Dave Jones
    11
Everything posted by Dave Jones
  1. again Joe, niche. You think they wouldnt have a combi if they could ?
  2. Where's my solution you are designing for a heat pump to provide limitless host water for less than £750 installed ? I fully understand I'm preaching to the converted here, but for the rest of the market they are economically unviable. Just have to read the reams of people moving into a new build with one, they wife has a shower and there goes the hot water. Like being back in the 70's. Fair enough the nice here for self builds where cost may not be the main factor they can be made to work but they are niche and once Worcester bo9che get their new boiler sorted will be the betamax to the VHS.
  3. i agree at a cost. Design me a solution that does it cheaper than a combi.
  4. your saying they provide cheap limitless hot water ? Thought not.
  5. you are the exception that proves the rule Joe! They will only ever be a niche product, how is a council house family of 5 meant to get 5 baths and hot water and heating out of one in 24 hours for less than £60 a month in utility bills ? Worcester Bosche have the right idea.
  6. for what reason ?
  7. its not rocket science. heat pump = 10k and 5 min showers then you freeze. dont work when its cold etc combi = £750 limitless cheap hot water. And no i dont like them they are expensive and give a substandard service.
  8. oh and all new build sites now have to have a 3-phase supply installed, even if you only want a single phase meter, more £££££
  9. my choice would be planings if you can get them or recycles hardcore, it will get muntered during the build anyway with telehanders, conc wgeons etc so just make it useable (200mm) and sort after.
  10. hallway wastes a huge amount of space
  11. biggest mistake ive learned is never to take any notice whatsoever of the architect once the build has started. What's on paper doesn't always translate to reality. Find good trades, pay them well and use their knowledge wisely.
  12. who was responsible for the drawings stating the front door opening size ?
  13. there is no extra charge for 32mm connection and as the cost increase in MDPE is miniscule id run it in 32.
  14. what does this include the shell to wallplate ? The roof?
  15. what thickness and make of boards was used (egger ?), what glue was used ? What spacing of screws was used ? Done properly using decent board it wont squeek at all.
  16. and make sure there are no underground utilities running through the plot before you buy. If its sewer it may make the build unviable.
  17. britpipe is right here, what is your m2 costs from the tenders ? List them all if you can.
  18. timber frame will be significantly more expensive than traditional brick and block. Money that could be better used elsewhere in the build ?
  19. if I understand from your photo, water is flowing into your garden from the uphill side ? French drain along boundry with perf pipe and pipe it away downhill. Add latrerals to it from the garden as well if it hangs wet. The question is where you pipe it to. Old houses pipe it into the sewer but this is frowned upon now. Where does your roof drain to ?
  20. impossible to know. You will have to ask them for quotes. could be £100 could be £25000 .
  21. this. looks like they used the slate flashing https://www.velux.co.uk/products/roof-windows/flashings?consent=none&ref-original=https%3A%2F%2Fwww.google.com%2F
  22. without reading all 3 pages, gas combi is way to go. Will not be beaten on price and running cost by any other system.
  23. when you say time and materials do you mean builder turns up and charges you day rate ? recipe for disaster.
  24. can they ? depends on how you get on with the plumber but yes. Should they to the letter of the law ? No. Same as you shouldn't do 31 in a 30.
