You're not the only one.
2020's last laugh: a leaking roof. Advice please.
Gone West replied to ToughButterCup's topic in Roofing, Tiling & Slating
The amount of water needed to travel through 300mm insulation would be a lot more than caused by condensation I'd have thought. -
@ToughButterCup Hi Ian, sorry to hear about the leak. I can't think of anything, other than as you've suggested a tear in the felt. Not a lot of help I know. What are the two types of insulation in the roof makeup? I would have thought a fair amount of water would need to get under the felt in order to make it through 300mm unless it's very open cell type, non absorbent insulation. I can't understand why the direction of the wind would make any difference as the overlap on the tiles should prevent water being blown up underneath. It was a wet winter last year so why no leak then? Sorry more questions than answers. -
IIRC you are not required to register a borehole. We supplied our borehole details to the BGS who put it on the register.
I should think so. Although ours was an accident, it has proved to be useful for watering the garden in the summers. We have two wells just up and down the lane from us but they are only 2m to 3m deep but ours is 47m deep.
Yes that's the site where I entered the data for our borehole.
Our standard soffits are 250mm. I like the look of deep soffits and at the back of the house they're 750mm to tie in with the balcony.
Electric towel rails
Gone West replied to Russell griffiths's topic in General Self Build & DIY Discussion
That is exactly what is in mine. IIRC the instructions say turn on and when it's warm fit the top plug to allow for expansion. Mine are all Geyser. https://www.geyser.co.uk/heated-towel-rails -
Do you have any drawings. Is it possible to check back on the LA Planning website to find what was applied for, and check the Building Control website to see if it's been inspected. Have you put any rods down the soil pipes to see if they are connected to anything. It could save some money if the drains are already connected and the foundations are suitable.
MVHR + ASHP Post Heater control
Gone West replied to john0wingnut's topic in Mechanical Ventilation with Heat Recovery (MVHR)
I think your idea is good and a simple solution to overcoming the problem of cool supply air in the winter. It's unlikely that at normal UFH water temperature you will get too much heat. Our MVHR has a built in EASHP which keeps the air supply at least as warm as the room. It will also provide warm air if required up to a maximum of 50C, any hotter and apparently the dust in the system starts to smell. -
Manifold system versus hot return system
Gone West replied to Russell griffiths's topic in General Plumbing
Nice idea, also will prevent condensation forming on the outside of the cistern. -
Getting a WC and bath waste into the same branch pipe
Gone West replied to lineweight's topic in Waste & Sewerage
I can't see a real problem with that layout and it is the way I would do it as long as the drop is ok. -
As a novice, every job you do will take a LOT longer than a professional. That isn't to say that you couldn't do it better, it depends on who you get, but it will take longer. If you're spending a lot on rent then you need to weigh up what is more important to you.
Sewage treatment plant and water softeners
Gone West replied to Bart1664's topic in Waste & Sewerage
No, it's never been checked. I just use the nose test. There's no smell with the lid off then I'm happy. There is a huge difference between the old septic tank and the treatment plant in that respect. -
We have a sewage treatment plant that has been running for nearly eleven years and we have used a water softener all that time. We haven't found any problems. -
Cost of Electricity
Gone West replied to canalsiderenovation's topic in Air Source Heat Pumps (ASHP)
Our house is heated by the towel rails in the bathrooms so the bathrooms are a bit warmer, 24C, than the rest of the house. You might feel more comfortable increasing the bathroom temperature by a degree or two. -
Cost of Electricity
Comfort is a very personal thing and Wendy would not be at all happy at 19C. The minimum we have our heating at is 23C. Some people are happy to wear outdoor clothes, such as jumpers, inside in the winter but we prefer to wear T shirts in doors. As I said, for most comfort set the thermostat to what you find most comfortable. -
Airtightness test
Gone West replied to Mandana's topic in Mechanical Ventilation with Heat Recovery (MVHR)
86 quid for smoke. He must be expecting a lot of leaks. We paid £200 for half a day which included smoke tests, calculations and airtightness test. -
Introducing ourselfs - extending updating bungalow
Gone West replied to Bernd's topic in Introduce Yourself
Hi Bernd, welcome to the forum. It looks an interesting project, hope it goes well. It's nice to see you keeping the bungalow and extending it. -
Each layer should be in the opposite direction to the previous layer to minimise gaps and hence heat loss.
Sounds like a good plan to me.
@zoothorn If there wasn't a loft hatch fitted by the builder did he drape the insulation over the joists as he was plasterboarding the ceiling. That would explain everything.
From what you have described the reason your room is cold is largely because the loft insulation hasn't been installed correctly. The type of insulation you have in the loft shouldn't be fitted so it can sag or be compressed. There should be a minimum of 300mm. The first layer should fit between the joists snuggly so there are no gaps, is not compressed and is roughly level with the top of the timber, probably 100mm. The next layer should go perpendicular to the joists, and if it was 200mm thick it would finish the job. If less than 200mm fit two layers with the second perpendicular to the first. It's a minimum of 300mm, it doesn't matter if it's 400mm. It's a crap job I've done several times but it does make a lot of difference if it's done properly. The builder obviously couldn't be bothered.
Tile backer boards - help me choose
Gone West replied to Snowbeetle's topic in Bathrooms, Ensuites & Wetrooms
From their Glasroc White Book :- Perimeter and junction sealing Designers must give consideration to the precautions necessary at junctions to ensure that moisture is not allowed to penetrate or collect. Cut edges of boards must be appropriately sealed and waterproofed at abutments. Waterproof sealant should be used around baths or shower trays, between the wall surface and the floor at the base of partition or wall lining, to prevent any possible moisture being absorbed by the board core. Tanking systems In extreme moisture environments, the exposed surfaces of Glasroc H tilebacker should be treated with a suitable tanking system. Continuity of linings All partitions and wall linings should be complete. There should be no omissions to board linings, e.g. behind baths. -
Hi Kes, welcome to the forum. There's all sorts on here as well as all the different types of projects. You'll find plenty on renovations, extensions and new builds.
