Onoff
    206
Everything posted by Onoff
  1. Could you..... On the basis that UFH is so efficient, run the waste through a loop under your slab and hold it there until the heat dissipates.....thus recovering some heat. Then let it exit via a small turbine to get some hydro electric power.....making use of the kinetic energy.
  2. A big house with lots of bedrooms will no doubt become a grandchildren magnet with the hordes descending for holidays & festivities. Just when you thought you'd got rid of the kids!
  3. Not wanting to detract from this thread so I'll keep it short. Ref the issues between myself and Jeremy, we've been in direct contact throughout the day and the air has I hope been cleared over this. I'm in a better position knowing what apparently went on over eBuild's demise. Jeremy made some comments in haste ref his setting up his own site which riled myself and others. I bit and had a little dig back then and that carried on over to here. Jeremy has been gracious enough to admit this and I've genuinely conveyed my respect for what he's achieved and that I would be sad to see him go. I really do mean that. Apologies also for the self promotion jibe. I'd like to leave it at that. Regards
  4. Just adding a perimeter lip with 20mm of 12mm ply. Glued and stainless panel pinned about every 75mm: The idea is that the bath lip will be outboard of the ply lip. The tiles will abut the ply near enough and the whole thing sat on a good thick mastic bead: I've also screwed the marine ply deck down with stainless screws. The one question mark is the use of D3 Gorilla glue throughout! Next a tanking coat of "something", tba!
  5. Taken on the boy's Motorola phone but difficult to do the issue justice. It looks better than the video shows generally and not as "glaring". About 10 seconds from the end when it goes from dark red to white there's a flicker. I'll maybe try again when the Samsung tablet is charged up. No diffuser fitted as yet so that may help. I've also tried another "genuine" PSU from one of these kits and it makes no difference. Also tried another strip of lights and it's the same. Tbh the wife is quite happy with it. Maybe be it's me being pedantic.
  6. I'd be VERY careful with your search terms there.....
  7. So is this a case whereby vermin let loose in an MVHR system could actually be a GOOD thing? I'm thinking maybe a degu or chinchilla would be more appropriate size wise. Sort of a self cleaning system, just plumb the Rotastak in! Seriously, that stuff can't be good for you, would it harbour bugs etc you'd be breathing in? What is the protocol for periodic cleaning of these ducts.
  8. I have done so in parts along the wall, it's brutal on chisels! If course you end up hacking the DPC level with the brick/block underneath so it really needs taking off above and a bell mouth reforming as you did.
  9. Cheers Dave. My thoughts were that if using EPS it could happily bridge the DPC without rising damp being a problem as it's not hygroscopic. This is I think why EPS is preferable to PIR all day long for EWI. Pretty sure it's done it's just the exact detail I'd like to know. I once saw a commercial size stack of blue board insulation go up in flames on an adjacent site (think that was EPS). Thick, black, acrid smoke. It enveloped the site I was on and someone hit the alarm in our building. OUR stair pressurisation units kicked in sucking in thick, black, acrid smoke...
  10. As I understand it, EWI should really continue below ground level for a certain distance. My understanding further is that it needs to sit against a"flat" wall rather than something rough with air pockets. In my case then the walls would need taking back and smoothing off with a render coat. The current finish looks to have been achieved by pressing a chip pan into the render! So.....when you get to the DPC, a mixture of slate on some walls and a tarry substance elsewhere what happens there? Do you need that smooth rendered face to continue all the way "down"? Then when you reach the footings, in my case not much wider than the wall: Do you stagger the EWI? It's a right mess tbh. The render was continued down over the DPC. An external path had been laid on polythene sheet lapped UP the walls! Damp issues? Oh yes! One step forward & two back!
  11. This? http://shop.vitcas.com/vitcas-high-temperature-plasterboard-709-p.asp?gclid=CImgu7TSwNECFbEW0wod8fgFiQ
  12. A pity they didn't go into the reasons why eBuild closed. Still, can't let things like that get in the way of a good story and a bit of self promotion.
  13. I could drive a car all the way round my house though I may need a 4wd for a start and possibly some bridge laying equipment to cross the various unfilled trenches.....
  14. Have you considered converting the garage itself to liveable space?
  15. The technical data sheet says it's not a conventional pu: http://www.everbuild.co.uk/D4-Wood-Adhesive
  16. Wish my MiL had a pacemaker.....
  17. This? http://www.toolstation.com/shop/p61864?table=no Still debating whether to ditch the D3 Gorilla Glue I've got for my bath carcassing and get some of this D4. I've used it loads over the last few years but the last lot turned into a rubbery white mass in the (new) bottle for some reason.
  18. Abandoned / stuck cars up Rowdow Hill this morning. Pilgrims Way and through Otford on the way to Sevenoaks at 4.15 this morning. Roads gritted but not as good as I'd hoped by any means. Lot of tree branches down due ti weight of snow. Trains OK to London though I missed the first one. Just spoken to the wife who said it's snowing again there now. Death Hill up from Farningham has loads of abandoned cars & lorries but according to FB they're being moved now.
  19. Double thickness of plasterboard over lapping at the joints is all I remember from helping a mate years ago.....
  20. Possibly takes time for a capacitor in the trannie to discharge.
  21. Elica cooker hoods at least seem very well respected: http://www.ukwhitegoods.co.uk/help/about-the-appliance-industry/manufacturer-information/2806-elica-cooker-hoods
  22. Go for it. I bought an Israeli designed, Turkish made induction hob from Comet when they closed down. That well known make "Electra Elecheib". Been as good as gold. Was £399, down to £199 and I found a 15% discount code that worked! For the price I "took a chance".
  23. Liking it! The overall shape is easy enough out of a bit of MDF. I'll probably print the lettering onto a piece of paper, glue to the mdf then carefully route out. As for the raised relief work....."pipe it" with No Nails or similar?
  24. OK, the jury's out on these LED strips. I think we're sitting in the cheap seats! Set on a single colour that'll come back on that setting when you power up and they're great. The one program I wanted, the gradual fade in / out thru the colour range can be a bit jerky between some colours. Enough to annoy me whilst trying to relax in the bath! Needs to be a smoother transition. I may of course be doing the product a disservice as I've bastardised it with the DIY 7-core extension. Running the sensor cores along side the DC lines might be causing an issue? I'll have a go with another set not messed around with. Still it's pretty good for <£10. Worth getting a set just to play with IMO. The little white box is interesting; a 3-core ribbon to the sensor then a 4-core flex coming out of it. According to the pcb inside, the 4-core does Vcc then R, G & B aka "RGB". So the flex from the white box goes: Vcc - Black core R - White core G - Green core B - Red core Easy enough to ditch the short white lead and go direct to the pcb with an extension cable. BUT the original short lead to the lights is done "properly" with the cable cores matching the RGB colours. Anyway, I just quickly tacked the extrusion up and pulled the 7-core thru the flexible conduit. Conduit inside the dwarf wall, along the side and round the back. Just coiled up in the bath recess at the mo. Tbh I'd like it dimmer and more "subtle": The conduit is slightly over length possibly. To be trimmed to suit the tile depth: Video to come! I tried one on the phone but the quality's naff so I'll do on the tablet later as it was too late last night. Of course it's all got to come out for tiling!
  25. Done a lot of st/st, the ones on the left! I do have a couple sets of those Ed.
