Everything posted by Onoff
Something like this probably. I'm not BUYING a proper flashing. Going to wet diamond drill the tile and 3D print flashings. All glued down with CT1.
It's finally happening: Using unistrut instead of proper channel so had to get creative with some 3D printed spacers:
Totally different conversation in Brighton for example.
I like Dulux Diamond Matt.
3D printing, can anyone help out?
Onoff replied to Nickfromwales's topic in General Self Build & DIY Discussion
Just read this. Would have been happy to help. Use the printer here all the time for practical purposes. -
https://www.goodreads.com/book/show/543682.The_Complete_Book_Of_Underground_Houses
PCP airgun with a red dot sight
Wendy House & Decking Stain - Help
Onoff replied to richo106's topic in Landscaping, Decking & Patios
Shoes/toads... -
Never did us any harm as kids: https://www.creosotesales.co.uk/product/traditional-creosote-20-ltr/ -
My beech isn't covered in human sh!t though!
I have a mate, a slightly special, albeit fully qualified and insured tree man. He's itching to sort all my trees out which is happily let him do but for the cost even at mate's rates. My beech is immense!
It'll be in the charger installation manual. Dedicated to my EV charger I have a 40A, bidirectional, double pole, Type C, 30mA RCBO.
- 14 replies
I presume you ideally have to change all your RCBOs to bidirectional? My new garage board is all RCBO, bidirectional, double pole, SPD bells and whistles. PV will go on the garage. I'll have to check what I fitted to the slightly older board in the house though I don't think that'll matter as the PV with be the Henley side of the house cu.
- 14 replies
My current charger isn't bidirectional. It's an Indra and I see they're working on them.
- 14 replies
My Skoda Enyaq 85x does too.
- 14 replies
Wasn't there a tin mine where they switched the pumps off and everything flooded? A couple of weeks later the price shot up as in it would have paid to keep it viable. By then though the damage was done etc.
In some cases justifiable in spades: https://www.sovereignmagazine.com/article/cornish-mine-redmoor-billion-critical-minerals
All it needs is Keanu Reeves and a tuning fork! We could of course mitigate a lot of this by having a state body with real teeth to force insulation upgrades of existing housing stock. Why not instigate punitive taxation for those not complying? (I'd be f***ed). Then ensure proper compliance by those doing it. Let's get away from the mass builders using one good test result for the whole estate and cowboy heat pump installers fitting them to inappropriate buildings.
Australia has 160 billion tons of thereabouts of proven coal reserves. Reckon the Chinese will be running coal fired stations for a good while yet.
It's almost as if they're suggesting a lot of public funding issues are caused by uncontrolled immigration and the costs entailed supporting/dealing with it. Weird eh?
Just loving my EV 😉 Jump in and look and the range. Then turn the heater setting up and watch the range drop before you've even moved. Green washing BS.
I think I'd lay down a permeable weed membrane then do gravel grids so free draining. How uneven is the grass exactly?
I believe you in that I've a similar issue and feel your pain. Since this crisis we've not used our oil for heating. Very uncomfortable is how I'd put it. We only use the oil for hot water. It's genuinely often colder inside the house than outside in the sun. As I write this, waiting to go to work I'm huddled under a blanket in the lounge. With the house so cold you can feel a constant, gentle cold breeze across bare arms. No doubt coming from multiple gaps in the building fabric. It's pretty miserable tbh. We've put a curtain across the lounge and run a 2kW electric heater in there. It eventually takes the edge off after a good few hours. My lad has taken to showering at work. Luckily my daughter is at uni. SWMBO and I huddle in the lounge at night like one of those old couples living in fuel poverty. I'd put oil, gas, coal even wood in the "high quality" as in high temperature heat bracket. ASHP is "low quality" as in low temperature heat. It can and does work but you're building fabric needs to be proofed against heat loss and the effects of (cold) wind washing. I can't imagine how long, if at all, it would take for that to heat your big old stone wall fabric house at the same time compensating for the losses. Yes I could have the oil boiler running at full chat and it'll eventually bring the house up to a reasonable temperature. A wood / coal fire would be great to get some instant heat. Is there a room in your house where you could in effect do all six sides of the "box" with seamless, internal wall insulation as in no gaps in the insulation where the walls, floor, ceiling meet? That and have good windows and door. Think of it as a thermos flask. The better the insulation, with no gaps, the less loss through the walls of the flask, the hotter it feels and longer the heat stays in the flask "room". You would then need less heat to heat it. You would still need to be careful.ref ventilation.
Ah! Didn't realise he was in foreign climes.
