Dave Jones
    11
Everything posted by Dave Jones
  1. why do you want to lose the screed its your finished floor ? pipes stapled to the insulation then 75mm sand/cement screed on top.
  2. they can literally do what they want as they are not accountable. Your only recourse to any of it is an appeal unfortunately.
  3. your making a rod for your own back by choosing a niche, expensive build system with limited builders who can do them properly. save yourself a load of headache and cash and look at a normal brick and block build.
  4. rotate socket 180 degrees and refit.
  5. need to see what is under that lead. should be soakers and a couple of trays, one at back and one at front. The cover flashing looks a little low, ideally it needs to be 150mm. get it scaffolded and take more pics, lift the tiles.
  6. ripples means you floated it a bit too early. It needs to be nearly gone off and it will be like glass.
  7. check both sides, also check they haven't already planed the door.
  8. planning consultant.
  9. floor to ceiling, exceeding current regs, Who best value ?
  10. not any more. new regs. every cold bridge, insulation detail etc has to be photographed with geo tag to prove its all been done.
  11. shame its a shed build, with a normal build you could easily had a vertical DPC at minimal cost.
  12. the only part exposed is the centre join if you have multiple panels side by side. Everything else is flashed.
  13. scaff / cherry picker and replace with dry virge.
  14. gabions a section at a time ?
  15. rubber roof, cheap and easy. couple sheets ply, couple 6x2 timber joists job done.
  16. screeding is a trade and a skill i think. pumping liquid just doesn't seem the same.
  17. not a fan of flow screed either.
  18. pays to keep them onside in case you need them back for snagging at some point.
  19. which elevation has front door/letterbox ?
  20. sounds like you have a plan. Hard to do a m2 figure until you have a plot and plans that can be QS'd. Flat site on good ground <<<< sloping site on clay for example.
