Everything posted by Onoff
The 18mm ply "deck" that the bath sits on is a little low at the internal corner. These are the measurements, slipping in corner packs and then making sure the bath is level in all planes. I'm planning to glue and pin a 12mm lip all round the edge of the hole in the deck so the tiles have something to butt up against and also to act as an upstand against water ingress. -
Didn't take note of all the pics first view, just the first one. I've used liquid DPM myself years ago with some success. From memory you applied one coat then when dry a second and coated it with sand that provided a key to render to which I did. Looks similar on the wall next to the wc. Would it I wonder be worth tanking the wall and boarding over? I've a similar dodgy wall in the bathroom. Where the window is was a door, where all the render is was a window. The left hand white area is a bit hollow. I've even got plaster been put on top of wallpaper! Hopefully the battens will keep it all in place.
Whatever's quickest if covering it up! Just render over the patches tbh BUT...as you've already PVA'd them and it's now dry I'd NEAT PVA it just before you render. Or you could roughly cut to shape (square off if pedantic) some plasterboard and stick that in the holes or EPS depending how deep. I've done all of 'em.
Just a little more procrastination and the bath can go in and possibly stay in: Maybe... -
Material / design for non-slip footpaths?
Onoff replied to Ferdinand's topic in Landscaping, Decking & Patios
PMSL! I reckon you might just get the record for the most "likes" with that!- 13 replies
- winter
- slip hazard
- (and 4 more)
I'd give metal a go. I'm an apprenticed mechanical & production engineer and was taught (sometimes beaten) to hacksaw to within 20 thou. Emery cloth was a banned and everything had to be draw filed. I love a bit of precision filing even now. My worry with some of those metal or metal effect trims is if it's a coating that would flake off. What do you cut the trims with btw? Those fancy shears, chop saw, mitre block? Inward sloping mitre, cutting trim / tiling this'll be fun: -
Thinking of this on a wall scroll in the bathroom: "Our Guru, who art in Wales, Hallowed be thy name. Tile Kingdom for some, But thy will be done, In porcelein (cost permitting). Give us today our daily tips. And forgive us our cock ups, ..... Work in progress, something else that won't get finished... -
SO DO I! Pretty sure when she sees the white she wont like it. She can't visualise stuff in her head is the problem, has to "see it". Had a half row yesterday when I said that at least the upstairs dormer gets nice and warm when the rads are on. (Despite being bloody freezing when not). Straight away it was "You're always saying it needs redoing as there's not enough insulation!". The concept of 4x2 walls with hit and miss insulation, heat loss / retention & draughts.....I started to try and explain but gave up. I might try cold bridging and see if we get a Scanners moment... -
With a bit of ply about 8mm thick to simulate the tile and some Blu Tack, it would appear it'll all line up: -
Onoff: "I've ordered the tile trim!" MrsOnoff: "I thought we we're going to buy it as we needed it?" (Where TF she got this idea from?) Onoff: "No it's cheaper this way and better quality than the sheds!" MrsOnoff: "What colour did you get, white?" Onoff: "Yes, like you wanted!" MrsOnoff: "Well "we" looked at the other colours and didn't like them!" Onoff: "No, I wanted metal but you wanted white!" MrsOnoff: "Do they do grey?" Onoff: "Yes, BUT I'VE ORDERED WHITE!" Go figure! -
A bit of modification to bring the conduit forward! -
Yep, found that to varying degrees with a couple of makes. Last pic where I'm mocking it up, I stuck the LED strip cut off to the ali extrusion cut off. Even though I cleaned the ali with Multisolve the strip didn't stick that well. I can see it might fall against the diffuser over time. -
Dunno, I'll wait till the trim arrives. Ordered 10 lengths just over £30 plus some external corners. Tempted to just glue a length of MT2 under there and be done with it! Half mulling whether I could run a length of 20mm round pvc through the table saw and use half as a 10mm radius capping with no joint! Sod's Law it'd be a different white! -
You should have said, I've just binned a load...
Insulating below footings shouldn't be a huge drama as I plan taking the external paths up anyway for one reason or another and the footings aren't that wide. Another pipe dream probably. After the bathroom it's either the roof or knock through the lounge & dining room. Different ceiling and floor heights, the walls are offset one room to the other and of differing construction! Business as usual then. Didn't the ROI government spend millions retro fitting housing stock whilst at the same time creating jobs?
That's good, my local yard (Kent, proper "South") for treated, constructional grade timber: 4*2 CLS 1.20 per metre £1.72 6*2 treated joist 2.05 per metre £2.69 145mm decking 1.65 per metre £2.15 150*15mm cladding 5.27 sq/m Pity it doesn't grow on trees.....
Is there any point in doing retrofit EWI piecemeal? By that I mean elevation by elevation. Would it improve heat loss issues with each bit done?
I could angle a 20mm Starrett I guess to connect the two hole positions..... This 10mm Genesis pvc trim has a little lip. Can't see two trims abutting neatly because of this? Can't see how they'll butt neatly: -
With the ply lining and an offcut of extrusion: -
20mm flexible conduit coming thru a 20mm hole in a 95x45 upright of the stud wall: -
Doing it "your way" which tbh I'd prefer then the LED extrusion would be offset to the conduit by about 22mm. Going to have to go for this: Thinking that instead of 16.5mm wide tile I could mitre bond a bit of 16mm mini trunking between the two tile trims. -
I want to make a brick. How hard can it be?
Onoff replied to Construction Channel's topic in Brick & Block
£4, job done! http://www.hobbycraft.co.uk/das-terracotta-air-drying-modelling-clay-1kg/563745-1000 -
Ref @Nickfromwales idea; the red dashed hole is where I've my flexible conduit exit and it's immovable tbh. I wanted it to line up with the light strip really: I need to make a decision asap ref what tile trims to get. White, plastic quadrant is a given as that's what SWMBO wants. But with an 8mm tile do I go for 8 or 10 I just don't know.....I've shown the 10mm one. -
Pick holes? You're supposed to be making a brick!
