Dave Jones
Everything posted by Dave Jones
Do £1500 to £2000 /m2 estimates include everything finished?
Dave Jones replied to flanagaj's topic in Costing & Estimating
£2000m2 is cheap, realistically you need to be doubling it. £1000m2 was maybe 10 years ago and even then council house spec. No way trades will become cheaper as they have mortgages to pay as well. New regs are a lot more expensive, materials have all gone up etc etc. Value is won or lost on the plot purchase and plans that can be built reasonably cheaply. -
ah right. well as previously posted you can but it up and live with it, 45 it down or plinth blocks. whichever you like the look off.
get rid of zones. if thats 20mm insulation i wouldnt bother. just put the cost of it an into notes and set fire to them. save you money in the long run.
cant see a problem as long as the timber cheeks is new so the edpm adheres and the soakers are done well.
- 1 reply
two different types of skirt and archi in same place ?
Trickle vents fitted too tight to the reveal
Dave Jones replied to Jilly's topic in Windows & Glazing
should be, pop the end caps off and unscrew it.- 1 reply
have you got a router and some patience !! router the skirting line into the archi then filler the line below for a continuous look. Only you will ever notice it but when that random person also notices it , much satisfaction.
oh and the klober dry verge satisfies my ocd, the dogs leg stuff i cant live with. https://www.dryvergeandrooflinedirect.co.uk/products/klober-continuous-dry-verge-t-strip-5-meter-4-per-pack
- 4 comments
- the windy roost
- highlands
(and 4 more)
Touring Caravan for site office?
Dave Jones replied to Andi's topic in General Self Build & DIY Discussion
id put a non material amendment in to add permission for static van during works. if the morons refuse appeal it with costs. -
looks tidy, you could use lead as the top flashing as well, the kits that come with it aren't that great really and have to be bashed about fairish to get the tiles to sit nice. I ended up grinding a fair bit out the back of the tiles so when they lay on the tin flashing they were in line with either side.
- 4 comments
- the windy roost
- highlands
(and 4 more)
wheres it say this in the regs ?
https://www.buildingregs4plans.co.uk/
that change in roof pitch for the conservatory wouldn't pass my OCD test, would have had to warm parapet roofed it! Oh and cut your grass! -
you will need an EPC if you want a completion cert to be able to actually live in the house. At least in England anyway.
attached guide. Technical_Bulletin_A_Guide_to_Photographic_Evidence_for_New_Homes (1).pdf
Plain Clay Tiling - Loading Out etc...
Dave Jones replied to BadgerBadger's topic in Roofing, Tiling & Slating
chalkline the battens to make sure they are dead straight or it will look pants. Measure to top and use a gauge that doesn't leave small cut for top row of tile. Set out eaves row so there isnt a small cut either end and follow the bond up. Use a level to make sure you don't drift with the bond again looks pants. Chalkline the verge as well vertically as you will find with clay not all tiles are the same size you need this to be good in order not to look pants. Use a valley tile if you can instead of a tray, have plenty of tile and halfs ready for the cuts. Loading out doesn't really matter if there is a couple of you to pass and lay.- 1 reply
very interesting read, good find! In the conclusion they suggest treating the SVP as a cold bridge to ground confirming my suspicions. Will vent through tile vent and insulate as much as possible. probably a bit OTT but we have a long runs throughout the house. "In our uninsulated SVP the average temperature increases by up to 2K, but when insulated the air temperature will be <1K above ground temperature, so we suggest treating this as a thermal bridge to ground rather than air."
so you dont crap in the house ?
showers yes. bath and sinks no.
depends, if you go for 'full regs' where a plan check is performed (costs more 8 weekish lead time) or building warrant where zero checks are done. Reality is for most people building a house they employ an architect, the buck should stop with them but as well all know in the real world they are next to useless.
can you quote the building regs that specify this as i cant find it ? Same logic could be applied to any bedroom door or bathroom door opening out into the landing blocking anything downstream etc Only regs I can see regarding cupboards next to stairs refer to the bottom of a flight not the top. Doors which swing across a landing at the bottom of a flight should leave a clear space of at least 400mm across the full width of the flight
not so sure about that. heat goes to cold. would like to see real world heat loss calcs having many meters of cold bridge running through a warm zone.
Coping stone fixing on single ply parapet
Dave Jones replied to health mechanic's topic in Flat Roofs
sorry for more bad news the parapet wall as detailed also fails building control. It needs a cavity closer to close off the cavity and a tray (you may have this cant see from photo). These are weak points of failure when they are done really well let alone when they are wrong from the start. https://www.nhbc.co.uk/binaries/content/assets/nhbc/tech-zone/nhbc-standards/tech-guidance-and-support/parapets-and-copings---revised-05-20.pdf
