Dave Jones
    11
Everything posted by Dave Jones
  1. risk all that effort by not hiring a couple hundred quid pump for a couple hours. baffling.
  2. If they dont like escrow then a solicitors undertaking could also work. It puts their solictor on the hook for the cash if it goes pete tong. If they refuse both run for the hills they are using your money for cash flow.
  3. stick to 100mm centres if you want to go for low flow temp for maximum efficiency. Dont/limit zoneing. Get it airtight and size doesnt really matter.
  4. what m2 is extension ? block and beam may be faster.
  5. you have a cold roof by the looks so as long as your ventilation space is open both ends for air flow then you can mix and match insulation as it will be able to dry out.
  6. if your air tight wont need it. Surprised your passiv designer even specified it which is worrying.
  7. if that is the internal skin then should be using longer damp so it can lap down onto the DPM that goes under your slab. otherwise you will have to use the expensive paint on stuff.
  8. already linked it earlier. the shed spec is in their tech doc
  9. keep digging until you find virgin ground or hit 3m in which case call in the pilers.
  10. roofer is a failed brickie.
  11. 1100 is fire regs. can ignore for ground floor windows exiting onto a hallway to outside door. Everyhting else has to meet 1100 and have a 450 clear opening so a 500 sash.
  12. no it is. for severn trent all ground is considered contaminated, hence using the ££££££ pipe, unless you prove otherwise.
  13. if you have had a soil test done (70ish quid) to prove no contamination they allow you to use normal pipe.
  14. Prices are relative, how many m2 of blockwork and what was the cost ?
  15. guess your builders weren't to their taste.
  16. no way a shed build is only 15% more than a normal build unless you were being robbed blind for blockwork.
  17. So wasting all/only benefit of a mega expensive shed build. A normal build at around half the price can achieve the same with none of the risk and deliver a better product.
  18. hard to tell from the photo but doesn't look like its bonded into the brickwork of the main house same as they adjoining wall they couldn't be bothered to gauge either. Also the coping stone isnt flashed (contrary to NHBC spec) which will be letting water down the back of that wall rotting it out slowly over time. How these big house builders get away with this crap is terrible. Get onto LABC or whoever your warranty is with.
  19. Why bother with architects to do the build ? Much better off employing someone who knows how to build like a project manager / QS/ Builder. Get a detailed construction drawing pack from them, which will be full off errors like odd window/door sizes that don't work brick and add cost, then get it QS'd so you know ballpark what its going to cost. Depending on how hands off (costing you ££££££) you want to be tender and engage a builder, paid in arrears to a written contract. Pay a quantity surveyor to visit each month to determine what the builder is going to be paid against the contract QS schedule. The fees you save doing this method instead of buying the architect another BMW will sort at least a bathroom. This is the process the banks use for developers and it works. It protects the bank. This way the builder knows they cant leg you over and leaves you to organise the big ticket items, windows, kitchen, second fix items. 3 bits of paperwork you must have: Construction Drawings from Architect. Fully qs'd costings derived from these drawings and a contract for the builder to sign. find a good QS who will visit site to prepare you a monthly report so you will be told to the penny how much to pay the builder. For quality and monitoring a project manager could be worth employing, depends how good your builder is really.
  20. interesting, was that for a normal build ?
  21. thats what i said ?
  22. your going to need a mega plant room for all the kit. multiple cylinders, mvhr etc etc
  23. What is the manufacturers recommendation ? You dont appear to have a cill on those doors. How is water going to be shed from them outside the build envelope ? You can carefully lap a DPC tray but a load of hassle and puts you in the frame if it leaks. Get on the phone with the door/window supplier and ask for a drawing to follow so it it leaks you have comeback. What we did with our bifold was have a normal 150mm cill then tiled (porcelain) over the top of the cill to give a level threshold, put an aco linear drain under the cill to takeaway anything that found its way there. Never leaked once in 5 years and only had a 15mm lip to walk over.
  24. hardie planks look really smart. zero maintenance https://www.jameshardie.co.uk/en/cladding/hardieplank
