Onoff
    206
Everything posted by Onoff
  1. Could be worse, you could be known as "that bloke who's fitted upskirt glass". Eh, @pocster?
  2. Mark the joist centres in case it doesn't work and you have to screw later. Spax flooring screws all day long for me in 22mm T&G chipboard. Superb design. https://tradefixdirect.com/woodscrews/flooring-screws?
  3. Their default is the customer is at fault and that any investigation will be chargeable. Case in point: My BT line was playing up. I reported it and their response was that line testing indicated the fault in or near my property. Furthermore to investigate and sort any such fault would be at my cost. From memory I had to agree to I think to an over £100 minimum charge. Making sure that no overhead lines (their lines) were snagged by (my) trees I disconnected the overheads at the box on the wall and insulation resistance tested the surface mounted cabling running from the box along the house and through the wall to the master socket. Tbh I'm pretty sure it's their cable anyway (maybe the old "Dropwire No.1"?). Plugged in a known good phone and still dead. Even tried another master socket. It was pretty clear it was their side so I wrote back with the IR results and that I wouldn't agree to the minimum charge. Fault was found 2km away at the local exchange. So much for in or near my property!
  4. Has someone made a serious pricing faux pas here? Get in quick! https://www.screwfix.com/p/dulux-trade-diamond-quick-drying-matt-emulsion-paint-pure-brilliant-white-5ltr/6180g EDIT: IF you can find any store with it in. I've hunted high and low to no avail.
  5. Find your local galvaniser: https://www.galvanizing.org.uk/find-a-galvanizer/
  6. Seems it's not going too well there: https://www.google.com/amp/s/www.forbes.com/sites/brittainladd/2018/07/08/lidl-usa-what-went-wrong-and-what-it-can-do-to-recover/amp/
  7. How about the Roman equivalent Vulcan? He made slave girls from gold to do his every bidding. ...was a very ugly baby too!
  8. You NEVER told us you had a mentor! I had visions of you lashing it together thinking it was great and then grandchidren or such like running into it with disastrous results. I remember the shipping container welding attempts! Go for it then but I stand by my finishing comments. It'll be bloody annoying having rust streaks down your render in a few years time. Galvanize then paint or ppc would be my first choice. Shot blast to Swedish standard SA2.5, zinc flame spray then paint or ppc the second choice. A quick home wire brushing and painting won't last imo. And don't be tempted to have it powder coated over bare steel even if clean, if not galvanised or zinc flame sprayed first. I looked at some stuff I put in 32 years ago the other week. 5 floors up the side of a building. That was zfs/ppc. Still looks good.
  9. How wide is it out of interest?
  10. It's a European thing, they leap up out of bed and throw the doors open then do their morning exercises in all their naked glory.
  11. My flat coated retriever would have been straight in that!
  12. Imho 12 dia verticals are too small and will flex. Something like 16x16mm sq would be better I think.
  13. Hats off to you having a go but if it were me I wouldn't dream of making one unless it was galvanised before painting. You'll regret it when water gets into your crap welding holes and rust streaks. Even worse where it fixes to the wall. At the very least zinc flame sprayed then powder coated. Just saying. https://bearmetals.co.uk/juliet-balconies?
  14. What sections are the verticals and horizontal?
  15. I'm ill and not doing anything so fingers crossed nothing goes wrong! Crazy with thread pitches and I feel your pain. When I changed the two 2-port and one 3-port valves here from Tower brand to the Honeywell ones, only the nuts/olives on the 3-port were the same. I then didn't have a 22mm olive splitter!
  16. Don't know. The tank level drops below the outlet and the burner must suck through what's left in the pipe. The pipe is now empty. I then get +2000L of oil delivered. You'd expect it to flow freely through the pipe (about 25m long). Not a dribble without some help. It's a copper pipe maybe 8-10mm, not coated or anything. Maybe kinked by a root?
  17. The outlet on my oil tank must be a good 2m above the (Riello) burner. Guaranteed though if I run out completely I have to disconnect the feed pipe at the fire valve (level with the burner) and "suck" the oil through with one of these:
  18. Oil level lower than the burner? Isn't this is is what a tiger loop is for?
  19. Water bar...who knew, never heard of them before now. Before this my thought would have been, if anything, that there's something in a can you coat the join with before the next pour. Everyday's a school day!
  20. Ok for chipping the old stuff off but a pita to keep moving when you re-render.
  21. That's it, draw a bead on @Onoff! Leave me alone. I'm not well and feeling sorry for myself. Don't even have the strength for a witty retort! Christ knows where this came from, been going downhill all week. At first I thought it was the silicone fumes but I could have just as easily caught something on the Tube.
  22. Scraping the old silicone out.
  23. Can't go wrong with a seefood diet...
  24. Could the previous ploughing have cut the pipe and then blocked it with a sod of earth? Hope not.
