Water contamination in heating oil tank?
Gone West replied to richi's topic in Boilers & Hot Water Tanks
In the past I syphoned the bottom of my oil tank every couple of years to ensure water didn't build up sufficiently to come out of the outlet. In my tank the sump below the outlet pipe is large and it would take a lot of water before it caused a problem, although that was what happened the first time which led me to do the syphoning. -
I stopped using Firefox because at every update it seemed to be trying to look like Chrome and I liked the look of the old Firefox. I started using Xmarks when it was Foxmarks and just carried on when it was commercialised.
- 84 replies
I got fed up with Firefox some time ago and now use Pale Moon with Xmarks.
- 84 replies
Clay sub soil drainage suggestions please
Gone West replied to readiescards's topic in Landscaping, Decking & Patios
I have seen winch drawn mole ploughs used. -
Ventilation rates
Gone West replied to Gone West's topic in Mechanical Ventilation with Heat Recovery (MVHR)
I can't find the link at the moment. For extract I used 2 ACH for bathrooms, 0.7 ACH for the kitchen and 1.1 ACH for the utility room. For supply I used 0.4 ACH for bedrooms, 0.5 ACH for reception rooms and 0.3 ACH for the hall. This gives a balanced total of 101 m3/h on fan speed 2, which can be reduced by using fan speed 1 and adjusting the fan speed percentage accordingly. -
MVHR ducting to outside
Gone West replied to Moira Niedzwiecka's topic in Mechanical Ventilation with Heat Recovery (MVHR)
When I was researching into how to install MVHR around eight or nine years ago I made a list of rules I found relating to connecting the unit to the outside. I'm sure these are not exhaustive and nor are they prescriptive, but it's what I used to install mine. 1. The inlet and outlet grilles should be 3m apart to prevent cross contamination of air. 3m was the distance I found mentioned most often. 2. The inlet and outlet grilles should be high enough (2m) to prevent interference by animals or children. 3. The inlet and outlet grilles should be on the same wall so they are affected equally by the wind. 4. The free flow area of the grill including insect screen should be at least as great as the cross sectional area of the duct. 5. The duct should be smooth wall to reduce air flow restriction. 6. Any ducting bends should be large radius of curvature or two 45 degree bends to reduce air flow restriction. 7. The ducting should slope downwards slightly to ensure any moisture drains to the outside. -
It's normally recommended that there is a minimum 3m space between MVHR inlet and outlet. -
Ventilation rates
Are there any thoughts about the different methodologies used between PH and BR ventilation calculations? Please. -
We have standard glass Eclisse pocket doors. Eclisse do telescopic pocket doors. http://www.eclisse.co.uk/telescopic-pocket-door-system-single/
@RichS and @willbish The cost of the removal and the replacement works were borne completely by the company laying the slab. As I had video evidence of the work being done and the time taken they accepted liability and in that respect can't be faulted. There was some half hearted vibration work done but the concrete was going off before it could be laid properly. The cost cutting included not pumping and using a concrete supplier whose depot was too far away. The weather being quite warm didn't help matters. After ultra-sonic testing showed cavities, core samples were taken to verify the fact. After that there was nothing to do other than complete removal.
I also had problems with my passive slab, details in my blog, although not the same as yours. The slab is 200mm thick all over and the second attempt, which I had pumped with C35, was fine. On ours the DPM was on top of the polystyrene and held down by the steel and the concrete was pokered. When I had mine done self compacting/levelling wasn't really an option but I would have used it had it been available.
@James H It looks great. If you've got time it would be good if you could do a blog showing your progress through the build.
Well done, you should be proud of your achievement.
I paid £140 for as built SAP and showed them my PHPP output for the design.
If you are having a heating system then you can adjust that to suit your construction. You could reduce the size of the sliding doors. I would have thought they would need a heating system in Canada whatever the thickness of the walls so there isn't a saving to be had in not installing a heating system. Our walls are 500mm thick but living in the South East of England allows us to not have a conventional heating system.
Thank you Moira. Yes the Genvex is working fine. Looking at the specifications for the Combi185 I think the small one 'S' would only work in a well insulated flat and the larger one 'LS', which we have, would only work in a well insulated small house like ours. I did look into using a Sunamp PV and separate MVHR near the end but the ventilation and DHW side of the build were too far advanced to change things.
Council tax
Gone West replied to nod's topic in Self Build VAT, Community Infrastructure Levy (CIL), S106 & Tax
@Onoff The council have recommended a band E and I have suggested a band D. The other two cottages in the area that have three bedrooms are band D. The original bungalow was a C. -
Council tax
Let's hope you get a refund without any problems. I'm sure if it was a private company doing this sort of thing it would be illegal but local government can get away with it. The local council tax department recommends a band to the VOA hoping it won't be challenged and mostly seems to get away with it. A new bungalow built next door to here has had a ridiculously high band assigned to it and the owner is selling it and doesn't appear to be worried. We'll tell the new owners that the banding is two above the original so they can challenge it. -
Looking at the U factors you've since supplied I would say the level of insulation is poor and presumably only meets, rather than exceeds Building Regs. By increasing the levels of insulation in all the areas of the house you would significantly reduce CO2 emissions and the space heating requirement.
The BCO said I just had to fill in a Section 80 form, which is only one page, and it doesn't cost anything. Mind you taking it down will cost a lot more.
We looked at AM Profiles years ago when we were looking at windows, they looked good, they quoted for us but ceased trading before we placed an order.
Not for me, it'll give me more garden.
Our new house, built in the garden of the bungalow we are living in, is a replacement for the bungalow which will be demolished. The Council Tax Inspectors have been around several times over the last couple of years and finally told us it was to be deemed habitable from 2nd Jan 2018, which we agreed to. We received a council tax bill for the time from 2/1/18 to 28/2/18 for the new house with an estimated band higher than the one I suggested to VOA. From the way the bill was laid out it gave the impression that the bill was due to be paid by 28/2/18. I phoned the Council Tax Office at the local council offices and found out that I didn't have to pay the bill until the VOA had banded the property officially. They really are the most cunning people I have met at trying to extract money. Their excuse was that it was often better for people that bills don't build up. Why aren't they made to print that information on the bill?
