not our bag / crap or.. we like concept than you are well on your way. This should be taught to budding Architects! and SE's. @SteamyTea If you put in a bit of legwork to find someone like me in you local area and most importantly are prepared to pay a reasonable fee then it can be a great way to work. It has taken me a long time to get to the stage where I can competently do the SE and architectural design but in the round can also save Clients money as I have a list of builder contacts and so on. Yes you can learn to do it all yourself and it can be a satisfying process. To do it right will often take a bit of time if you are a novice. You can do the BC stuff yourself, planning and so on.. all the answers are on BH. SE..? you may be for example a builder who knows that it will be ok.. but if you come to sell will the buyer believe you? Find someone local.. they are there and often you'll only find them by word of mouth. You may only need them to do a small part but just having someone there who knows a bit can be of great support. Hope this makes some sense?
  24. It can be as often you find that you get your dog washers, mark out the timber and drill.. all looks good but if a drill hole is near a knot they can be ferociously hard and the dog washer won't bed properly.. then it all goes downhill as it's tempting keep tighening the bolt and hoping for the best.. you can wreak the old and new timber that way. The main thing as I said earlier is to look at the shape of the old timber and the grain.. it's often not hard to do and it you get the enjoyment of practicing a craft .. for all on BH.. just take a few minutes to get it right. The principles will stand you in good stead. But if the old timber is too cupped the glue won't cover all the surface area.. let common sense prevail. I mentioned earlier a good long lap length. Two reasons. 1/ A long lap length creates a stiffer beam so you reduce deflections. That works in your favour. 2/ You may have someone ask.. but you are creating a laminated beam here, like a bit of ply or certain types of Glulam beam so what about rolling shear. Rolling shear occurs in a bit of plywood for example where the different plys are glued together and at the glue joint the grains of the timber want to roll over each other. The glue may be good but the cellular structure of the timber and capilliary tubes roll over each other.. hence rolling shear which for example you need to sometimes check in timber portal frame joints and the like. The long lap length allows you to head off these hard and time consuming calculations / nasty SE questions at the pass. Glued joints can be great at times but they are not the silver bullet for all your dilemmas. Lastly if you are considering glueing things then make sure you use a structural glue and remember that it only works if the mating surfaces are clean, dry, not frozen (working temperature) and kept dry while the glue cures.
  25. Great posts from all and fantastic advice. Rule of thumb.. If you are doing your first self build and doing the PM and leg work you can save between 10- 15 % on the build cost copmapred with just getting a builder to do it all for you. Now to get that extra money if you don't PM it you need to earn it and you pay tax on it.. factor that in. The next question is.. will it be less risky financially to do over time at work / concentrate on my carreer? Also equate the pleasure / self satisfaction you may get from having more control over the build as that has a value, although undefined. Lastly ask yourself how do I cope with risk and uncertainty.. that is really personal but some folk can and some don't do so well. I'm sure you have already asked yourself these questions but some folk don't. That said it can be a great journey but there are ups and downs along the way.
