Dave Jones
    11
Everything posted by Dave Jones
  1. sigh. no this isnt a VCL. These bodges are all too common.
  2. make the windows work brick, adjust them a few mill either way so you end up with a half brick. One of the many things architects are clueless on, specifying widow and door sizes that dont work brick.
  3. looks great!
  4. gabion baskets are cheapish method and they look good as well.
  5. id add some mushroom vents at the base of the pitched roof/flat roof junction to get some air flow.
  6. interesting. from my understanding, brushing a sloppy sand/cement mix over them prior to dabbing ensures any tiny shrinkage cracks are sealed. Agree they should be gagged properly anyway but it doesn't take long to brush a slurry over them for belt and braces.
  7. The heatloss calculator on the same site is excellent
  8. well spotted, its internal but the calc had it wrong way.
  9. the titan wet/dry from screwfix is a bargain. https://www.screwfix.com/p/titan-ttb774vac-1300w-16ltr-wet-dry-vacuum-220-240v/826kh
  10. running the values for my solid wall buildup (225 brick,100mm celotex, plasterboard, plaster) through the calculator using -10c external 26c internal still puts the dew point well inside the insulation so I don't think any air gaps between the bricks and insulation is needed.
  11. accumulater is essential depending on your useage. 2 showers happening and the dishwasher turns on for example will result in a dribble.
  12. disagree. as long as its insulated its superior. Just same as internal walls not freezing as they are insulated etc
  13. use marxox blocks under the joining walls. These shed builds never fail to amaze.
  14. is that a cold roof or a warm roof ?
  15. standard gulley pot would be ideal as they have an integral trap to catch any rogue items that may accidentally fall in, also stops the smell. screwfix/toolstation do them.
  16. sheer daylight robbery. at £250 a day ask them how long they will be onsite for, a month ?
  17. 65k to stand up some timber ? couple days work tops for a crew and crane. sounds bad but then timber frames are a rip off. Unless you planning to completely finish the build in 4-6 months I fail to see the benefit of paying over the odds for TF as its quick to erect then losing all the expensive gained time anyway. See it all the time locally, normally pushed by clueless architects onto unaware clients thinking it will speed everything up.
  18. no its slower and cheaper.
  19. it wont be the beam is insulated and air is a better insulator than wet ground like a traditional slab. B & B every time for me, fast, accurate, less labour, better for environment.
  20. you need to get your plans properly QS'd, estimators.com are pretty reasonable. email them your plans and elevations you will get back a price down to every last nail. It wont have foundations or steelwork unless you supply the SE spec as well but you will have a guide on what it will actually cost to then discuss with a builder.
  21. dont take too much notice of EPC its junk science at least at the moment where electric is penalised. Hire in a micro digger and tracked dumper (both go through a front door) for a weekend and you'll have it done. 300mm of XPS insulation would be great. 150/200mm hardcore+sand blinding+ 150/200 conc then screed on top. Just work down from FFL to see your max depth, careful not to smash any drains. 100mm pipe spacing allows underfloor flow temp to run lower and much more efficiency for the small extra cost of a bit more pipe. Dont bother with zoning the underfloor it just reduces efficiency.
  22. put a fan (normal desktop 12" will do) in a doorway/window and seal around it to the frame with bin bags to depressurize the house then go draught hunting.
  23. 56k will buy an awful lot of brickwork. Golden rule to remember 99% of architects are clueless on how to build anything. They are good at milking clients though. For example look at any of the window openings your architect has drawn and i guarantee you none of them will work brick. If they had a clue how to build anything they would design them to be built.
  24. lose the timber frame and cladding and go traditional brick/block will save min £300m2, pay an SE to give you a foundation spec that can be priced. Have your plans QS'd to see the actual material costs.
  25. buildup doesnt matter you are digging down. 25mm isnt going to do much, 50% (even believing that figure) loss means you need double the heat output. Madness.
