Dave Jones
Everything posted by Dave Jones
and ditch all those zones.
window manufacturer supplies the straps. Use built in (tied into the brick courses) closers that are ready made and braced square. have zero issues and no 'wobbles'.
so after talking to marmox they advise running a course just under where the ledger plate sits. There is also a stepped gable on another elevation with same issue. They recommend stepping the blocks up the gable following the trays as you go. attached spec in case anyone needs. spec 6f - gable wall.pdf
Cloakroom cistern frame + pipe hiding
Dave Jones replied to johnhenstock83's topic in Bathrooms, Ensuites & Wetrooms
use a gerberet or similar flush frame, the button panel comes out allowing future access if needed. -
get mains any other option is just hassle and will devalue the place when it comes to sell. you need to determine the fall from your place to nearest manhole. hopefully you are on a hill as 13mm per m which is min you can get away with using 110mm pipe means you need 2262mm of fall. More than likely a cheap £750 pumped chamber will do the job. Just the cost of running a shallow trench from said manhole to your boundry.
exactly this. The way they have been fitted wastes all that time an effort of having a 150 cavity. It's if you have no cavity at all. It's not a massive job to fit them correctly on straps and has already been said get 70% of the frame sitting in the cavity leaving just enough extending into the blockwork so that the frame can be weather sealed to the blockwork. Do tape the insides to make sure they are airtight. I'm going to take a wild guess here but the architect drawing didn't specify this detail right ?
dont get me started on them. almost as bad as estate agents but not quite.
quite agree most are rubbish and charge like a wounded bull.
the man who built his London house from DIY tutorials
Dave Jones replied to joe90's topic in Surveyors & Architects
that would no way pass our planners, all that overlooking glazing. 47k for a london plot. smells fishy. if BBC are promoting it bound to be BS. -
be honest, 90% is copy and paste. Your not re-inventing the wheel on every legoland box that is cranked out. Value wise no more than twice (to account for overheads) a plumber, brickie other trade. The cream who design the very nice and rare designs get remunerated accordingly.
Central Fan Coil Unit - run from ASHP
Dave Jones replied to wardie9025's topic in Other Heating Systems
the MVHR is the air mover no the coils. -
why is it needed for a box ? If the architect is any good a production box should be smashed out in a couple hours. Nothing difficult about it, cut and paste.
yep if you use this mdf https://tricoya.com/
Wow design without blowing budget
Dave Jones replied to Stonehouse's topic in New House & Self Build Design
cracking telegraph pole that! -
Alternative to parge coat
Dave Jones replied to Dave Jones's topic in Environmental Materials & Construction Methods
wet plaster it is then. -
8.98p low 00:00-6:00am 38p normal 53p high (4pm-8pm)
im using greenbuildingstore to design and supply, we are fitting and commissioning ourself.
- 1 reply
im with 100green who took over from greenenergy UK. looked cheaper than octopus and better time slots.
now to switch to time of day tariff @JohnMo i may 75% of electric at 9.43p kwh, in winter the powerwall charges at this overnight and we use it from the powerwall in the day.
we doing the same albeit full MVHR with a cooling unit on the incoming side taking a feed from the ASHP. For the first floor fitting panasonic fancoil units in place of rads to provide both heating (not really needed) and cooling in the summer. They do not need any 'central unit' just a flow and return just like a normal radiator. https://www.aircon.panasonic.eu/GB_en/product/fan-coils/ -
ive used both site QS and the online ones. Site for getting paid (by the bank) and the online to produce the initial QS for the build. found them pretty much ok and reasonable, also offer advice on alternative methods and materials for some tasks may not have considered. While the on site is an extra cost you see them maybe 4 times total so not massive in the scheme of things. The online QS is where its won or lost, you have to get this correct. you need every single expenditure on it not just the materials and labour.
i don't have an issue with paying a decent fee for a decent design. That would mean £1000 tops for a normal sub £750k house., Treble that fee for a more interesting design, stand out features of which you would not see in 70% of other houses. There is also the question of construction drawings containing enough detail to pass building regs and allow a builder to completely price the build (excluding second fix items). This should be no more than half a days work for a competent architect so another £250-300. All planning i would never use an architect always a planning specialist. Same as I wouldn't use a painter to fit a kitchen.
