Everything posted by Onoff
Was sure somewhere I read they were changing to 3 x 1kW to allow for some redundancy if one failed... Virgin coconut oil at Lidl for £2.99/300ml. Melting point around 24degC...just thinking out loud...
Do it please. As I started reading your post I was wondering if there was a vertical access "tube". Is the existing thermistor chain removable? I wonder if SA would consider a retrofit sensor array a better controller could make use of? Is it one immersion heater in these units or 3 x 1kW or am I thinking of something else?
So a vertical string of multiple sensors in series that trip out a little before the crystallization temperature?
Let's hope it's not your stud detector! ?
Don't you then chance overcooking the PCM below the raised sensor array? Isn't it that it doesn't change state all at once but relies on convection currents that can't be "rushed"?
What's the test, a flood test?
- 1 reply
Have a word with Colin: And he'll direct you to Aldi/Lidl!
I'd have gone with "Hope your bastard wet room corner falls aren't enough and you end up spending a fortune on folding glass doors or worse an unsightly enclosure!" Not that it's worrying me!
If they haven't and you weren't there to see it done and take note of the materials used you've only yourself to blame! ? Hopefully they did something like this: https://www.ikogroup.co.uk/2013/07/24/iko-permatec-hot-melt-waterproofing-system-installation-video/
Erm...that looks like felt not asphalt. Asphalt is boiled up in a bfo pot and trowelled on to form a seamless continuous layer. What did the spec say?
I thought this was going to be a seamless hot asphalt type thing this time around?
Not an issue, SA will pay to beef your structure up! ?
That's a bit unfair on the installer, poor choice of words maybe? More a case the installer shouldn't have to over specify. The installer doesn't decide / stamp the rating.
So is it the case that an old model, smaller sized Sunamp PV worked "better" than a new, larger sized UniQ because of limitations imposed by SA on the new range? If so SA should have said a long time ago they were redesigning for a mass market and that to achieve similar results to the old PV then go up a size. The customer now has to bear the cost of the uplift due to the value engineering that's gone on? Taking the long term view then tbh, IF the tech works I'd live with that and another £600 or whatever for a couple of units. I'd always be thinking though that I've a dumbed down model that could have been better.
Did he remove all the old stuff, clean and reapply? What silicone did he use?
Not any more, all gone!
Presumably it's feasible to plumb for a TS/UVC in such a way it's a quick swap if SA ever sort the issues?
Picked this little tool up at the motor factors. Far superior at removing silicone from the tiles than the Stanley bladed window scraper type: £2.50 for the tool and £2 for a pack of 5 spare blades (both + VAT).
FFS you spend money on stud fiinders like I do on silicone!
Did you pay by credit card?
Only DeWalt I have is a GIANT router. Beast.
As I say I'll probably take this, the second one back. Can pull the trigger now and nothing. Have to give it a damn good whack to get it to go. Brushe or some other loose connection I guess.
Space rich, cash poor people like me do!
- 186 replies
- sunamp
- energy efficiency
