Everything posted by Onoff
Does it have a current transformer attached to the incoming house mains live or some other "intelligence"? As in what stops it drawing too much and popping the main house fuse when you've the electric hob and shower on full chat then decide to charge the car? Mine has a current transformer at the house connected to the EV charger via 37m if Cat-6 that also connects the charger to the internet router. I did the bulk of the work myself on mine and then the sparks came along and certified it. Mine's a company supplied charger. So I have an Electrical Installation Certificate for the charger. On top of that I'm pretty sure there should be a form done for your DNO, in my case UK Power Networks, the form being a Low Carbon Technology Application Form. Not saying it won't all work etc but things to be aware of. I'm on 22p/kWh. Looking to get a smart meter to take advantage of lower night time tariffs.
Similar situation here where my mains water comes up through the footings / slab then into a suspended floor space. I ran the MDPE water pipe in a blue corrugated duct: I then rolled a bit of perforated, galvanized sheet and wrapped the exposed section of duct within the suspended floor space: Like this:
Recessing elec conduit in floor for floor plugs?
Onoff replied to Great_scot_selfbuild's topic in General Flooring
I'm thinking the duct/cable should be at least 50mm deep if in a floor and of course RCD protected. -
Cheap stainless steel pot scourers scrunched in and foamed. Crushed, broken glass is good. Round here it was de rigueur to lay bottles down if building a shack, smash them all and cast the slab on top. Just to stop the tunnel bunnies gnawing their way through.
Galvafroid, MIO (micaceous iron oxide), black bitumastic etc. But then I'm old school.
What are the best prices for (EWI) EPS insulation at the moment?
Onoff replied to oranjeboom's topic in Heat Insulation
It was @MarkyP I believe. He still looks in on here I think: -
Converting a drystone wall to a mortared wall
Onoff replied to sb1202's topic in Landscaping, Decking & Patios
Cover it in stainless mesh like an in place gabion. -
Very, no gas, no main drainage, overhead lines, no streetlights, no pavements, single track roads with passing places etc. The phone lines are copper to the exchange a couple of miles away. Openreach have "no plans" to put full fibre down here as yet.
We have the original BT line, still copper which wasn't great for my lad's gaming etc. As soon as he got a job he paid for Starlink, the £75 a month option I think it is. Speed wise, though x10 better than BT it doesn't seem that great to me as in for the money. The dish is set up correctly. It may be because we are at the bottom of a steep valley so have line of sight to fewer satellites? BT: Starlink:
There was a chap on here, down in Deal from memory, went on a course then did his own EWI. He offered for me to go down and take a look but I never did. Can't recall his username... -
I bought a part roll of Cat-6 on FB marketplace when I ran it for the EV charger recently. Bargains to be had etc!
I just simply lack empathy but fake it to make it. Failing horribly btw
We've turned the oil off for CH. Down to 150 gallons. Only using for HW now.
@Pocster?
Absolutely. Galling is a thing to be very wary of. Use copper slip or aluminium anti seize. A bitch if they gall. Another trick is to use A4 nuts on A2 studs as well as an anti seize medium.
"A far better mix is to use 100gm citric, 40gm of washing soda (tesco green bags) and a squirt of fairy liquid per 1L of water. It is reusable many times. Doesn't turn the metal black. And doesn't etch the metal so much. It is a similar solution to Evaporust".
Aluminium foil and water.
No tow bar. A mate was going to get the same as mine but decided not to as he wants to tow. It feels funny only going into garages now for Ginsters and wine gums mind.
EV. Skoda Enyaq x 85 SportLine. AWD, 175kW DC charging, 82kW battery, 0-60 in 6.6 seconds etc.
Again, J bolts hooked under reinforcing mesh or some similar design of holding down unit with plates and long studs. Windage against a gate and offset loads will just worry chemical anchors out over time. With something locked into the concrete you're trying to "worry" the whole, large concrete footing.
I'd cast in J bolts for that as a "holding down unit". Hooked round mesh going down into the concrete. Don't get me wrong I love chemical anchors.
Try this before cerium oxide: https://www.ungerglobal.com/uk/products/rub-out
Jewellers rouge aka cerium oxide works a treat to bring up scaled glass. We used to use it to get cement stains off glass. It comes in different grit sizes. We once used coarse to fine getting burn marks out of glass that some lad had caused with angle grinder sparks.
Low points: and how to get out of them
Onoff replied to ToughButterCup's topic in General Self Build & DIY Discussion
Plus you can look back to that point where you had perfectly flat, boarded walls and think "If I'd have "turned right" and accepted a mate's proffered help on the tiling..." Guess who turned left and had a go himself? 😡
